Hi, BLFers,
I think you should have heard that we will release a new three-color EDC key light. Yes, It is our M1R EDC Keylight.
You may be curious about the data and UI of this light. Today we will introduce this new product in detail.
CYANSKY M1R is a multi-functional rechargeable EDC keychain light equipped with one built-in 200mAh Li-ion battery. It adopts a one-switch control design but with triple output —— cool white light, red light, and UV light, allowing for multi-functions in various scenarios. The keychain light features IPX8 waterproof and 2 meters impact resistance, capable of all-weather use. The M1R light is the almighty light assistant for everyday carry.
Triple Outputs Meet Multiple Lighting Needs of Life.
- 200-lumen White Light for Outdoor Lighting.
- 5-lumen Red Light for Undisturbed Lighting and Warning
- 3W UV Light for Currency Detection and Fluorescent Inspection, etc.
Features.
- Triple output —— cool white light, red light, and UV light
- Built-in 200mAh Li-ion battery.
- TYPE-C charging
- Easy one switch operation with lockout function.
- A6061-T6 aviation-grade hard aluminum alloy full-metal CNC processing body.
- Premium type HAIII hard-anodized anti-abrasive finish.
- A maximum of 200 lumens output.
- IPX8 Waterproof
- Working Temperature: –30~50℃ / –20~122℉
- Impact Resistance: 2 meters
- Size: 50.4*24*11 mm
- Weight: 19.5g/0.69oz
Operating Instruction
On/Off:
Press and hold the switch for 0.5 seconds to turn on/off the white light.
Light Change:
When you need to change the light between the white and red/UV light, turn off the light first. And then press and hold the switch for 1.5 seconds, the flashlight will activate the last working mode and then turn on the light you want.
Output Selection:
White light: Low→Med →High
Red/UV light: Red→Red Flash→UV.
Memory Function.
Lock/Unlock:
With light off, double click the switch, and the light will blink twice then be locked. Double click the switch again to unlock the light.
Dynamic Real-Time Battery Level Monitor:
With the light off, single click the switch to check the status.
Green constant on: Battery >80%;
Green blinking: Battery 50–80;
Red constant on: Battery 20–50;
Red blinking: Battery <20%.
Intelligent Overheat Protection.
Low-voltage Warning:
Click Here to find more information about the M1R EDC light.
