Test/review of JSC Energiya INR18650 3000mAh LITS-3 (Blue)
3 posts / 0 new
HKJ
HKJ's picture
Last seen: 7 hours 36 min ago
DSC_4750
Official specifications:
  • Nominal capacity: 3000mAh
  • Nominal voltage: 3.6V
  • Maximum discharge current: 2C (6A)
  • Charge voltage: 4.2V (Other specification say: Open voltage 4.1V).
  • End of discharge voltage: 2.5
  • Cycle life: 300 cycles to 60% (Other specification says: Service life 500 cycles).
JSC%20Energiya%20INR18650%203000mAh%20LITS-3%20(Blue)-info
This is a Russian manufactured 18650 cell with good capacity, but fairly low current capability.
DSC_4751 DSC_4752
DSC_4753
DSC_4754
JSC%20Energiya%20INR18650%203000mAh%20LITS-3%20(Blue)-Capacity
The cells match fairly well and can deliver the rated current, in my test I went significantly above that and the cells died (One a 15A the other at 20A).
JSC%20Energiya%20INR18650%203000mAh%20LITS-3%20(Blue)-Temp-7.0
JSC%20Energiya%20INR18650%203000mAh%20LITS-3%20(Blue)-Temp-10.0
JSC%20Energiya%20INR18650%203000mAh%20LITS-3%20(Blue)-Temp-15.0
JSC%20Energiya%20INR18650%203000mAh%20LITS-3%20(Blue)-CapacityTimeHours
JSC%20Energiya%20INR18650%203000mAh%20LITS-3%20(Blue)-Energy
JSC%20Energiya%20INR18650%203000mAh%20LITS-3%20(Blue)-Charge
Conclusion
The cells works nicely, but are not top of the line cells.
Notes and links
The batteries was supplied by a reader for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
Superstocker
Superstocker's picture
Last seen: 11 hours 45 min ago
Thanks HKJ! I appreciate all your hard work.
Barkuti
Barkuti's picture
Last seen: 3 days 17 hours ago
The figures of this cell look nice. It's great to see something else manufacturer wise, even if most folks here don't care much.
Overstated capacity as @#$% usual, though.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
The human mind, and its programming, is at the forefront of a particular battle of The Light vs evil dark forces. Nearly every human being on this beautiful planet “Earth” has some sort of negative mind programming in its mind. And you better take care of your mind programming, or someone else will in this wicked world.
Viruses DON'T cause diseases, they rather are a consequence of them. Read the book “Béchamp or Pasteur” by Ethel Hume for more information.
