New 5 digit RD6012P Power Supply is coming soon
27 posts / 0 new
RD tech
RD tech's picture
Last seen: 1 hour 42 min ago
New 5-digit RD6012P Power Supply is coming soon!
NEW 5 digit dual current range 60V 12A power supply RD6012P is released now
Hello, our new product RD6012P 5 digit dual current range power supply is coming. Hope you like it and you can check the product information and make order in the link below:
https://www.aliexpress.com/item/1005003472332331.html
As what we do all the time, we will set the lowest price when new product is released, so here is the price:
RD6012P:$79.99USD (normal price:$96USD)
RD6012P-W:$83.99USD (normal price:$100USD)
We also prepare the S800 case and input 800W PSU for you to assemble them together to make a complete power supply.
Discount Time: 2021.11.5-2021.11.10 PST .
Because of dual current range (6A/12A), this price is even lower than RD6006P, so you can get the RD6012P with lower price when its performance is better than RD6006P, because when switch to 0-6A range, RD6012P can be used same as RD6006P.
Here are some important features about RD6012P:
  • Support 60V 12A maximum output
  • 5-digit resolution, accurate display
  • Dual current range:0-6A(0.0001A);0-12A(0.001A)
  • High efficiency: full output efficiency >90%
  • Low ripple: 20mV VPP output ripple typical
  • Optional display style(classic/detail display/curve style)
  • 15 colors can be chosen for displayed parameters
  • New setting interface, more user friendly
  • Optional output power limit, protect the device
  • Wild applied(phone repair/lab/factory/precision debugging)
  • 2.4 inch screen/PC software/APP control(RD6012PW only)/support firmware update/multiple protections/keypad control/keypad lock
  If you have any questions about RD6012P, you can contact us in the way below:
  1. Contact us on Aliexpress directly
  2. Contact my email:1749808860@qq.com or WhatsApp: +8615868147353 or WeChat: 15868147353
If you have any interest in USB tester or power supply, please contact me
this is my shop on Aliexpress: https://rdtech.aliexpress.com/store/923042
Edited by: RD tech on 11/05/2021 - 05:05
RD tech
RD tech's picture
Dual current range(12A/6A)
RD6012P supports dual current range,it is 5-digit display,you need big current, you choose 12A range and you can get 0.001A resolution, if you need low current with high accuracy, you can switch to 6A range, the resolution is 0.0001A, useful function: )
Tom E
Tom E's picture
Last seen: 3 hours 36 min ago
Looks great, but we need more amps! Like 40, but 30 may do.
RD tech
RD tech's picture
thank you so much for your support
but for now there is not plan for that , even it have big current , the price will be very expensive
Tom E
Tom E's picture
We need only 3-4V at 30 amps, so there's enough power, but I understand - cost on high amp bench power supplies is in a different realm.
Specs and the look are very impressive!
mattlward
mattlward's picture
Last seen: 5 hours 24 min ago
I am not getting pics above? Anyone else?
EDC rotation:
FW1A, LH351D 4000k (second favorite)
FW3A, LH351D 3500k
FW3A, SST20 FD2 4000k
FW3A, Nichia 4000k sw40 r9080 (favorite light!)
FW3A, Cree XP-L Hi 5A3
Emisar D4V2, SST20 4000k
raccoon city
raccoon city's picture
Last seen: 6 min 24 sec ago
I can see the pics.
They're Facebook pics, and the URLs are quite long.
mattlward
mattlward's picture
They opened in another browser! This is finally getting to the size that they are becoming more useful. I have been holding out for a little more power, my old HP bench unit is only 3A, but it is an honest 3A. It would be great to have say 20A in the 3.5 to 4V range, but that is not an option with budget minded supplies at this point. This one may finally get me over the hump. My HP is so old that I have replaced the caps 2 times in its lifetime and have had to rebuild part of the regulator circuit once. Next time it dies, might just be the end of it.
EDC rotation:
FW3A, LH351D 3500k
thefreeman
thefreeman's picture
Last seen: 2 hours 47 min ago
They have a 20A PSU but it’s the older design with a small screen and subpar interface, I use it regurarly to test my drivers.
