I am new and I recently got a “WholeFire XHP90” flashlight, I am really pleased with it but the only problem is that it has various useless modes where it will blink and strobe which is really irritating. I have to go through these modes every time so ot takes several clicks and flashes to turn off. I wish it could just be on and off that would be perfect.
I unscrewed the top and the board behind the LED has 4 wires coming from it and going to the switch. Is it possible to somehow change the wiring in a manner where it will go only to on/off?
Yes. The driver controls those modes. You could bypass it and connect directly to the LED but I'm not looking at that unfamiliar light. It might be better to get a different light with configurable driver.
Most cheap drivers only have a FET to turn it on/off (including pwm), and a few parallelled chip-resistors as ballast (current-limiting), with a µC controlling the FET.
I lobotomised a crappy AT01 by bypassing the µC and FET and just having the LED current go through the resistors.
No pix, can’t advise further. Sometimes it’s as easy as a solder-bridge, other times just resoldering one of the LED wires to a different place on the board.
