Is anyone else a budget shaver?
44 posts / 0 new
how crazy is this
Last seen: 2 hours 18 min ago
Was thinking of this today and wondering if anyone else really wants to get their money out of shaving cartridges or may have went back to double edge razor blades? Before the pandemic I would be into my beard by now but due to the desire for a good mask fit I am now year round clean shaven.
For years I used a double edge and clearly the blades were cheap but I never was very good with it. (If I ever find it will try again since I discovered Cremo — completely transformed my shaving experience and maybe I could make it work now.)
When I tried my first cartridge shaver (Sensor XL it think) it was just so much better! They kept improving them and improving them and they kept getting more blades, up to 4 or 5 now, and way more expensive. I got fed up with the expense and learned to take care of them. I don’t see it as much work. Look forward to hearing what you think. After every shave I dry it off with a towel and then rinse it with rubbing alcohol. Before the first use I blue jean strop it and do that maybe every 4 shaves or so — sometimes quite a few. Three months is typical now. Don’t remember the last time I got razor burn. Current cartridge is just past 3 months and I still get a BBS. Probably takes a bit more work than it used to but as long as my face isn’t getting irritated I’ll just keep using it until I feel like a change.
Probably a bit silly but on the other hand I probably save enough for a decent flashlight every year or two;-)
Edited by: how crazy is this on 11/04/2021 - 13:59
raccoon city
raccoon city's picture
Last seen: 4 hours 6 min ago
I use an inexpensive Norelco electric shaver.
(I don't like razors.)
Lightbringer
Lightbringer's picture
Last seen: 14 min 1 sec ago
I just buzz my face for the Greg House look.
If you’re talking about the teeny jars of “Cremo” (eucalyptusy smelling), I know what you mean. I use a dab of it daily as an unguent (forehead, cheeks, chin, neck) as a sort of moisturiser, especially in winter when it gets dry out.
raccoon city
That reminds me, I also use this beard trimmer made by Remington.
https://www.amazon.com/dp/B014TWNLGE
I use it at 5mm for my sideburns, and 1mm for everywhere else on my face.
If I feel like shaving, then I use my Norelco.
darosk
darosk's picture
Last seen: 22 hours 36 min ago
When the ‘Rona hit I started doing safety razors (the double-edged cheapo ones), and even lathering my own shaving cream. Had no experience with it prior. I started it mostly as a curiosity and a cheap hobby to learn a new skill so to speak. Had disastrous results initially, cut myself all over. Now I’m a little better with it, cuts are fewer and far between, gotta learn the angles and whatnot.
What struck was how much cheaper it was. It’s so cheap compared to the cartridge stuff I was using before. I got a 50+10 pack of Gilette’s safety razors on sale and it was like $2.25 (approximately, I’m converting from my local currency). I’ve been using VI-John shaving cream and it’s like 80cents for a large tube and has lasted me months.
Now, as far as the results… well lets just say the cartridge stuff is a lot easier to get nice results. With practice it’s gotten easier of course, but compared to the cartridge shavers it takes a bit more to get a real smooth job.
I’d heard about the alcohol and stropping maintenance for the cartridge razors, but never tried it. Maybe I will – once these blades run out.
My Lights (Updated: June 20, 2021)
Unheard
Unheard's picture
Last seen: 5 hours 19 min ago
Using straight razors since ca. 10 years now and never looked back. You need some stuff, but that will stay with you for the rest of your life.
Smile, you cannot kill them all.
how crazy is this
This is what I’m talking about. One of the very few things where, for me at least, their corporate slogan is spot on. “Astonishingly Superior”
https://www.target.com/p/cremo-men-s-shave-cream-6-fl-oz/-/A-16205561#ln...
xevious
xevious's picture
Last seen: 2 min 39 sec ago
I never liked wet shaving, because I wasn’t any good at it. But later on, I learned what I was doing wrong (or insufficiently) and I enjoy doing it from time to time. I know a guy that won’t use electric. He uses a safety razor most of the time but also uses cartridges. Did you know that some cartridges are able to be stropped? Yes, you can “freshen” them so that you’ll get more shaves out of them.
Given the cost of good soap and the blades, I find it cheaper to go electric. I invested in both Braun & Norelco shavers. They’re terrific. It’s all about technique. I find I can get a very close shave, almost as good as a blade. And if I exfoliate afterward, it feels like I did use a wet blade. The Braun Series 7 is a beast. It is one of the best Braun has made thus far. I’ve had mine for 8 years and the battery is still excellent. My Norelco 3D SensoTouch 1290x is still going strong after 9 years, charging up to 57 minutes (max was originally 60). I’ve changed the heads only 3 times since I’ve had them, keeping the last head as it’s still good. I bought the lesser 1280x shaver used, as a backup & travel shaver. Works just as well (same head). Some people get freaky about a used shaver, but they can be totally disinfected. Overall, very good investment. And the convenience of electric is magnificent. I’ve done full shaves in my car (cruising on the highway).
pennzy
pennzy's picture
Last seen: 5 min 19 sec ago
Haven’t shaved in decades except my neck and that’s too much.
arow55
Last seen: 1 hour 16 min ago
I’ve tried everything including straight razor last year just because and to learn to sharpen it. But all I use now are portable shavers powered by Eneloops.
dthrckt
dthrckt's picture
Last seen: 1 week 1 day ago
If you store the cartridge razor in mineral oil after cleaning they last even longer.
I shave my whole head once a week, clippers on whole thing, then cartridge on face only.
CollectEverything
CollectEverything's picture
Last seen: 19 hours 42 min ago
The naked blade seems like an accident waiting to happen though. What if someone comes along and bumps your elbow? What if you just woke up and are a little groggy?
