Beast drivers @ Kaidomain
48 posts / 0 new
yavi
Last seen: 8 months 5 days ago
I have just seen three new drivers at kaidomain, for leds in series at 3A each, for 5,7, and 9 leds, the one with 9 is rated at 100W...
5:
http://kaidomain.com/product/details.S020167
7:
http://kaidomain.com/product/details.S020166
9:
http://kaidomain.com/product/details.S020165
Anyone has a compact host to do it? Haha.
Edited by: yavi on 02/25/2012 - 05:41
Shadowww
Last seen: 1 day 2 hours ago
I wonder if those would fit in the TF TR-J12..
dthrckt
dthrckt's picture
Last seen: 9 hours 50 min ago
thanks for posting
I just ordered the 9led one.  Would you believe I actually WANTED strobe for this project?
Oh well...this driver's probably more robust than what I'd been planning...and I'll gain low voltage protection.
Unfortunately, the driver won't be near enough to the LEDs to benefit from the thermal protection.
Shadowww
8000 lumen strobe? I seriously hope you aren't going to use it as a weapon, because it'll sure as hell will have potential to be one.. Big Smile
dthrckt
dthrckt's picture
that's pretty much the idea w/ the light but I figure it will be so freaking bright that the strobe will be irrelevant (or would simply disorient me, too)
yavi
It would be a potential weapon for epilepsy attacks...
So...are you planning to build a 9 xm-l flashlight?
If so, please let us know about the project, it souds huge hehe.
It could also be a 18 XR-E light using parallel pairs of them, with a huge distance Smile
dthrckt
dthrckt's picture
yes, i've been assembling the pieces for quite some time.  5 drivers will arrive this week.  They were going to be modified and sandwiched but I'm much less likely to toast $100 worth of xmls using the KD driver...
it actually isn't very big at all - roughly stanley led spotlight size...
the emitters have been ordered (but are coming from HK).  The only other part I'm lacking is the relay, but I'll probably just buy one from radioshack (local) when I get ready to wire the switch...
actually, I need to check if DX backordered the reflectors.....too many orders w/ them and I haven't updated my spreadsheet Tongue Out
this driver makes me MUCH more comfortable w/ this expensive endeavor - good chance I'd screw up the home brewed version...
2100
Last seen: 2 years 11 months ago
The TR-J12 would be able to do low 4000 lumens OTF with the 5 LEDs driver.  Not sure if it fits though...   That'd be a good use for the MKNE or King Kong 26650s.   Not sure if the switch can take it, but it should.....
dthrckt
dthrckt's picture
has anyone posted pics of the driver and driver cavity of trj12?  this KD driver is BIG!
Match
Match's picture
Last seen: 5 years 6 months ago
Shocked
Smile
Silly
(runs down to the basement to start scheming...)
Shadowww
I'd be afraid using unprotected LiIons in such powerful thing.. IMO 3x A123 LiFePO4 26650's would be way to go.
Chicago X
Chicago X's picture
Last seen: 8 years 4 months ago
You may want to look at a FET-based switch for that many watts.
http://wardogsmakingithome.org/index.html
War Dogs, Making it Home - Rescue Dogs for Returning Vets
dthrckt
dthrckt's picture
is there a benefit to mosfet switching vs relay?  I want to retain the stock switch from my host and I'm not sure how to do that w/ a fet, plus I can get the relay locally and relatively cheap...
Shadowww
They (MOSFETs) can handle higher currents than relays in smaller package.
jufran88
jufran88's picture
Last seen: 5 years 4 months ago
Yes, they're MOSFET based. More likely this one: http://www.onsemi.com/pub_link/Collateral/NTMFS4835N-D.PDF
I bought one of the similar drivers at Kaidomain last month. I'm planning to build a triple XML U2 IC in a Maglite. I already have the LEDs from Cutter Electronics.
