CRX TEC XP-L HI v2 5D – H17FX – 18350 – Rv Clicky Tail sw – 1012lm.
Made from titanium pill capsules found on AliExpress.
Two lights and a cell charger,
Ti-6Al-4V grade 5 titanium alloy
Copper lined body
Cree XP-L HI v2 5D emitter
Lava red afterglow bezel gasket
18mm x 12mm LOP reflector
18mm x 2mm ARC glass
KD 16mm Copper DTP MCPCB
10mm thick copper LED shelf
25mm x 1mm brass pill housing
Dr. Jones 17mm H17-FX configurable driver
Lucidrv2 firmware
Reverse clicky tail switch, bypassed spring
Screwed bezel & tailcap
Slimline pocket clip
18350 cell compatible
Triple 11mm x 1.4mm ice red tritium vials in tail
Max – 1012lm, 3A – 784lm
Max Throw –
Length – 94mm
Width – 22mm
Weight – 117g (with 18350 cell)
CRX TEC XP-L HI continuous runtimes:
I really like the cut in pattern on the body.
I had considered buy a Ti Dawn for this pattern.
But there’s no clip you say…
And now a triple emitter pocket rocket version!
CRX TEC Triple XP-L HI v2 5D – H17-FX – 18350 – Rv Clicky Tail sw – 2100lm.
Made from titanium pill capsules.
Copper lined body
Triple Cree XP-L HI v2 5D emitters
Lava red afterglow LED gasket
Carclo 10507 optic
20mm x 1.5mm ARC glass
Noctigon 20mm triple Copper DTP MCPCB
20mm x 8mm thick copper & brass LED shelf
H17-Fx Lucidrv2 firmware
Reverse clicky tail switch, brass contact
Max sustained output – 770lm.
CRX 13mm x 4mm random Ti ice red tritium glow fob on chain
Max output – 2100m, 924lm (3A)
Max throw – 180m, 120m (3A)
Length – 76mm
Width – 22mm
Weight – 92g (with 18350 cell)
CRX TEC Triple Cree XP-L HI continuous runtimes:
These things must run through the cells so how about a…
CRX TEC 18350 Titanium 1000mA Pocket Charger/ Spare cell carrier.
Made from a titanium pill capsule.
Copper lined body
S9 1000mA micro USB charging board
Max charging current – 1000mA
Length – 51mm
Width – 22mm
Weight – 55g (with 18350 cell)
So for the last ti pill capsule I made a handy on the go 18350 cell pocket charger/ spare cell carrier.
With this I can carry a spare cell for the TEC lights and also have a charger on hand for when I’m out & about in a form factor not much larger than an 18350 cell.
Copper lined body with a 1A charging circuit in the head.
Red indicator light for charging, blue for charged.
The unit is potted and with the threaded head/ silicone o-ring it is fairly water resistant.
Stay cool
These looks great. Is there a link for these yet, or are they just previews? Thanks
Amazing .
What I do
Those look great! Do you have a link for the pills that you can share? I don’t think I’ve ever seen a chain on a light before but that’s a nice looking chain, looks elegant on a host like that.
The usb port slot…did you drill-and-file that? I’m curious how titanium works with a file. I’ve only worked with it very little, just some grinding and wire brushing and a couple of drilled holes.
Such amazing work! My god, Just when I think I'm actually getting pretty decent at modding, I realize I'm a kindergartner here. Thank you for sharing, CRX !
[FLF] Five Light Friday https://budgetlightforum.com/node/78749
Check out some of my new lights (picture heavy) and quick first impressions of them here: https://budgetlightforum.com/node/77180
My Sft40 beamshots / comparison thread: https://budgetlightforum.com/node/78100
The BLF GT with SFT40 (2300lm, 2700m+ @ 30 seconds!)
https://budgetlightforum.com/node/79561
Superb!
BLF Member Map, add yourself
My 10th Annual contest entry.. My 9th Annual contest entry. My 8th Annual contest entry.. My 7th Annual contest entry.. My 6th Annual contest entry... My 5th Annual contest entry... My 4th Annual contest entry...
My DBSAR inspired SRK lantern hand made mod
These look great. Adapting non-flashlights into lights is always cool. And not new for you, either.
The ice red tritium glow fob on chain is some nice flashlight bling!!!
I’d rather use my flashlight around the house than turn on the lights.
