NEW high current 60V 24A 1440W power supply RD6024 is released now
179 posts / 0 new
RD tech
RD tech's picture
Last seen: 3 hours 13 min ago
RD6018W feedback
Works well, CR1220 battery prepared by myself
If you have any interest in USB tester or power supply, please contact me
this is my shop on Aliexpress: https://rdtech.aliexpress.com/store/923042
kat
Last seen: 5 days 19 hours ago
Why do the new power supplies for RD6006 have only 3 capacitors?
The older ones had 4
RD tech
RD tech's picture
hello, are you sure RD6006 has 4 capacitors? becasue I check the original design, it only has 3 big capacitors, do you mean other models? or you can show us the picture
kat
In this youtube video I saw 4 capacitors: https://www.youtube.com/watch?v=6GhGgAb8SC8
RD tech
RD tech's picture
I saw 3 capacitors
RD tech
RD tech's picture
RD6012P feedback
ordered RD6012PW whole set, delivered in good condition
kat
RD tech wrote:
I saw 3 capacitors
No, I mean on the power supply, not on the controller board.
There are 4 in the video
RD tech
RD tech's picture
for this, I do not know, because the input PSU is not produced by us, we order them from another manufacturer to work together with our RD power supply, anyway, it does not affect the performance
RD tech
RD tech's picture
RD6006PW feedback
The block works great. I recommend the seller Good quality
RD tech
RD tech's picture
RD6012P feedback
Great product and great seller. Very happy. I have also had an RD6018w for well over a year and has been nothing but brilliant. Hopefully this one is the same. It is fairly simple to set up, everything that is need is included.
RD tech
RD tech's picture
hello, for the input PSU chosen for our RD power supply, please notice the output, make sure it is below 70V DC and stable, then it is OK, and for the feedback, do not include your address information, it is not safe
RD tech
RD tech's picture
RD6012P feedback
great device. I liked.
RD tech
RD tech's picture
RD6024 feedback
Very happy with the product. Device very well mounted and working normally
RD tech
RD tech's picture
RD6012P feedback
good, if the range can be switched then it would be perfect.
RD tech
RD tech's picture
RD6024 feedback
Thanks for the present.
RD tech
RD tech's picture
RD6024 feedback
I bought it for the second time, the packaging is very good, the quality of the power supply is very good, the adjustment is relatively simple, the screen display is clear, and it is exactly the same as the seller's description.
RD tech
RD tech's picture
hello, if you have interest and spare time, you can have a look at our Alibaba live
RD tech
RD tech's picture
RD6012 feedback
take 10 minutes to finish the assembly, it is good
RD tech
RD tech's picture
RD6006P feedback
Great converter, it’s a pity that I didn’t take the 6012p version
RD tech
RD tech's picture
RD6018W feedback
Power supply works well and fitted perfectly in the case. I'm very happy with it.
RD tech
RD tech's picture
RD6024 feedback
the device comes in 2 weeks, and everything works
RD tech
RD tech's picture
RD6006 feedback
Great converter! Delivery 29 days in KZ. I recommend the seller:)!
RD tech
RD tech's picture
RD6018 feedback
Everything is packed perfectly, in a foam box.Everything is made at the highest level, The power supply came at the same time in another package. Thanks to the seller for a high-tech and high-quality product at a low price!
RD tech
RD tech's picture
Monthly Remind
when choosing the input PSU for RD power supply, make sure that the output voltage of the PSU does not exceed 70V DC, otherwise the product will be damaged. it is ok to choose other brand good PSU even if you do not choose ours
RD tech
RD tech's picture
RD6006 feedback
very glad to get this bargain
RD tech
RD tech's picture
25A cable feedback
These are a pretty good lead. In my pictures you can see the watts lost. their performance is better than all of my other power supply leads. I highly recommend these.
RD tech
RD tech's picture
tear down video of the 1200W 68V PSU
RD tech
RD tech's picture
Comparison between 800W65V and RD 1200W68V switching power supply
S-800-65 is NVVV 65V 800W power supply, and RD-1200-68 is RD 68V 1200W power supply. We will disassemble them and show you the difference.
Overall comparison: There are obvious jumper Wire on the 800W power supply, and it uses green single-sided circuit board, half bridge type topology, and the use of low-cost components make the PSU more affordable when the performance is ensured. The 1200W power supply uses a black double-sided circuit board, which has better soldering performance. It uses a 2-transistor forward topology structure, and the used components are more abundant and have a longer service life. This two power supplies are glued at the large capacitor and inductor positions to fix them, both can work at full load for a long time when testing performance, which is recommended.
