tiry31
(tiry31)
January 2, 2022, 4:40pm
1
I just received my flashing kit from Hank.
I have a problem : I tried to update my D4V2 E21 2000K with the following firmware :
anduril.2021-12-13.emisar-d4v2-nofet.hex
But the flashlight does not start; I have the aux led which lights up but nothing by pressing. I tried reseting but nothing.
I put back the old firmware that I had saved by reading through the kit and it’s all good again.
Any suggestions ? wrong firmware ?
Try anduril.2021-12-13.noctigon-kr4-nofet.hex
mattlward
(mattlward)
January 2, 2022, 9:04pm
3
Yup, that is the fix.
This light uses a 5 amp CC driver, not the D4V2 driver due to the LED choice.
tiry31
(tiry31)
January 3, 2022, 3:42pm
5
That works thanks !
For my Noctigon KR1 W1 Yellow (Osram KY CSLNM1.FY) should I use the same firmware (anduril.2021-12-13.noctigon-kr4-nofet.hex) ?
mattlward
(mattlward)
January 3, 2022, 4:41pm
6
That is a config I have never used and have never researched. I suspect that it will be no-fet firmware based on the drive current max for that led. So, if that is the case… you are on the right track.
