FREEME ✌ ASTROLUX® EC06 6*XHP50.2 16000lm 566m 3*21700 USB-C Flashlight Group Buy >>> $69.99
213 posts / 0 new
jimahi
Last seen: 1 hour 44 min ago
Code please. Thanks!
torchfanatic
Last seen: 1 hour 49 min ago
Interested!
Would also like to see how this would compare with the Q8 pro!
I like torches Smile
vonroyale
Last seen: 1 hour 42 min ago
Coupon please and thank you.
future11
Last seen: 17 min 41 sec ago
mojomoyu
Last seen: 4 days 9 hours ago
Interested
freeme
freeme's picture
Last seen: 5 hours 31 min ago
All replied.
1thedeals.comyoutubeAstroluxNealsgadgetsolight
vonroyale
Order placed.
CM2010
Last seen: 1 hour 53 min ago
Got mine today, thanks freeme.
freeme
freeme's picture
That was quick!
CM2010
freeme wrote:
That was quick!
Got lucky with the post.
CR888
Last seen: 1 month 1 week ago
Interested code pls Mr. Freeme
CR888
freeme
freeme's picture
Replied.
Tom E
Tom E's picture
Last seen: 14 min 36 sec ago
Mine is still stuck in transit, last update 4 days ago, so don't think it's in the US yet.
I have a 3 21700 flat top adapter ready-to-go for this light.
freeme - the flat top adapter is a great idea, Astrolux should really consider including it, or at least offering it.
texas shooter
Last seen: 8 hours 40 min ago
I’m kind of rolling the dice that Molicel P42’s will fit. They have a good projecting top but were too fat for the Amutorch DM70.
CM2010
They work fine that’s what I’ve used in mine.
vonroyale
Tom E wrote:
Mine is still stuck in transit, last update 4 days ago, so don’t think it’s in the US yet.
freeme – the flat top adapter is a great idea, Astrolux should really consider including it, or at least offering it.
Where did you pick that up?
Tom E
Tom E's picture
This is a pic from the Convoy 3X21A I bought, but it had several cracks so I asked Simon for 2 spare and he sent them to me.
freeme
freeme's picture
Tom E
Tom E's picture
My EC06's tracking says "arriving late" but does say it arrived in LA (other coast).
man of light
man of light's picture
Interested
Tom E
Tom E's picture
I posted over here on the driver design. It seems unique to me - 6 LED's, 3 sets of output circuits of FET+1's. I believe they are wired in parallel for input off the same pins from the processor though, so can't individually control them, but on the output side, they are independent. The MCU processor has a very limited # of I/O pins.
freeme
freeme's picture
Replied.
man of light wrote:
Interested
Tom E
Tom E's picture
The EC06 arrived at my local post office, though closed today. Should get it tomorrow smile
sandro
Last seen: 2 days 16 hours ago
Code please
Thanks freeme
freeme
freeme's picture
Awesome! cool
Tom E
Tom E's picture
Ok - took some pics, made some measurements. I'd say I'm usually disappointed with a first look at output, yea like 99% of the time. The best #'s I'll measure with a maukka calibration factor is almost always lower then the spec, with some rare exceptions.
 This EC06 though is utterly insane! I'm actually afraid to test it at 30 seconds because at 10 seconds, it's close to flesh damaging level, yet it's a fairly robust host, coning in at almost 100 g more than a Q8 at 501.5g for the EC06, Q8 at 409 g, and the bigger Convoy 3X21A at 577 g.
 First set of cells I tried were a brand new set of Vapcell T42's, supposed slightly better performance than 40T's and measured 28090 at turn on! Ouch! Yes, flesh scorching hot in just a few seconds.
Measured again without re-charging over 10 secs: 27755 at turn on, 25360 at 5 secs, 24660 at 10 secs. Lumens are with the maukka calib factor. My old calib factor got 12% higher lumens, so these #'s are on the conservative side, but make note this is not at 30 seconds.
Throw with a 2 sec pause, taken at 5 m: 127 kcd
So what makes this light so hot? Well, it comes stock with 22 or 20 AWG spring bypasses on the only 3 springs in the light at the batt- end of the 21700's, and direct brass ring contact on the batt+ side. Also there's a unique power design to the driver, 3 separate output channels, 3 pairs of LED wires -- that has to help. I'm still not sure I can explain this because the best turn on lumens I've seen from a single XHP50.2 3V light is 4500, though probably could have gotten more. If I could get 5000 with a top cell, then x6 for the EC06 puts it at 30K, but the EC06 has 2 LED's per cell, therefore it should not do as good a a single LED driven by a single 21700.
I looked closely at the battery tube end, and the tweaks they've got factory stock is many of the things I've done in mods to similar lights. Haven't looked in detail at the driver and head assembly yet, but I expect more of the same. I'm almost thinking these guys studied my mod posts, but of course I'm not the only one doing them, and mostly they are common sense anyway.
I'm not sure what A2 stock settings the firmware has, but the surface temp really got hot quick, and I haven't even gone into Advanced UI mode yet. Sure hope top of ramp and/or 2C is set for max turbo in the Simple UI... surprisedcool
Tom E
Tom E's picture
Couple more points:
  • the lens looks untreated. Either it's very good glass, AR coated but no noticeable tint, or if replaced with an AR, it will do about 5% better!
  • the beam looks decent enough to me, considering XHP50.2. For 6 LED's, of course you get the pedal effect on the outside of the flood
  • would like a SS bezel option, and of course color choices
  • like it has a tripod mount point
  • got a Convoy 3X21A flat top adapter to fit and work - just has to dremel/sand down the adapter about 1 mm in diameter to fit - now works excellent!
  • It does a little better in lumens then my MT03 TA with slight mods (triple XHP70.2), same length, smaller head diam then the MT03 but also throws better
  • amber/orange LED's in the switch come on sometimes, not sure, but think it's when the light gets hot - don't know what that's about. The standard green ones are top and bottom mounted, while the amber/orange ones are on the left and right sides
richbuff
Last seen: 1 week 4 days ago
 Thanks, Tom E, and everyone for your valuable input.
I'll take a code, and thank you, freeme!
Rev 22:15
Tom E
Tom E's picture
No prob! But I did find it has excessive parasitic drain with the switch LED on hi - 2500 uA. There's a 0.5 K ohm resistor (0402) in the path - probably should be much higher. Interesting  just the other day I found the Sofirn SP31 Pro also had excessive drain on the switch LED on hi of 1300 uA with a 1K 0402 resistor. I swapped that 1K for a 6.8K and now it does 276 uA on hi - much better.
 The SP31 Pro switch LED's were super bright, too bright, and so are these on the EC06.
So the stock draw is as follows:
  switch LED OFF: ~120 uA
  switch LED Low:  ~170 uA
  switch LED Hi:     ~2500 uA
Even 120 uA is a little high, but not bad. Typically it should be ~30 uA w/Anduril 2 on this type of driver.
For me I can swap the 0402 0.5 K resistor with about a 6.8K.
Wondering if Sofirn makes this light? Switch PCB has label on it which think it says Q8 Pro.
Koenigsegg1
Code please Thanks freeme
