Lumintop Ant Man (14500 LEP flashlight)
76 posts / 0 new
Firelight2
Firelight2's picture
Last seen: 2 min 24 sec ago
How easy is it to swap the driver for something higher powered?
djozz
djozz's picture
Last seen: 42 min 27 sec ago
The driver seems glued: it is not retained by anything visible, and some light prying does not make it move.
SKV89
Last seen: 3 days 3 hours ago
Such a great form factor ruined by a shitty driver. Thanks for the review!
Firelight2
Is the bezel removable?
If there are exposed driver wires under the bezel, perhaps you can tap the driver out from the front. For LED flashlights I typically use a narrow metal pick or a round wooden toothpick. Press it through a wire hole to the top of the driver, feel around to try to make sure the tip isn’t touching anything important, then lightly hammer the back of the pick with the side of a pliers. That’s usually enough to break any glue.
My biggest concern with replacing the driver is not getting the stock driver out. Rather it’s avoiding burning up the laser with a new driver. I don’t know enough about lasers to know what they can and cannot take.
JaredM
JaredM's picture
Last seen: 16 min 16 sec ago
I have a feeling this light has a thread in pill assembly.
ChibiM
ChibiM's picture
Last seen: 13 hours 23 min ago
I have a few images in my review in case you're interested: https://1lumen.com/review/lumintop-ant-man/
JaredM
JaredM's picture
Thanks Marco. It does kind of look like the copper pill as seen in the astrolux lights, no? Maybe smaller?
Firelight2
I’m not so sure. The driver in the bottom of the head is not in a pill. It appears to be press-fit or glued in place.
There is what could be a small copper pill visible inside the top of the light. It could be a small pill holding the laser module, but not the driver. Or it might just a retaining ring holding an internal lens over the phosphor.
Lumen9000
Lumen9000's picture
Last seen: 8 hours 42 min ago
ChibiM wrote:
I have a few images in my review in case you’re interested: https://1lumen.com/review/lumintop-ant-man/
Great review! Let’s hope lumintop reaches out and addresses the problems you found!
djozz
djozz's picture
The LEP module is a cilinder that looks like threaded in place from the battery side. There is probably two wires coming out of the module that are soldered onto the driver, and the driver is then glued in place. To access the module you need to remove the driver. There is no holes from the front that can get you the option to poke with something. There are two small holes in the driver though, you may use that for prying but with the risk to ruin something on the driver.
id30209
id30209's picture
Last seen: 7 hours 16 min ago
So i can confirm that when Ant goes off, battery is at 3.2V (that is when i noticed it’s off) and pulling 23mA.
Recharching battery now and i’ll try again what are Amps when fully loaded
WTB Titanium 4sevens 2xAA tube
ChibiM
ChibiM's picture
Thanks.. that's still lower than my 100+mA when it turns off, although still quite high for parasitic drain.
Curious how deep it will discharge if you let it sit Wink
jon_slider
jon_slider's picture
Last seen: 5 hours 46 min ago
wonder if a protected battery could prevent overdischarge
until a better driver is found
id30209
id30209's picture
jon_slider wrote:
ChibiM wrote:
Curious how deep it will discharge if you let it sit ;)
wonder if a protected battery could prevent overdischarge until a better driver is found
Hi Jonathan,
I think it was designed to be used with their protected 14500 in mind. I think it should work well with it.
jon_slider
good to know,
all the test reports were unprotected high drain flat tops, I think
still concerned that the parasitic drain is excessive.. and hope for an improved driver
atm it seems to me that the GT Nano w 10440 tube, might be the better thrower option.. better beam, more reach, less money
