[Review] - Fenix HM50R v2.0 - Headlamp EDC 700 lumen 16340 TypeC - by Lock
1 post / 0 new
lock
lock's picture
Last seen: 22 hours 6 min ago
Hello everyone, with this short review today we will see one of the latest Fenix flashlights: we will talk about the Fenix HM50R v2small angular frontal light equipped with red auxiliary led.
The flashlight was supplied by Fenix specifically for review.
Here you can find the link of the parent company and here the link of the product
Immagine
Immagine
Immagine
Immagine
Packaging and content
The Fenix HM50R v2.0 arrives in a colored cardboard box with all the main features of the product imprinted on it. The equipment includes:
• HM50R V2.0 torch
• Elastic band
• 700mAh 16340 Fenix battery
• USB Type-C charging cable
• Spare O-Ring
• User manual
• Warranty Card
Immagine
Immagine
Immagine
Immagine
Immagine
Main features
• Led CREE XP-G3 S4
• Max output: 700 lumen
• Max brightness: 3350cd
• TIR Lens
• Auxiliary LED: Red
• Battery Included: Fenix 700mAh Rechargeable Battery (ARB-L16-700P)
• Length: 64 mm
• Head Diameter: 22 mm
• Body Diameter: 19 mm
• Weight: 30g (only light), 49g (with battery), 78g(with battery and headband)
• Waterproof IP68
• Impact Resistance: 2m
Output Levels and Runtime
The Fenix HM50R v2.0 has 4 output levels for the main LED and two for the auxiliary one
Turbo: 700 lm (measured 680 lm) – 1h
High: 400 lm (measured 410 lm) – 3h
Med: 130 lm (measured 140 lm) – 8h
Low: 30 lm (measured 30 lm) – 42h
Red Light: 5 lm (measured 5 lm) – 60h
Red Flash: 5 lm (measured - lm) – 120h
Immagine
Below the runtime schemes for the Turbo, High and Med levels
Immagine
Immagine
Immagine
Immagine
Il corpo ed i materiali
The Fenix HM50R v2.0 is a small 700 lumen headlamp that is very light and comfortable to wear: ideal for short walks or jogging. Even with sudden movements thanks to the quality of the band and the particularly low weight, the flashlight will always remain firmly and in position on the head. A silicone strip further increases the grip.
Immagine
Immagine
Immagine
Immagine
Immagine
Immagine
Immagine
Immagine
The flashlight is attached to the elastic band thanks to its belt clip. It fits perfectly and firmly. The system is simple and functional and allows you to quickly remove the flashlight from the elastic band if, for example, we need to use it in the hand or attached to some clothes. In fact, just press a tab and pull the flashlight away.
Immagine
Immagine
Immagine
Immagine
Immagine
Immagine
Immagine
Immagine
The belt clip is quite thin but also very sturdy. Detaching and reattaching it to the torch is really a feat.
Immagine
Immagine
On the head, laterally, there is the Type-C fast charging interface, well protected by a thick rubber cap.
Immagine
Immagine
Immagine
Bundled with the flashlight comes a 700mAh Fenix branded 16340 cell.
Immagine
Immagine
Immagine
The switch, placed on the head of the flashlight, is electronic, rubberized, not protruding, very large and easily operated.
Immagine
Immagine
Immagine
Immagine
The lens is TIR. The bezel is bronze in color and recalls the color of the switch bezel ring
Immagine
Immagine
Immagine
Immagine
Immagine
The tailcap is flat so tailstanding is allowed, moreover it contains a powerful neodymium magnet that allows the torch to be attached to any ferromagnetic surface both in a vertical and horizontal position. A slight knurling made by vertical milling increases the grip for opening the battery compartment.
Immagine
Immagine
Immagine
The overall build quality is excellent. The feeling in the hand is of absolute solidity and robustness. The tiny size makes this flashlight extremely portable in your pocket or fanny pack.
Immagine
Immagine
Immagine
Immagine
The threads are anodized
Immagine
Immagine
The anodizing is done well as is the lettering
Immagine
Immagine
Immagine
The color is cool with some imperceptible chromatic variations on slightly warmer shades in the center of the beam.
The beam is wide and flood with a slightly brighter central part that gradually fades onto the spill.
Immagine
The red auxiliary LED provides an output of only 5 lumens, which can be used mostly for very short distances, for example for reading.
Immagine
Immagine
Immagine
Immagine
Following are some shots in the dark
Immagine
Immagine
Immagine
Immagine
Immagine
Immagine
Immagine
Immagine
Immagine
Conclusioni
Pro:
  • Small and light
  • Tailcap magnet
  • Red auxiliary LED
  • TypeC quick charge
  • Good adjustment
  • Quick and easy attachment / release system
  • Wide and convenient switch to activate
Cons:
  • There are no special levels for the main LED: the Beacon for example I find it very useful when running on the street in the dark to get noticed even from a distance
  • Red auxiliary LED has a maximum output of only 5 lm, I would have liked the presence of an additional level perhaps of 15-20lm
Excellent flashlight to use for short night outings, and given its weight and small size, it is also ideal for sports such as jogging, etc.
Thanks for reading...XD