Here's the one I bought: http://kaidomain.com/product/details.S020121
Thermal conductive adhesive to smash between circuit board and body
4835N N-channel MOSFET
Chicago X
Chicago X's picture
http://brunningsoftware.co.uk/FET.htm
This is a good basic read.
willie
willie's picture
Last seen: 1 month 1 week ago
I am a tech not but like TO-220 size because of mount and easy solder tabs. I used one on my Phatlight PT120 and a DX cheapo switch to activate. Was able to keep stock Mag switch location and machine the massive copper heasink (from front of Mag tube to back of old switch length) to house the mosfet internally. I'll try to take some pics possible to illustrate. Am currently working on several high amp projects (DD & CVCC) that may need to be mosfet switched. Have this on order and have been patiently waiting http://kaidomain.com/Product/Details.S020079
dthrckt
dthrckt's picture
thanks CX and willie
pics would be great - that's what I was wondering, if a fet can be used w/ a cheapie switch or just alone
I'll obviously need one or the other - the fans alone are eating an amp at 12V Sealed
willie
willie's picture
On the phone or would post this pic. I don't remember where it came from and hate to plagiarize but here it is http://imageshack.us/photo/my-images/503/fmosfetschemmjimmymos7.jpg/
Cuz of the low voltage was able to eliminate one of the resistors and used a 6.8k (had some) instead of the 10k. Search Lambda builds. I suffer from CRS but recall having issues with the positive ground on the PT emitters. Machined Teflon/plastic insulators to isolate components. This may or not be an issue with pcb mounted emitters.
dthrckt
dthrckt's picture
nice thanks.  easier to wire than the design I had for a relay...
willie
willie's picture
Have my part number at the house. Used a different part than Lambda as I found his info after ordering from Digikey. Same results.
willie
willie's picture
Did I miss something or is this a where these monster drivers came from http://budgetlightforum.com/node/8068
willie
willie's picture
willie wrote:
Did I miss something or is this a where these monster drivers came from http://budgetlightforum.com/node/8068[/quote]
BTT
I used a IRLB3034PBF MOSFET N-CH 40V 195A TO220 from Digikey.
Chicago X
Chicago X's picture
Here's the pic from the link above:
willie
willie's picture
Thanks CX!!
dthrckt
dthrckt's picture
sounds like (from the other thread) those new multi xml lights use very different drivers (magnetic control ring, strobe options, etc.)
my reflectors shipped, T - 2 months to assembly Tongue Out
viktori
viktori's picture
Last seen: 5 years 1 month ago
Could these drivers work in a car? Car battery can spike up to about 13.8V, and these are rated 12V....
Anyone know of a decent driver that could work for a car project?
Viktor
Edit:
I posted this before looking at the already quoted link...
This is my flashlight collection.
Techjunkie
Techjunkie's picture
I tried out one of the drivers mentioned here tonight, KD sku S020121.  Vbatt was really close to Vf of the 3xMCE string I'm powering it with, so I wasn't asking it to do much heavy lifting.  Even still, the darn thing overheats and throttles back after about a minute of use.  The thermal sponges that it comes with are wedged between it and the Mag D tube and the LED Heatsink above it.  For most drivers, including the DX 57779 it replaced, that's sufficient.  Even throttled back, output is still pretty high, but side by side with another light with the same emitter and reflector combo and a different driver shows a visible difference in brightness.  Oh, it whines on low and medium too.  All in all, I'm disappointed.
dthrckt
dthrckt's picture
meaning the light w/ KD driver is dimmer (ie less efficient)?
Techjunkie
Dimmer, yes... less efficient, no (or to be fair, I don't know - I haven't measured Pout/Pin in any of the modes).  The KD driver, after heating up for ~1 minute, is reducing the amount of current delivered to the LEDs AND the amount of current drawn from the battery pack, so it's not necessarily less efficient, it's just throttling back.
When it throttles back this way, instead of boosting voltage sent to the LEDs to maintain an output that requires a higher Vf than Vbatt, it skips right over going direct drive and lowers the voltage sent to the emitters to a value lower than Vbatt.  Presumably, it does this to keep cool.  I would have preferred if it only throttled back to a point where Vout approximately matches Vin (i.e., no boosting, but no bucking either).
dthrckt
dthrckt's picture
thanks
that's disappointing...
I have the 9 emitter version here.  It looks like I'll use the 'poor man's' technique you described for me, as I had originally planned.
I'm sure you're familiar w/ the technique...but fyi, the KD 5A sst-50 driver that others described as behaving similar to what you've described works fine for a few minutes (which is as long as I've tested) potted w/ devcon 2 ton and alumina in a copper pipe cap (ie no host for heatsinking) but it is very hot after <2min.  I suspect it will run indefinitely w/ a copper bushing added and mounted/sinked in my host, but I think it makes more heat than the PT-54 Yell
