Unpleasant surprises
62 posts / 0 new
tekwyzrd
tekwyzrd's picture
Last seen: 2 days 15 hours ago
Recently I’ve been checking items off the to do list. Currently stuck at oil change. 95 Saturn wagon, not quite 80k miles. I’ve done most of the maintenance on it and until now I’ve never encountered a problem I couldn’t solve. Oil change once a year with full synthetic oil. I always hand tighten the filter.
So why won’t this filter come off?
Strap wrench, jaw type wrench, chain wrench, pipe wrench. They all slip and filter won’t budge. Yes, I’m trying to turn it counterclockwise. I don’t want to resort to a torch. Suggestions?
Nothing travels faster than the speed of light with the possible exception of bad news, which obeys its own special laws. – Douglas Adams
Oli
Last seen: 3 days 18 hours ago
Hammer a large screwdriver or other 10-12 inch long metal object into in from the side a good distace and then turn. If you don’t have a sharp enough screwdriver you can pre-drill a hole to get it started.
You can't compare the big flashlight in the sky to the little flashlight in your hand.
Bort
Bort's picture
Last seen: 3 hours 59 min ago
Go clockwise to loosen it. Counter intuitive but it often works.
You can also refill with oil, drive then remove filter, it will be very hot but that will also help loosen it. But that is an extra cost of extra oil you will waste (and mess unless you drain the fresh oil).
Some recommend stabbing it with a screwdriver, though i would be afraid of an engine projection being damaged or the can collapsing then you have to pick apart pieces.
You can also try a penetrating oil or WD40.
You can use a hammer drill if you have some attachment or the cap had a head that you can put a sprocket on, the pulses often loosen stuck bolts. Start at low power.
The Journal of Alternative Facts TM
"It is critical that there is a credible academic source for the growing and important discipline of alternative facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists"
jeff51
jeff51's picture
Last seen: 3 hours 41 min ago
The time I tried the stab with screwdriver, the metal ended up ripping apart and I was worse off.
The getting it hot might work.
I had success by gluing two strips of 120(?) grit sandpaper back to back and using that under a strap wrench. After I cleaned the strap with some acetone or some sort of de-greaser.
The grit dug into the filter and the glue kept the two pieces from slipping on each other.
There are also oil filter wrenches/sockets that have a section that fits over the knurled end of the filter – but that costs money.
Goo Luck,
Jeff
Oli
The screwdriver probably doesn’t have to be all that long. It’s been a lot of years since I’ve done it and it turned very easy. I think I put a hole in the bottom first to get the oil out of the way.
Oli
I don’t think I’d bother with a drill. Just Hammer a good size nail into it for a starter hole for the screwdriver. Just do it near the cap but on the side where the can is stronger. But if you end up with a dent in it plenty of your other wrenches will probably work.
cohoer
Last seen: 2 hours 56 min ago
Iffn you have enough clearance to grab and turn then this type wrench finally got the filter off my ride-on mower.
jeff51
jeff51's picture
You can often borrow nifty tools at auto parts stores.
You might check with the counter folk to see what they recommend.
Oli
Yes the proper tool is always best. But the hammer and the screwdriver will be done in 30 seconds. Then you can buy the proper tool at your convenience for the next time.
Pip
Last seen: 1 hour 55 min ago
Scrap the car out. Melt it down and make a new car. You have to send a message to all the other cars that this sort of behavior wont be tolerated.
Kidding of course. I would try a piece of soft rubber under the strap wrench. The screwdriver route usually works but the cost of failure is high.
NeutralFan
NeutralFan's picture
Last seen: 1 day 19 hours ago
Maybe time to take it to an oil change place and let them figure it out?
I’ve always changed the oil myself on all my cars and every once and awhile the filter will be a pain. But a strap wrench will take care of it. Not sure what’s going on with yours.
I’d rather use my flashlight around the house than turn on the lights.
SIGShooter
SIGShooter's picture
Last seen: 37 min 40 sec ago
Take it to a place like Jiffy Lube and have them change the oil this one time.
The times in the past when I had oil filters that didn’t want to come off the sandpaper trick worked fine. Except for one time and rather than driving a screwdriver or nail through the filter I had Jiffy Lube deal with it Party
Did you lube the filter gasket before screwing it in the last time? That can cause the filter to stick and be difficult to remove.
how crazy is this
Last seen: 24 min 29 sec ago
My fave tool for an oil filter! Just happened to break my filter wrench one day and the neighbor borrowed my his. Had to get one of my own. One of the best tools I ever bought.
Hammerman
Last seen: 2 weeks 2 days ago
Swap out the motor
 I’d listen to Oli . Anyone who has the word oil in his name must know about such things .
Paying $22 to have someone else change the oil just sounds like a brilliant solution.
Superstocker
Superstocker's picture
Last seen: 1 day 2 hours ago
I’m sorry you are having trouble. Such things happen to all of us but they can be frustrating. I use these “wrench caps” and they have been awesome. I got mine from autozone, I think. This should get the idea across though. No idea how good the harbor freight ones are though. They come in different sizes and make things way easier for hard to reach filters or ones that are stuck.
https://www.harborfreight.com/oil-filter-wrench-end-cap-set-6-pc-56893.h...
