Easy way for button top battery
8 posts / 0 new
Fedtro
Last seen: 1 day 19 min ago
Hello everyone, since buying 21700 button top batteries such as Samsung 40T or 30T or Molicel P42A or Vapcell T42 on the market is increasingly difficult because they are not easy to find, I decided to make them at home using a 21mm MCPCB. that Simon Mao sells in his AliExpress shop at the following link:
https://a.aliexpress.com/_uAX8yG
I will fix the PCB board on the flat top battery head with a transparent shrink film, taking care to leave the upper part uncovered that will touch the head of the flashlight.
Since I am not a technician I ask all BLF members if my idea could be a good one. Thank you.
YuvalS
YuvalS's picture
Last seen: 4 hours 20 min ago
It seems a bit not stable.
If it tilts the contact is not best.
Consider fill the gap or solder it in place.
Also make sure it is not too high for your light
My FW repository
My BLF/OL contest entries: 7th 8th 9th
Fedtro
Thanks so much for the advice, I'll do as you suggest and fill the void with an insulator ...
chops728
Last seen: 1 hour 24 min ago
If you can Solder —Just Solder Blob the top of the cell —- Works great ( No adapter needed )
Fedtro
chops728 wrote:
If you can Solder --Just Solder Blob the top of the cell --- Works great ( No adapter needed )
I did not want to solder it because maybe one day recover the PCB boards maybe when the battery starts to decay as performance but I will also follow this advice and I will weld some to try.
Thanks 1000.
chops728
If you have a hard time making the solder blob big enough — I’ve used a piece of balled up copper wire —just fill it full of solder
lampliter
lampliter's picture
Last seen: 50 min 58 sec ago
Use a magnet.
magnet
When you're up to your ass in alligators; it's hard to remember your original intention was to drain the swamp.
jeff51
jeff51's picture
Last seen: 3 days 15 hours ago
Magnets work well.
As long as the battery compartment does not apply any sideways action when closing.
For example the Q8 or the SP36
All the Best,
Jeff
