Test/review of Vapcell INR18650 3400mAh F34 (Green) 2021
5 posts / 0 new
HKJ
HKJ's picture
Last seen: 17 hours 14 min ago
DSC_4602
Official specifications:
  • Min capacity: 3300mAh (0.2C discharge)
  • Nominal voltage: 3.60V
  • Max Continuous Discharge Current: 10A
  • Max Discharge Current: 20A
  • End-of-charge voltage: 4.20V
  • End-of-discharge Voltage: 2.5V
  • Weight: 48g ( Appr)
  • Internal resistance: 24mOhm ( Appr) AC 1kHz
  • Standard Charge: 1000mA,CCCV 100mA cut-off
  • Quick Charge Current: 2000mA
Vapcell%20INR18650%203400mAh%20F34%20(Green)%202021-info
This is a high capacity 18650 cell with moderate current capability.
DSC_4600 DSC_4601
DSC_4603 DSC_4604
DSC_4605
DSC_4606
DSC_4607
Vapcell%20INR18650%203400mAh%20F34%20(Green)%202021-Capacity
The two cells tracks nicely, they can deliver up to 10A, above there is heat problems.
Vapcell%20INR18650%203400mAh%20F34%20(Green)%202021-Temp-10.0
Vapcell%20INR18650%203400mAh%20F34%20(Green)%202021-Temp-15.0
Vapcell%20INR18650%203400mAh%20F34%20(Green)%202021-Temp-20.0
Vapcell%20INR18650%203400mAh%20F34%20(Green)%202021-CapacityTimeHours
Vapcell%20INR18650%203400mAh%20F34%20(Green)%202021-Energy
Vapcell%20INR18650%203400mAh%20F34%20(Green)%202021-PowerLoadTime
Vapcell%20INR18650%203400mAh%20F34%20(Green)%202021-TripCurrent
Vapcell%20INR18650%203400mAh%20F34%20(Green)%202021-Charge
Discharge-Vapcell%20INR18650%203400mAh%20F34%20%28Green%29%202021-pulse-1.0%2010%2010-IR
Conclusion
The cells works nicely, but the internal resistance increases more than usual when the cell is near empty.
Notes and links
The batteries was supplied by Vapcell for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
GhostJoe
Last seen: 1 month 1 week ago
Thanks a lot HKJ, looks like the cell is a BAK 1N18650CP under the wrap
https://www.18650batterystore.com/collections/bak-18650-batteries/produc...
Sillen
Sillen's picture
Last seen: 1 day 23 min ago
Thanks for the write-up HKJ. Got a couple of these two weeks ago. Tests ok 3337 & 3313 @1A with S4+
beam0
beam0's picture
Last seen: 54 min 11 sec ago
I’m considering these 20A /10A continuous cells for some medium drain lights, HKJ’s graphs above shows they will provide up to 20A (with heat issues above 10A)… But the BAK 1N18650CP you linked are only rated 6.5A Max, so I’m curious why you say it looks like those under the wrapper?
d_t_a
Last seen: 20 min 49 sec ago
beam0 wrote:
GhostJoe wrote:
Thanks a lot HKJ, looks like the cell is a BAK 1N18650CP under the wrap https://www.18650batterystore.com/collections/bak-18650-batteries/produc...'m considering these 20A /10A continuous cells for some medium drain lights, HKJ's graphs above shows they will provide up to 20A (with heat issues above 10A)... But the BAK 1N18650CP you linked are only rated 6.5A Max, so I'm curious why you say it looks like those under the wrapper?
My guess is due to the 5-lobe top design, which is typical for many BAK 18650 batteries.
However, I think the 5-lobe top design might also be used by other manufacturers (I'm not well-versed enough if this is the case).
