FREEME ✌ ASTROLUX® EC06 6*XHP50.2 16000lm 566m 3*21700 USB-C Flashlight Group Buy >>> $69.99
213 posts / 0 new
TopDog
Last seen: 1 month 1 week ago
Order placed
Thank You Freeme
texas shooter
Last seen: 7 hours 58 min ago
I stated earlier that this light was grossly over driven on turbo. It’s also one of the lowest setting lights I have. I’ve got three dogs that sleep in different spots on the bedroom floor. This light ceiling bouncing on it’s lowest setting gives just enough light to tell where they are. It’s low is so low that I can directly look at the 6 LED’s at night. I can see each of the 4 sub LED’s in each LED.
torchfanatic
Last seen: 1 hour 6 min ago
What lumen output will my Samsung 40ts give?
What are the best batteries to get for maximum output?
Thanks
I like torches Smile
Tom E
Tom E's picture
Last seen: 3 days 2 hours ago
torchfanatic wrote:
What lumen output will my Samsung 40ts give? What are the best batteries to get for maximum output? Thanks
28K or so at start, 22-23K after 30 secs - about right. Tested T42's, P42A's, 30T's. 40T's and T42's should be about the same.
I'd stay with 40T's or T42's. Not much gain at all from 30T's. 30T though is still considered the best battery on the market for sheer output, though shorter runs.
Again, very short term high output - gets smokin hot.
Fedtro
Last seen: 1 hour 4 min ago
I have read at startup 28k Vapcell T42, 27k Samsung 40T, 26k Molicel P42A.
richbuff
Last seen: 1 week 4 days ago
It looks like my order on Nov. 27, five days ago, was too late to get a sample from the first production run; mine has to wait until Dec 21 to ship.
Any possibility that the second production run will be triple live gonzo, like the first run?
By the way, links to all the topic threads for this light, just for everyone's ready convenience:
https://budgetlightforum.com/node/79942 [Review] ASTROLUX EC06 Pop-can flashlight with 16,000 lumens, 566m beam distance, Type-C charging/discharging & Anduril II The_Flashaholic
https://budgetlightforum.com/node/79864 Astrolux EC06 - some pics & a beamshot d_t_a
https://budgetlightforum.com/node/79734 FREEME ✌ ASTROLUX® EC06 6*XHP50.2 16000lm 566m 3*21700 USB-C Flashlight Group Buy >>> $69.99 freeme
https://budgetlightforum.com/node/79996 Notice/Analysis Astrolux EC06 Vodak-Yarout
https://budgetlightforum.com/node/80003 EC06 Tear Down Review Tom E
Rev 22:15
torchfanatic
Thanks for the quick and helpful responses Tom and Fedtro!
Looks like I will buy one more Samsung 40t and I have messaged Simon via AE to purchase a 3×18a adapter!
Thanks
Majoroverkill
Majoroverkill's picture
Last seen: 3 days 13 hours ago
By the way, links to all the topic threads for this light, just for everyone’s ready convenience:
https://budgetlightforum.com/node/79864 Astrolux EC06 – some pics & a beamshot d_t_a
I’d like to know to. Mine won’t ship till the 21st of December as well. The only reason I ordered was because of the insane output, fingers crossed.
Doug S.
Tom E
Tom E's picture
Triple live gonzo? smile
It's interesting - the XHP50.2 3V has been out for quite some time, and I got a few lights using them, but never really tweaked them up, mostly leaving them stock, or they were triples, or some other odd setup. So I decided to mod up a couple and see what a single XHP50.2 3V, single cell light could do. I modded up the WT1M w/spring bypasses and better LED wire.
 So on a T42 it does 18.6 amps, 5210 lumens at start, 4550 lumens at 30 secs. So the EC06 results sound more reasonable now. Take 5210 x 6, result is 31260, so to get 28K on the EC06 is realistic, 1 cell and 1 FET per 2 LED's. The WT1M's FET is probably not the best either, pretty decent though.
Westie
Westie's picture
Last seen: 5 hours 18 min ago
What cells work without an adapter?
Where could I get the battery adapter?
Could I use neodymium magnets or just soder a piece of brass on top to make it a button top?
Does someone have a link to a flashlight handle that fits?
Also, could I get a code, please?
Fedtro
Westie wrote:
What cells work without an adapter? Where could I get the battery adapter? Could I use neodymium magnets or just soder a piece of brass on top to make it a button top? Does someone have a link to a flashlight handle that fits? Also, could I get a code, please?
You cannot use a magnet or even a piece of brass because if they come into contact with each other, everything will burn! You have to use the Convoy 3x21A flashlight adapter, write a private message to Simon Mao and ask him if he can send it to you, he was very kind to me and sent me 10 by paying through his shop in AliExpress. Or you have to create button top batteries starting from the flat tops and you have to use a 21mm PCB board that you always find on Simon Mao's AliExpress store, fix them with a soldering point and protect them with a shrink film like I did. The choice is yours...
Majoroverkill
Others are using the P42A cells. I just ordered a set for my EC06. The tops stick out just enough to make contact. CM2010 uses them and said they work fine.
