What's the un-leakiest battery? (non rechargeable ie CHEAP)
33 posts / 0 new
wle
wle's picture
Last seen: 4 hours 21 min ago
MtnDon wrote:
I should correct myself. It appears that the cells sold as Heavy-duty are actually different than the other NON-HD types. They both use a zinc case but the chemicals in the HD last longer and provide a more stable voltage according to Wiki. But Wiki also states they leak because the chenical reaction uses up the zinc, thins the zinc case.
that seems like the best answer:
alkaline – unleakiest of the 2
heavy duty
regular duty – leakiest
    Daniel Behrman, "The Man Who Loved Bicycles".
-Greg Lemond.
Barkuti
Barkuti's picture
Last seen: 1 day 4 hours ago
Carbon cinc cells regenerate their charge/energy when not used. For this reason, they can provide way longer service life if used from time to time, particularly if drained faster than at slow pace. For this reason I remember obtaining better service time per money unit out of carbon-cinc cells when I had my old gameboy. This was also due to the fact that alkalines were noticeably more expensive than carbon-cinc cells long ago (90's).
If you care about leakage problems, it could be a good idea to wrap any carbon-cinc or alkaline batteries in heat shrinkable tube, like li-ion cells. May be of some help.
The human mind, and its programming, is at the forefront of a particular battle of The Light vs evil dark forces. Nearly every human being on this beautiful planet “Earth” has some sort of negative mind programming in its mind. And you better take care of your mind programming, or someone else will in this wicked world.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
Keanu Reeves may need your help. Join his Telegram channel here.