Collection: TN42, TN40S, Catapult V6, SP36 BLF, sc700d, sc64c LE, D4V2 CuZn, D4V2 CuTi, D4V2 Al x2, KR4 Al x2
Wishlist: Acebeam K75, Zebralight sc600w mk IV plus, Convoy M3-C
Pip
Last seen: 2 hours 1 min ago
I quit shaving several years ago. It’s extra work for which there is no compensation. Now I just buzz my beard off with the clippers whenever I cut my hair. My wife likes a little facial hair. I’m not sure if she likes other forms of laziness or just that one.
Unheard
Unheard's picture
They’re not dangerous. Geometry is made for shaving, not killing. Every once or twice a year I have a small cut, but no scars thus far. One rule tho – if it falls down, let it fall.
puglife2
puglife2's picture
Last seen: 2 hours 10 min ago
i’m using this small clipper since 2013
CollectEverything
I’m not trying to say it’s an aSsAulT wEaPON. I just worry about accidents with a sharp blade. The idea is appealing to me otherwise because you aren’t throwing something away all the time.
arow55
A close shave is important if you wear A N95 mask for covid protection.
Dirty Water Guy
Dirty Water Guy's picture
Last seen: 13 hours 6 min ago
Been using tracII style, no pivot, no fancy since the 70’s, guss I’m stuck in a time warp. The newest blades offer nothing to me and I typically get 30 shaves/blade. At this price I get 8 years of shaves for $15. The more money I save on shaving = more $ for that flashlight I really might not need, but I gotta have
https://www.ebay.com/itm/294348142090?hash=item448884360a:g:lbcAAOSwPolh...
pennzy
pennzy's picture
That’s a great deal but I have never found a generic Trac II that was any good. My beard is coarse and even though I only shave my neck, I go through Trac IIs pretty fast. Do you think these are close to Trac IIs in quality?
Edit – BTW, they are only $11.98 at Amazon.
turkeydance
turkeydance's picture
Last seen: 2 days 58 min ago
yes.
there are lots of ways to save money shaving….here are some that worked for me:
1. as how crazy is this posted: rinsing and drying any blade will save it from corrosion, which is the #1 thing that ruins a sharp blade.
2. proper (and cheap) beard prep will help those older blades keep on keepin’ on.
3. cheap hair conditioner works as well as the expensive creams. for me, anyway.
carsknivesbeer
carsknivesbeer's picture
Last seen: 45 min 34 sec ago
Get yourself an old Gillette adjustable (Slim or Fatboy) and start on a low number. Unless you have a fairly wrinkled face (I mean that in the kindest way possible) there aren’t any problems that cannot be solved to get a good and pain free DE shave. Also as a bonus, they are the best blades to slice LEDs.
Lightbringer
That’s the brand, but not the ook I was referring to. This is listed as “beard cream”. Btfoom what it’s supposed to do, but it’s got good stuff in it, and doesn’t smell like a funeral parlor like some other products do.
I’ll use Gold Bond on my hands, more specifically knuckles, because otherwise they get too dry and literally split, and seems like a bunch of little paper-cuts. And a coupla big ones.
My hygrometer is already at 24% RH; at/below 20% it just stops reading and goes “LL”. Wheee. Hell, just petting my cat, I was feeling little shocks and hearing crackles, so no wonder he ran off after a while. And nope, I don’t have the heat cranked up, as it’s only a chilly 66° in this room.
So yeah, winters are pretty much a dry The Hell over here. I know how Ashy Larry feels…
Lightbringer
Hey, that’s how Hitler got his trademark look. Needed to shave his ‘stache to get his gas-mask to fit.
Strewth.
Unheard
Unheard's picture
Ah yes. I wish the straight razor would have been established in private households for that reason. It never happened at large scale and shaving was done mostly in the barber shop. The safety razor (I like those too) has, and later the cartridge system razors, which added plastic waste :-(. Don’t fear those small cuts. The way you hold it guarantees it cannot cause deep wounds, even when your kid bumps into you while shaving. You’re shaving with almost no pressure, at an angle that can be considered safe.
Omega_17
Last seen: 2 days 5 hours ago
I use one of these vintage T9 trimmer, they are excellent and super cheap. Just need to add an o-ring at the tail-cap for security.
xevious
xevious's picture
Have you ever thought about using an electric razor for the first pass or two, then follow with a wet shave to get that closeness you desire? I’d found that my greatest troubles with wet shaving have been long or thick whiskers. On a day when I want to do a wet shave, I found making an initial pass with my electric razor eases the path for the really fine cutting you get with wet shaving.
pennzy
pennzy's picture
I never had an electric shaver touch my beard but I never had a high end model to be fair.
CNCman
CNCman's picture
Last seen: 3 hours 1 min ago
I still use an electric shaver I purchased from the Goodwill 9 yrs ago for 10 bucks. Beer
Perception
Last seen: 1 day 5 hours ago
I use water and a safety razor to keep my beard trimmed up. It was irritating at first, but my skin got used to it quickly and I don’t notice anymore. I paid 10 bucks for a sampler pack of blades a few years back, and in another 5 or 6 years I may need to buy more blades. All in all, it probably only costs me a few cents a year to shave.
Rexlion
Last seen: 5 days 21 hours ago
I’ve always used an electric shaver. My Braun Activator 8595 is about 14 years old, and the silver finish is peeling in spots, but it’s still functioning well (I change the cutter block and foil once or twice per year).
== We save the planet from darkness ==
how crazy is this
I used to be able to find a Remmington shaving stick that was like a powder that you put on your face as a pre-shave. That was the only way I liked the electric. Got to hard to find so I went back to wet shaving.
Was considering going back but it seems to me that the foil and block is even more expensive than the cartriges.
