Hello
Can anyone tell me where I can buy, in the UK, a pair of snapring pliers with tips small enough to unscrew a convoy retaining ring from the driver pill?
I’ve scoured amazon but most of them don’t indicate tip size. Tried B&Q, they had nothing below about 2mm. Even just know what tip size I need would be handy, is 1mm small enough or does it need to be thinner?
Much thanks
You can try a lens ring spanner (example ) I know my example is from US Amazon, but maybe you can find something similar in the UK
I just use a small pair of needle nose pliers like these . They work with almost all my lights.
Just use the normal pliers for snapring, use the angle grinder to make the point shallower,that’s how I’ve done mine
If you have tweezers try them. If the ring is not to tight they will work.
Tweezers don’t work, they just bend. The rings are really right.
I have snap ring pliers, but find that needle nose pliers just work better most of time.
For retaining rings where the hole isn’t big enough I just drill it bigger with a pin vise drill.
I can’t find any needle nose pliers or snap ring pliers that have a small enough tip. Don’t have an angle grinder.
Do you have a pin vise drill? You can probably buy one from Amazon for $10.
There’s actually a tool that’s better than snap ring pliers for opening these. I don’t know what it’s called though. It looks like a bar with 2 parallel arms sticking out. One of the arms can be moved back and forth along the bar. The tip of each arm has the pins in it.
That sounds interesting, anyone know what it’s called?
I use a cheap set of bead pliers from a craft store. You can sharpen the tips if need be.
Could try this – Neewer® Professional Flat and Pointed Tips DSLR Camera Lens Spanner Wrench Repairing Opening Tool for Most Cameras https://www.amazon.co.uk/dp/B00J5F6O92/ref=cm_sw_r_cp_api_glt_fabc_CT4CB...
I just use a pair of round nose pliers that I’ve filed the ends thinner on
Here you go.
https://www.amazon.com/gp/aw/d/B00J5F73GA/ref=ox_sc_saved_image_1?smid=A...
I use a electrical staple. Ya know, used to staple house wiring. I just bend it to whatever I need and grab the staple with a pair of pliers.
"Everywhere I go, there I am"
Awesome thanks!
You’re over complicating it. Just cross over two small nails
Piercing The Darkness YouTube channel – https://www.youtube.com/c/PiercingTheDarkness
That’s what I’ve always recommended over here. And CRX did.
But I stopped telling that, for apparently people want to buy specific tools for it.
I use an SS nail and an awl that rests with the handle in the palm of my hand.
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
I just use an old pair of cheapo tweezers. Do the tweezers get twisted out of shape? Yes. They still do the trick though.
https://www.google.com/search?q=seger+pliers
Widely available.
Think of how stupid the average person is, and realize half of them are stupider than that. George Carlin
Anyone offended by my signature please fill Complaint Form. Thank you.
If a lot of people listen to Slayer, the world would be a better place to live" - Tommy Wiseau
I use bead pliers and tweezers.
https://fundrazr.com/osturaband
No affiliation, just a fan.
circlip / snap ring pliers. size A0.
https://budgetlightforum.com/comment/1744122#comment-1744122