Oli
Just to be clear, I have the 9 in channellock oil filter pliers. I haven’t used them in the last 12 years because I have not needed them. Channellock also makes a 12 and a 15.5 in oil filter pliers. And plenty of other companies make them in 9 to 12 inches. But if you’re stuck and you don’t have an extra vehicle or you have got to get it done to drive to work the next day, then the screwdriver will get it off. I changed the oil in our three vehicles yesterday so I won’t have to do it during the winter. And I have never paid to have my oil changed. I do not enjoy doing it but I want to know it’s done right. The last used vehicle that I bought had a stripped oil drain bolt. It was not leaking but when I went to change the oil it was extremely tight and then it just spun and did not turn out. I had to clamp on with the 10-in vise grips hanging straight down and pull down as I was turning to get it to start catching what little threads were left. Apparently Ford intentionally makes the threads on the bolt softer than the threads in the pan so when some knucklehead over tightens things you can just buy a $5 plug. I’m sure many oil change places get the job done MOST of the time without issues.
tekwyzrd
tekwyzrd's picture
Thanks. Already tried that.
tekwyzrd
tekwyzrd's picture
That’s one of the tools I tried. No good. I’ll post a photo of tools tried later.
tekwyzrd
tekwyzrd's picture
It’s on the driveway sitting on a jack and stand, wheel and covers removed.
kennybobby
kennybobby's picture
Last seen: 6 hours 21 min ago
It sounds like you have tried all the usual tools and tricks, and probably have a big oily mess with no option to take it anywhere.
The threads are likely galled or cold-welded from galvanic corrosion of dissimilar metals.
i don’t know if the flange is accessible, but i would be thinking of using a chisel and hammer to tap on the nut flange in the CCW direction, or an air impact hammer if you have that equipment. Anything to get some vibration into the thread joint to break it loose.
Good luck that is a tough situation.
Now i used to think that i was cool,
drivin' around on fossil fuel,
until i saw what i was doin',
was drivin' down the road to ruin. --JT
Oli
Also get some pictures of what the filter currently looks like. If it’s really damaged at this point I would go and buy another identical one and cut it in half so you can see exactly where the structure is left inside. That way you know what you can grab with what tools. Depending on access. Or cut more away to get at the base plate once you know what the base plate looks like. Again room and access are going to dictate the next moves.
Pip
If you get to the base plate you can probably stick a screwdriver in one of the holes and use a hammer to drive it around. I hope I never get to that point on an oil filter lol.
If you have a 3d printer you could design a tool to fit in all the oil holes around the center and put a wrench on it.
captainkirk
Last seen: 6 min 17 sec ago
I am afraid we are all missing the important question here: “95 Saturn wagon, not quite 80k miles.”. What? How is that possible?
Anyway, best of luck with the oil filter, I have nothing to add over what the others have already said.
This space for let.
pennzy
pennzy's picture
Last seen: 11 min 15 sec ago
I stopped changing my own oil when the price of oil went way up. My local garage does it for about $10 more than the cost of filter and 5 quarts of oil plus he will grease any odd fittings for me. A large pair of pump pliers should get your stuck filter off if you can get them in there and have room to turn.
Oli
https://www.harborfreight.com/locking-oil-filter-wrench-63696.html Is there room to get this in near the base plate? I looked at one video of that vehicle and it is showing a view from underneath but also talking about removing the tire and getting at it in that direction. Are you working from the wheel well or underneath or both? The view wasn’t that great from underneath.
slmjim
slmjim's picture
Last seen: 2 hours 40 min ago
A coil spring filter wrench grips tighter as more torque is applied to the hex head.  It won't collapse the can.  Indispensable when swing area around the filter is limited and access can only be had from the end of the filter.  There are two sizes.  Link below is just for example, as I cannot ascertain quality to recommend this particular item.
https://www.ebay.com/p/15017011598
slmjim
Smile! It makes others wonder what you've been up to.
Time is more valuable than money.
You can get more money, but you cannot get more time.
puglife2
puglife2's picture
Last seen: 2 hours 25 min ago
Use this next time :
tekwyzrd
tekwyzrd's picture
Both.
When I go out there I’ll take a photo. Next try is a filter socket. The filter is still mostly solid with only minor dents and two nice clean holes with no tearing of the metal.
When I do get the filter off it will never be a problem again. I have a dual filter relocation kit that will make filter removal much easier and avoid oil in the filter fron draining on the rubber boot.
Sirstinky
Last seen: 53 min 36 sec ago
!{width:50%}https://i.imgur.com/gYnSh3o.jpg!
I do not recommend Fram filters. The grip is nice, but cut one open and compared it to a better brand and you’ll see why.
Get Wix, Puralator, Bosch
puglife2
puglife2's picture
I hate my car so i’ll stick with Fram but thx anyway Thumbs Up
Sirstinky
Big Smile [/quote]
