As far as i can tell every other function works as it should. Including the stepped ramping. Since stepped ramping works i can only assume this is a firmware issue…???
I know it’s a long shot but any idea if this is fixable through the ui menu? If I need to remove the driver then too bad, i’m not pulling apart this light :person_facepalming:
I got it! The “hard reset” is doing the reset via removing the tail instead of the 13 clicks right? Either way, I did the tail reset and it seems to have fixed the problem. Thanks pc_light, I wouldn’t have tried that if you hadn’t suggested it
