Help me setup VPN please..
40 posts / 0 new
vestureofblood
vestureofblood's picture
Last seen: 16 hours 59 min ago
Hi All,
I paid for Express VPN. I thought I was going to be able to set this up on my router, but just now I found out there are two types. Open and L2TP. It appears my router will only work with the L2TP, but from what I understand this really is not that secure? I am much more interested in the security aspect than in getting new shows on Netflix. I can’t just get another router because my internet is LTE, the router comes with a preinstalled simcard from the company.
1. Is going around installing the VPN on every device going to be as good?
2. If i install the OpenVPN software on the computers etc should I still install the L2TP on the router?
3. If i install the VPN on my phone will it use the VPN only when connected to Wifi or will it work when using my data?
I’m not sure if this matters, but here is my basic setup. LTE router connects to a network switch that connects my house and shop PC to the NAS. I have other devices like my TV and laptop that connect to the router using Wifi.
Thanks!!
In Him (Jesus Christ) was life; and the life was the light of men. And the light shineth in darkness; and the darkness comprehended it not.
http://asflashlights.com/ Everyday Carry Flashlights, plus Upgrades for Maglite.
raccoon city
raccoon city's picture
Last seen: 8 min 56 sec ago
Can you bypass your LTE router and use it in bridge mode?
If so, you can use another router.
Do you just want extra security when you surf the web?
If so, you could use the browser Tor, though Tor is not allowed on some websites.
raccoon city
I think it'll work for both, though I haven't used a VPN on a phone.
By the way, you'll need some sort of kill switch so that if your VPN stops working, whatever application you're using will quit using the internet.
gman7228
Last seen: 5 days 23 hours ago
This type of VPN is client based. All the functionality for VPNing is in the client. You shouldn’t have to do anything to your router or network to get this to work. This type of VPN used to be (or still is) also called an anonymizer. Your phone or PC (client) runs the VPN app and it will encrypt data and connect to the VPN server (proxy) through your router and the Internet. You should not have to do anything special. Using a VPN makes your machine anonymous on the Internet because the VPN proxy server will be connecting to a web site for you and sending the web site content to you. The web site never sees your connection, only the proxy’s.
gman7228
There are 10 kinds of people in the world. Those that understand binary notation and those that do not.
raccoon city
By the way, some websites don't like it if you visit them using a VPN.
My VPN has split tunneling, which let's me use my VPN with only the applications that I choose.
I can have one browser use my VPN while another doesn't.
I don't know if Express VPN offers that, but it's a nice feature.
manithree
manithree's picture
Last seen: 9 hours 28 min ago
Running the VPN on your router is a valid thing to do. Personally, I think it’s a bad idea, though.
If you do use one VPN connection on your router, then all your devices on your NATed network will have the same VPN IP address. So, in case you do decide to do something like torrenting a movie, or watching the BBC, that’s all on the same VPN connection. If you also log into gmail, or apple.com from that same IP address, it’s possible (not saying it’s ever been done before) that a 3rd party could connect that usage by client IP. That’s why I recommend you put the client on individual devices. Then each device connects and reconnects all the time, the IP addresses change, and there are lots of them, and harder to track.
But, remember that only 5 devices can be connected simultaneously with ExpressVPN
gman7228
Yes it absolutely is. Router based has it’s advantages. We could go down a big hole here.
Going by the title of the thread, the simplest way to get started is to install the app on your device(s), fire it up, sign in. That should get it going. If it doesn’t… write back.
You probably already know, but if you give them more money, more than 5 can use it.
1. Is going around installing the VPN on every device going to be as good? Yes. Same principal and protocols so it will be good.
2. If i install the OpenVPN software on the computers etc should I still install the L2TP on the router? Are you using OpenVPN clients? Try the ExpressVPN client app. Shouldn’t have to do anything on the router. Typically these clients use the TLS (SSL) protocol which should pass through all routers.
3. If i install the VPN on my phone will it use the VPN only when connected to Wifi or will it work when using my data? You connect and disconnect from the VPN using the client. Any time the client is enabled/connected to the VPN it will use it. So you control it on the device and it should work anywhere, anytime you turn it on. LTE, wireless, ethernet – doesn’t matter.
gman7228
vestureofblood
I would consider this, but so far I can’t find anything that would indicate its possible on my router. Its a Dionlink LTE router (not very common or popular) so there are not a lot of videos etc about that particular one. I looked in the LAN settings and everywhere else I could think it might be and didn’t see anything that said Bridge mode. Can it be called something else?
raccoon city
Check out the manual for the router.
The manual will have your answer.
azj
Last seen: 18 hours 38 min ago
Personally, I use a second, semi-inexpensive linksys router, that I installed a version of DD-WRT on. You can find a list of compatible routers on that site. Other people like to use Tomato Firmware
In any case, I have OpenVPN set up on that router, and a device or two plugged into that router that I want the traffic masked for. Everything else is plugged into the regular router like normal.
I use a program called RemoteUtilities to manage that computer. I used to use TeamViewer, but they got a little draconian in their “free” usage licensing check since I use it from work too, so I ditched it.
vestureofblood
EDIT: IGNORE THIS POST. I found out the problem was something stupid that I did and nothing to do with the VPN. On the same day I added the VPN I change a bunch of passwords. I did so on the NAS, but didn’t realize I had to do so inside each networked PC (someone else originally set this up for me). I am leaving the information below because otherwise many comments in this thread wont make sens.
