LEP + LED flashlight: Lumintop Thor Pro [discussion + review]
79 posts / 0 new
JaredM
JaredM's picture
Last seen: 28 min 15 sec ago
Voltage sag, not Vf is the number to use in the ohms law equation. 4.15-3.4= ~.75 @ ~32A >> ~~23.5 mohm
Another error is the parallel resistance of the cells. Divide not multiply. 15mohm/4 = 3.5 mohm
So very roughly, 20mohm is circuit R
https://fundrazr.com/osturaband
No affiliation, just a fan.
JaredM
JaredM's picture
Does a magnet stick to the springs?
dave1010
dave1010's picture
Last seen: 8 min ago
Thanks! That makes sense.
dave1010
dave1010's picture
No, not magnetic.
Here’s a picture of them
Plasmaskin
Last seen: 13 hours 32 min ago
This looks like an awesome light but with two separate light sources, I would expect to control them using two separate switches. Going through multiple click hoops to get what you want seems really cumbersome. The Fenix LR40R got it right in this regard.
Lumen9000
Lumen9000's picture
Last seen: 9 hours 45 min ago
I think anduril2 works great, without more buttons.
dave1010
dave1010's picture
2 independent switches would help in some ways but hinder in others. For example going to turbo on both channels would require 2 double clicks.
The Thor Pro UI is good but there’s not a good way to jump to turbo on both channels quickly if you’re just using the LEDs.
Ideally the UI would let you have the LEDs on low or medium then quickly switch to LED+LEP on turbo for a bit, then back to just LED.
MOVE-EVO
MOVE-EVO's picture
Last seen: 14 hours 58 min ago
LUMINTOP has a troublesome UI, so I hope it will be a simple and effective UI.
dave1010
dave1010's picture
There’s a video of the prototype’s UI in the second post, if you missed it.
I have their D1, which uses their own hold-to-turn-off UI. The driver is good but I’m not keen on the UI. I also have their tint-ramping FW4X, which I didn’t really like the UI of as it had a separate config mode to change the channels. I was concerned that they’d use the FW4X’s UI here but they haven’t.
The final version may be different though.
dave1010
dave1010's picture
Here's the Thor Pro prototype's turbo output visualised against the Lumintop GT70, which has similar lumen and candela numbers but is a few times the size and weight:
Please excuse my crude drawing!
Pöbel
Pöbel's picture
Last seen: 55 min 42 sec ago
That is actually a very good way of illustrating beam characteristics!
MOVE-EVO
MOVE-EVO's picture
Mr.dave1010 thank you!!
fonfan
Last seen: 9 hours 26 min ago
Independent channels would much better.
WANTED Zebralights. My flashlights
Flashy Mike
Flashy Mike's picture
Last seen: 9 hours 8 min ago
I don’t mind the UI – as long as I can flash my own firmware.
Is the MCU of the driver an Attiny variant?
dave1010
dave1010's picture
sevin7
Last seen: 6 hours 55 min ago
dave1010 wrote:
Neal now has the light up for pre order!
https://www.nealsgadgets.com/products/lumintop-thor-pro-flashlight
It has a screen on the bottom now which is cool but not super useful. $400 is way out of my price range, I was hoping for something close to $200 with the group buy price (still no idea what that price will be). It also says its 4× 18650. If that is the case then I’m no longer interested. 18650’s are not for me, 21700’s are the way to go.
manithree
manithree's picture
Last seen: 1 day 4 hours ago
dave1010 wrote:
Fedtro wrote:
 …Sorry for the extra zero Dave I told you I was doing a job and I added one too many zero.
LOL! 570mm is a bit large for a flashlight… Unless you’re talking about one like this.
Says the guy who claims 1400km of throw:
dave1010 wrote:
It hits 7000 lm and 500kcd (1400km)
dave1010
dave1010's picture
Flashy Mike wrote:
I don’t mind the UI – as long as I can flash my own firmware. Is the MCU of the driver an Attiny variant?
I removed the retaining ring but the driver board won’t budge while it’s still connected to the MCPCB. The wires seem to be very short.
I’m not confident enough that I can solder it back together in 1 piece and without damaging the LEP module if I took it all apart.
Here’s a shot of under the reflector.
Interesting how it says Osram P8.
