The Mark 3 turbo definitely threw better than the standard Mark 3 but this Mark 3 with a W1 is probably one of the coolest mods I’ve ever done it actually is a pocket thrower it throws so much further than I could have ever hoped.
I actually used the stock centering ring for the xpl hi and I had a lot of issues trying to keep it centered and then I ended up just using a couple dots of super glue because once the reflector is tight down on it it’s not going to move anymore and so those little dots of super glue held it in place long enough to tighten it and it seems to work pretty good there is a bit of a Halo but not enough to render it not worth it I’ll probably try and find the right centering ring later on and make something
