Test/review of Vapcell INR21700 3000mAh T30 (Purple)
4 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 hour 40 min ago
Vapcell INR21700 3000mAh T30 (Purple) 2021
DSC_4685
Official specifications:
  • Model: T30
  • Size: 21.6*70.9mm
  • Typical Capacity: 3000mAh (0.2C discharge)
  • Min capacity: 2900mAh (0.2C discharge)
  • Nominal voltage: 3.60V
  • Max Continuous Discharge Current: 30A
  • Max Discharge Current: 50A with 80°C cut
  • End-of-charge voltage: 4.20V
  • End-of-discharge Voltage: 2.5V
  • Weight: 70g ( Appr)
  • Internal resistance: 8mOhm ( Appr) AC 1kHz
  • Standard Charge: 2000mA,CCCV 100mA cut-off
  • Quick Charge Current: 15000mA below 45°C
Vapcell%20INR21700%203000mAh%20T30%20(Purple)%202021-info
This is a high current 21700 battery.
DSC_4683 DSC_4684
DSC_4686 DSC_4687
DSC_4688
DSC_4689
DSC_4690
Vapcell%20INR21700%203000mAh%20T30%20(Purple)%202021-Capacity
The two cells matches very nicely and capacity is nearly constant at different loads.
Sadly my holder melted at the 30A test, probably because my temperature sensor was out of battery preventing my script from stopping the test if the battery got hot.
Vapcell%20INR21700%203000mAh%20T30%20(Purple)%202021-CapacityTimeHours
Vapcell%20INR21700%203000mAh%20T30%20(Purple)%202021-Energy
Vapcell%20INR21700%203000mAh%20T30%20(Purple)%202021-PowerLoadTime
Vapcell%20INR21700%203000mAh%20T30%20(Purple)%202021-TripCurrent
Vapcell%20INR21700%203000mAh%20T30%20(Purple)%202021-Charge
Discharge-Vapcell-T30-pulse-1.0%2010%2010-IR
Conclusion
It looks like a good high current battery, it maintain voltage well at 30A, but may need a temperature cut-off.
Notes and links
The batteries was supplied by Vapcell for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
GhostJoe
Last seen: 1 month 1 week ago
Thanks a lot HKJ, “Internal resistance: 8mOhm ( Appr) AC 1kHz” Obviously it is not a Samsung 30T rewrap.
Based on spec and images, it might be the Chinese Qi Xin 21700.
https://qixinbattery.en.alibaba.com/product/1600074572536-817243732/Hot_...
Superstocker
Superstocker's picture
Last seen: 1 hour 7 min ago
Thanks HKJ!
Correllux
Correllux's picture
Last seen: 5 hours 52 min ago
Hey, what’s that smell….do you smell something burning? Smile
