Haukkeli's entry to 9th OldLumens challenge -modded S2+
24 posts / 0 new
Haukkeli
Last seen: 15 min 37 sec ago
I have been active in this forum for six months now. Few months ago there was some discussion about Convoy S2 and S2+ differences. There were some pictures that inspired me to try this build, which is building S2+ triple with 18500 tube using 18650 battery. So here it starts.
Haukkeli
First I ordered 18500 tube from Jaxmans Aliexpress store and host from Convoy Flashlight Store. Then I waited for a month.
When parts arrived they were not compatible. Jaxman uses older style threads and Convoy has square cut ones.
After asking from Simon, if he has older gray hosts (he doesn’t) I found that Kaidomain’s hosts are with metal button. So they have to be older ones.
Another month went by and parts arrived. I tried to put them together and Bingo! Threads were compatible.
Here can start the real build.
Haukkeli
First I filed half of the threads away from the pill. I also filed top of the pill flat so that I can use 20mm mcpcb.
This allowed me to screw the pill deeper and as a bonus I didn’t need spacer that you usually need with triple builds.
Next I drilled Center hole to the pill and filed it to get rid of the burring.
Haukkeli
I used H17Fx driver from Mountain Electronics. Here’s the first installation.
Haukkeli
I decided to use Samsung LH351D 5000K 90cri leds and dedome them. I have heard that dedoming makes them really nice.
First is the reflow process. I used some regular solder and sticky flux. Heating is achieved with soldering iron with copper plate on top of it.
Here they are ready
And after that dedoming with sharp blade and thin centering gasket
Haukkeli
Next I assembled the pill for the first time. I have found it easier to apply thermal paste after the soldering if you have separate pill.
Then I put Carclo’s narrow spot tir (10507?) on top of the mcpcb and 1mm thick AR coated lens from Kaidomain on top of the tir. It’s 0,6 mm thinner than the regular one for space savings. Next screwed it in the host. It goes quite deep.
No need for spacer
Firelight2
Firelight2's picture
Last seen: 2 hours 23 min ago
Good luck with your mod!
I tried something similar 5+ years ago. I concluded there wasn’t enough space for an 18650, though I was able to make an 18500 fit with the 18350 tube. For an 18650 version, I used the stock tube and tailcap, but shortened the head.
Haukkeli
After trying to assemble the light I found that the battery was still about 1mm too long. I dismantled everything and went to my workplace where I have acces to lathe. I turned the driver shelf so that the driver sits few millimetres deeper in the pill. I also added little solder blob on drivers brass pole, so that using flat top is easier. Here it is again in the host.
With this latest modification battery is flush with battery tube.
Haukkeli
Next I shortened the spring in the tailcap and added bypass. I used silver coated spring from Kaidomain.
Haukkeli
After assembling the tailcap the flashlight is finished and works as it intented. Here it is next to regular sized S2+
Notice how different the colouring is even though both are gray.
And of course mine has metal button that you can’t get from Simon anymore. Big Smile
If someone else wants to try this build I recommend ordering regular S2 pill from Kaidomain along with S2+ host. They Lego and S2’s pill is much shorter than S2+‘s. So it is easier that way, I think.
Scallywag
Scallywag's picture
Last seen: 8 hours 17 min ago
Looking forward to it. Something like this?
Haukkeli
Flashlight is finished. After receiving parts it took about 5 hours. Couldn’t have made it without turning the driver shelf deeper in the pill. It was a millimetre game.
Edit: after taking a look to the link you posted it was definately the same method I used. Only difference that I found is I wanted to add a lens on top of tir.
That was the 1mm too much that forced me to my workplace on my spare day to have access to a lathe. Big Smile
MtnDon
MtnDon's picture
Last seen: 49 min 3 sec ago
That was a lot of file work. Smile
MascaratumB
MascaratumB's picture
Last seen: 5 hours 33 min ago
Good work Wink
I did a similar stuff a while ago (https://budgetlightforum.com/comment/1741697#comment-1741697) but using a shorter pill, which makes the job easier to fit!
In any case you have a nice flashlight there Wink
Haukkeli
Seems like my idea wasn’t so unique. Smile
MascaratumB
Ideas don’t have to be unique: making them happen has Wink
And you did it Thumbs Up
Scallywag
Scallywag's picture
MascaratumB wrote:
Good work Wink
I knew it! Your thread was the one I remembered, but the link above is all I found when I searched. I just assumed I’d been mistaken.
Pip
Last seen: 6 hours 27 min ago
I would like to do a triple osram on a convoy for my dad, but thought the bezel would overlap the optic too much. You could potentially turn it out a little bigger in a lathe, but you would lose the anodizing there. Does the overlap from the bezel affect the beam much?
I love the convoy lights for anybody who isn’t an enthusiast. Simple UI, no parasitic drain, and dependable. My dad uses a blf a6 all the time. A similar light with triple osrams would be great for him.
Haukkeli
I don’t think it affects much. You could go the easy way and buy triple from Jaxman. That’s basically S2+ triple. Even parts are interchangeable. Then just swap emitters to your liking.
Pip
That’s a good idea, I don’t have any jaxman lights so I never even gave that a thought.
G0OSE
G0OSE's picture
Last seen: 12 hours 13 min ago
I love triples and they are fun to make as I’m sure you are finding out! looking very good so far for sure!
Skylight
Skylight's picture
Last seen: 28 sec ago
Well done! Cool This makes the S2+ considerably shorter.
The tint of dedomed LH351D is one of the best. It already happened to me that I turned two of them partially blue with slicing too low. Facepalm
Haukkeli
This has been my most carried light. Later on I have also changed lens to clear sapphire one for scratch resistance and tint improvement.
wcddesign
Last seen: 4 hours 45 min ago
I’m impressed Haukkeli. So many things done here that I would have no idea how to do… Yet Silly