Doug S.
Westie
Westie's picture
Fedtro wrote:
You cannot use a magnet or even a piece of brass because if they come into contact with each other, everything will burn! You have to use the Convoy 3×21A flashlight adapter, write a private message to Simon Mao and ask him if he can send it to you, he was very kind to me and sent me 10 by paying through his shop in AliExpress. Or you have to create button top batteries starting from the flat tops and you have to use a 21mm PCB board that you always find on Simon Mao’s AliExpress store, fix them with a soldering point and protect them with a shrink film like I did. The choice is yours…
Why would a soldered piece of brass similar in size to a button top be bad? It’s the same thing as the PCB adapter you mentioned.
Did you remove the original wrap or you just put it on top of the original one? Does it affect the performance?
I found Simons profile and I’ll contact him. Thanks.
But those are not the best performers, right?
I’ve seen people mentioning Vapcell,30T and 40T as the best performers.
frastad
Last seen: 1 hour 47 min ago
I was sceptical to the “soldering” solution and tested it (with 18650 cells but this shouldn’t matter).
- I used an 60 watts iron
- I melted the solder (to have a drop on top of the iron)
- I placed the iron with the drop on top of the cell and it floated there within seconds
- after cooling down I used a sandpaper so get rid of the “sharp tip” of solder
PXL-20211119-k
For me it worked out perfectly.
They may not win a design award but they do a good job in a Sofirn SP36 now.
Plasmatoast
Last seen: 5 hours 40 min ago
A vapcell 40t is 4000mah and 30a
A molicel p42 is 4200mah and 45a.
vonroyale
Last seen: 59 min 29 sec ago
All flat top batteries I’ve used worked fine without an adapter. 40T and P42A, I know you can’t use the Yellow Vapcell because the positive sits below the body of the battery.
beam0
beam0's picture
Last seen: 2 days 19 hours ago
Please send me the code, thank you.
Just got onto this light, bummer I already missed the first production run. Gotta start paying more attention around here!
Also… No tripod mount Flat Stare
Majoroverkill
Best performers? Are you looking for the longest run times or max output? In a torch like the EC06 able to put out so much light it would be hard to tell the difference between 26k or 28k with just the naked eye. Between the 40T 30T P42A and the Vapcell T42 the difference is so slight that your best bet would be to get the cells you like. I own all these cells and find myself always using the 40T’s. They are less expensive then the vapecells. The reason I chose the P42A’s because they work, so I don’t have to purchase the battery plate from Simon and wait another month or so.
Doug S.
st0ckmod
Last seen: 1 month 2 hours ago
Is the group buy still going on? If so, I’d appreciate a code!
Plasmatoast
Same here, interested
I held out long enough. Need to use those black Friday 40t cells for something !
Tom E
Tom E's picture
smile I'm trying to buy a bunch of Vapcell T42's via alibaba. The place I'm dealing with quoted me a great price for qty 20, shipped, but we'll see - deal isn't done yet and wondering if she got the qty confused because it's about 1/2 the price I'd expect, even for wholesale cost.
Vodak-Yarout
Vodak-Yarout's picture
Last seen: 17 min 40 sec ago
This light have tripod mount to oppose ON/OFF button USB-C port is in between
Plasmatoast
Tom E wrote:
smile I’m trying to buy a bunch of Vapcell T42’s via alibaba. The place I’m dealing with quoted me a great price for qty 20, shipped, but we’ll see – deal isn’t done yet and wondering if she got the qty confused because it’s about 1/2 the price I’d expect, even for wholesale cost.
How cheap? I saw what ends up as 10$ ea when you buy 10 but lionwholesale has them for 7.50ish ea
Tom E
Tom E's picture
She quoted $55 US w/shipping for 20 - must be something wrong, I figured double that.
Basser28
Basser28's picture
Last seen: 1 month 3 days ago
Interested
Plasmatoast
Tom E wrote:
She quoted $55 US w/shipping for 20 – must be something wrong, I figured double that.
If they’re legit, and it’s not some sort of communication issue, that would be a great deal !
beam0
beam0's picture
Tom E wrote:
28090 at turn on Yes, flesh scorching hot in just a few seconds.
Measured again without re-charging over 10 secs: 27755 at turn on, 25360 at 5 secs, 24660 at 10 secs. Lumens are with the maukka calib factor.
Wow, yes very unusual to see this (or any light) underrated by more than 10,000 lumens! I suppose it being direct drive makes this possible.
Surprising that Astrolux would underrate the advertised output by that much.
Your measurements combined with the GB price are steering me towards this light over the Acebeam X45 (4*XHP70.2 / 18000lm)
Looking forward to seeing someone else’s measurements to confirm this.
Bungle88
Bungle88's picture
Last seen: 4 days 4 hours ago
Interested Thumbs Up
CR888
I just wish I could get this light in something warmer than 6500k, I know XHP50.2 emitters are available in 5700k but it’s not available in the EC06.
CR888
liteupmynite
Interested
