Die sizes of some dome-less leds
25 posts / 0 new
djozz
djozz's picture
Last seen: 6 hours 39 min ago
Getian GT-FC40____________19.1 mm2
Cree XP-L Hi______ _________3.72 mm2
OSRAM KW CSLNM1-TG___0.94 mm2
CREE XHP35 Hi____________5.52 mm2
OSRAM KW CSLPM1-TG___1.83 mm2
Luminus SFT40____________3.90 mm2
Luminus SFT70____________6.34 mm2
Yinding 5050 30W_________2.06 mm2
Die sizes were estimated from a printout from this picture so likely not perfectly accurate.
Edited by: djozz on 10/31/2021 - 12:06
fogofwar
fogofwar's picture
Last seen: 31 min 12 sec ago
You were able to get your hands on a SFT70? I hope the test is coming soon.
djozz
djozz's picture
Yes, Simon had listed a few but they are marked sold out now. I hope to test it the coming week, and I hope to test the round Yinding led too.
djozz
djozz's picture
With pen, picture-print and ruler I tried to figure the actual die sizes of the different dies. Not scientifically precise but good enough for getting the picture. Results added to the OP.
fogofwar
fogofwar's picture
Nice, I hope the SFT70 turns out well. It seems it will match the intensity of the SFT40 since the die area is about 50% larger and the lumen output will also be about 50% higher. I hope it survives 20A
thefreeman
thefreeman's picture
Last seen: 50 min 30 sec ago
The FC 40 is really big Shocked
No B35A ?
I measured 3.1~3.15mm
The datasheet says 3.12mm
djozz
djozz's picture
Thanks, no I have no B35A.
I just wanted to post the picture actually, but Hoop convinced me to add the names and die sizes.
flightless22
flightless22's picture
Last seen: 1 hour 49 min ago
The Yingding looks interesting
Aspheric light
Source
siletto
siletto's picture
Last seen: 3 weeks 17 hours ago
Great comparison!
Are there some further info on the Yinding round emitter LED?
It seems interesting for a C8 thrower mod.
Agro
Agro's picture
Last seen: 7 hours 35 min ago
It’s interesting that you measured OSRAM KW CSLNM1-TG to be 11% and KW CSLPM1-TG 8% smaller than the datasheet says.
OTOH your CREE measurements are quite consistent with what others measured before.
fogofwar
fogofwar's picture
Very cool, I found the emitter on Taobao. It seems to be designed for projectors. This might induce me to do my first mod with a 8A driver. The beam should be very beautiful – it might even look good in a zoomie.
There is some additional information on the Taobao page. Apparently it is 5900-6300K. There is also one with a glass lens at 5000k.
https://item.taobao.com/item.htm?spm=a1z0d.6639537.1997196601.4.34dd7484...
fogofwar
fogofwar's picture
I contacted the seller on Taobao and they said that the Yinding does 1800 lumens at 8A. If so, the intensity should be very close to an Osram W2. I’m eagerly waiting for the Djozz test and hope the Vf is low.
djozz
djozz's picture
Things went wrong in the household, that consumed my free time this week. I hope doing the test soon.
fogofwar
fogofwar's picture
No worries, I can wait Big Smile take care
Scallywag
Scallywag's picture
Last seen: 8 hours 50 min ago
You’re doing this for free for the community. Please take your time and don’t worry (:
JaredM
JaredM's picture
Last seen: 2 hours 30 sec ago
My yinding emitters are hung up in shipping Sad I’m dying to test them out! Looks like you might beat me to it.
I also was indecisive too long on the SFT70 and missed the boat. My thought was that the emitter plus a suitable driver was going to cost about the same as a 90.2 and FET driver. The 90.2 can be had in 5700K as well.
I’ll be refreshing this page for the next few days
JaredM
JaredM's picture
Anxiously awaiting your impressions of the YD5050. TomE’s and my package is held up at port somewhere since 10-29
Haukkeli
Last seen: 48 min 32 sec ago
I built one C8+ with these YinDings. I haven’t really tinkered with it yet for optimal centering and focus, but at least I can confirm it can take 8A and produced light leans heavily towards greener side of BBL. Even without perfect focus, the hotspot seems similar with Culpm1 or whatever catchy name it has.
JaredM
JaredM's picture
There seems to be another variation of this emitter from YD. It has a clear flat encapsulation that looks like the glass Osrams.
https://m.aliexpress.com/item/1005003092500000.html
fogofwar
fogofwar's picture
Yep, the 5000k version has a glass lens
JaredM
JaredM's picture
Green is never ideal, especially since it desaturates colors, but if this one can hit 1mm² osram surface brightness and double the lumens from a round LES, let it be (a bit) green! <:)
I think it’ll be a great sft40 alternative for 18650 lights. Since its only 2mm², even 6A should throw really well if efficacy isn’t crap. I like to upgrade to a 21700 platform for the 8-9A the Luminus wants. I’ve never warmed up to the PM1 because of its asymmetric corona /rectangular die other than in a D4S where the quad orientation averages this out. It also begs for a collared aspheric build.
Target reflectored hosts for this emitter imo would be in the size range of the (Convoy) M2, D80v2, and C8+. Smaller won’t handle the wattage and larger will be too pencil beam for my taste. Ymmv.
Haukkeli
I use LD-4A set to 7A-9A. Seems to work fine in C8+ with Culpm1 and YinDing. I really like Culpm1 in C8+ driven at 8A. Probably my favorite thrower. I like it more than L21B with SFT-40. Beam is purer and warmer white and throws almost as far, when viewed with bare eye. L21B might throw further, but weather must be crystal clear with it.
JaredM
JaredM's picture
https://budgetlightforum.com/node/79804
Djozz’s test of the yinding 5050 round die.
JaredM
JaredM's picture
BTW.
I did pixel counting measurements of my own photos of the emitters and the areas that I’m gettting are as follows:
CSL NM1 – 1.04mm²
CSL PM1 – 1.97mm²
YD5050 glass – 2.22mm²
YD5050 silicone – 2.12mm²
djozz
djozz's picture
You get slightly higher numbers, and the Yinding is a bit closer to the PM1 than in my attempt to measure them.