They also have a 18A one with a bigger screen and more buttons but it’s significantly more expensive
RD tech
RD tech's picture
Tom E wrote:
We need only 3-4V at 30 amps, so there’s enough power, but I understand – cost on high amp bench power supplies is in a different realm.
thank you so much, I will consider that
icpart
Last seen: 9 hours 23 min ago
Why not to try to design dual power suplly with serial parallel capabilities like 30V 12A of channel?
RD tech
RD tech's picture
in the RD series power supply, we do not add that when we design it, in the next series, we will consider to add that
RD tech
RD tech's picture
20A should be the old DPS5020, yes, it is 1.44 inch screen and no keypad, 18A should be the RD6018 power supply, yes, it is 2.4 inch screen and keypad control, more user friendly, and it adds more function, so the price is higher than DPS5020
RD tech
RD tech's picture
raccoon city wrote:
I can see the pics.
They’re Facebook pics, and the URLs are quite long.
yes, blf cannot upload local picture, I can only use the facebook picture link
RD tech
RD tech's picture
15 colors, custom your unique display
Hello, RD6012P supports parameter color changing, if you like other color for the display, you can set it in the setting page, so that you can get a display which is more convenient for you to read
RD tech
RD tech's picture
3 display style can be chosed, swich as you like
RD6012P supports 3 display style(classic style/detail data style/curve style), you can switch the display style by pressing thearrow button, choose the one you need, it is very convenient and user friendly
RD tech
RD tech's picture
today is the last day for RD6012P promotion, and it will end at 11-10 PST, after that, though it is 11.11 promotion, the price will not be lower because our tradition is to release product at lowest price when it is released
https://aliexpress.com/item/1005003472332331.html
RD tech
RD tech's picture
there is already feedback for RD6012P(we sell them in China first for Public Test), this customer use 15 days to make a diy power supply,he adds 3.3V 5V 12V Four-way Adjustable module, Soldering Station, supports 100W PD fastcharge....very good https://aliexpress.com/item/1005003472332331.html
RD tech
RD tech's picture
hello, for our DC to DC power supply, if you want to use AC input. you need to use an AC to DC PSU to power on our device, and you need to be careful when choose the PSU, it is recommended to use switching power supply( no matter ours or other good quality brand),for converter or transformer, be careful because if your input AC voltage changes to a high value in short time, it will also output high voltage to damage our device, and you had better not to use electric bike charger or second hand PSU or modified PSU because their output are extramely unstable
Enderman
Enderman's picture
Last seen: 1 hour 58 min ago
I have the DPS6020 (20A) and it would be nice to have more current.
I would buy a 30 or 40A power supply, even if it has lower voltage.
I only use stuff below 30V anyways.
RD tech
RD tech's picture
thank you so much for your support , i can understand your request, I will consider , and tell our engineer
RD tech
RD tech's picture
RD6012P feedback
he might be late, but he always comes with his special metal panel
RD tech
RD tech's picture
There will be Black Friday Sale at the end of November, the discount will not be same like 11.11 sale, but it will still be lower than normal price, so if you miss the 11.11 sale, you can make orders for RD6012P at Black Friday Sale
RD tech
RD tech's picture
RD6012P feedback
good product and good performance(PS: if you use lower than 6A, you can choose the 0-6A range)
RD tech
RD tech's picture
Black Friday Sale will start from 25th and end at 29th, the discount will not be same like 11.11 sale, but it will still be lower than normal price, so if you miss the 11.11 sale, you can make orders at Black Friday Sale, and it is a good chanse to order RD6012P with lower price
 https://rdtech.aliexpress.com/store/923042/pages/promotion-20211129.html
RD tech
RD tech's picture
the first thing he did when received RD6012P is taking apart it and remake a new one
RD tech
RD tech's picture
for our RD series power supply, we pack them well, and the box is covered by plastic film, the device is well protected, and it is also a easy way to see if someone has opened it before you get the package.