———————————————————————————-Original incorrect comment below———————————————
I tried loading the VPN to my devices. When I loaded it to a PC my internet speed did not seem highly effected so I was encouraged. However I later found out it completely destroyed my network connection! Now when I try to access ANY information stored on the NAS like my pictures, videos etc or open any shortcuts with data stored on it I get an error message about the short cut. If I try to open file explorer it stalls out for a long time and then the screen crashes. Either goes either blue or black. Start up is very slow. Whats worse, I tried uninstalling it and restarting everything but the damage is permanent. Worse still I never setup system restore on this PC so now I will have to reformat the hard drive.
I really don’t understand why this happened. The only theory I have is that because both my internet and the NAS data come in on an Ethernet cable that the VPN doesn’t understand the difference??
pennzy
pennzy's picture
Last seen: 11 min 4 sec ago
I know I can’t Chromecast or print when my VPN is on. I don’t know but this sounds like a similar problem.
manithree
manithree's picture
When you install a system-wide VPN client, you’re telling the VPN client to route all network traffic from that system through your VPN providers servers. The result of that is local connections are disabled, unless they’re available from the Internet, since everything goes straight to ExpressVPN outside your network.
You still haven’t said what you’re trying to accomplish by using a VPN, so that makes it difficult to give specific suggestions. But, maybe the browser extension is what you’re looking for. That will allow your web browsing to go through the VPN, but gives you more control (you can easily turn it off, or use multiple browsers with different settings, etc.). That won’t affect file shares, since that’s independent of your web browser.
That really shouldn’t happen. If you uninstalled the ExpressVPN software, you should have access to local resources again. Have you checked The Windows Network configuration? It’s possible that ExpressVPN configured a VPN protocol that’s built-in to Windows, and that’s still running. I don’t use Windows or ExpressVPN, so that’s just a guess, but I know Windows has some native VPN support.
azj
You may have to look at the vpn app (assuming you’re using one) for a setting to allow local network (LAN) access, or “network lock” or something. If you’re just using a windows VPN I think it’s buried somewhere in the TCPIP or IPV4 settings and called “use default gateway on remote network” or something like that.
CM2010
Last seen: 38 min 20 sec ago
When I tried ExpressVPN installed on my router it totally throttled my connection so if you need a bit of speed behind you….
azj
No, I think terminology is getting mixed up here. “System-wide” in this case would mean “Computer-wide”, where installing a VPN on your “Computer”, (also called a “Computer System”) affects everything that computer tries to access.
Other things on your network, apart from that particular computer (system), would not be affected by the VPN, like a NAS, or a chromecast, however the computer with the VPN (if active) would not be able to talk to them. Other computers on the network (like your shop one) would be able to.
Rebooting all the equipment probably introduced some other unknown problem that has nothing to do with the VPN.
Can you uninstall the VPN? At least until everything goes back to normal.
VPNs can introduce slowness. There’s not much to be done about that.
For one, they are encrypting everything, and the more encryption there is, the more horsepower that takes, which can slow stuff down.
For two, a VPN is routing all your traffic somewhere first, before it goes wherever you say you want to go. Like if you decided it would be a good idea to use a VPN that makes you look like you’re in Luxemborg. Guess what, just opening a page to Google has to route through Luxemborg first. Playing CoD or something is just crazy talk at this point.
For three, you’re depending on their servers (in Luxemborg in that example) for speedy routing. Picture a freeway interchange. It’s like that. The bigger the better. How big is theirs?
vestureofblood
azj. Thanks for joining the conversation, and clarifying system wide. I already uninstalled the VPN. The problems with house PC continued, and after the restart of all my systems including the NAS the shop PC started having the issue. I don’t think its a coincidence that right after I installed the VPN all of this happened. I have never had any of this happen before.
manithree
manithree's picture
I went to network status and under Ethernet it says “not connected”, but LTE-XXX (my router) says connected. So it looks like maybe whatever it changes was on the NAS???
How did you “go to network status”? Was that on the NAS, or a PC?
It’s highly unlikely that the VPN client on one of your computers modified your NAS.
I also tried plugging the NAS in directly to the shop PC with an eithernet cable, rather than being routed through the network switch and it did nothing
Unless you’ve had that working before, I wouldn’t expect it to (i.e. it’s not a very good test). In general, you can’t just connect two computers, and your NAS is likely just a small linux or bsd computer, with a straight-through network cable. Unless one or the other has an auto-configuring network adapter (which used to be quite rare, and I think still is), you need a crossover cable to do that.
ETA: Plus addressing issues. That’s just very unlikely to work.
vestureofblood
That was on the house PC.
manithree
manithree's picture
There are 2 things to check. If the network status on the PC is “not connected” there is either a physical problem with the NIC in the PC, the cable, or the switch. Or, it can’t connect to the DHCP server on the router to get its assigned IP address. Check the lights on the port on the PC, lights on the ports on the switch, and double-check your router is still working.
Given that you’re seeing multiple problems on your local network (I think), it’s possible your router is disconnected from your LAN, or not functioning. I would focus on one PC that’s plugged directly in to the router, if possible. Get its network connection working properly by checking every step between it and the router. If you can’t get that working, you’ve almost definitely got a router problem.
Kelly8
Kelly8's picture
Last seen: 2 weeks 1 day ago
Sorry if this is off-topic, but is it worth it to buy Express VPN, or are there better options?
CM2010
ExpressVPN is considered one of the best if not the best.
I just split the cost with a friend and share it as you can have 5 connections.
raccoon city
If you're looking for a budget option, I like Ivacy VPN.
https://budgetlightforum.com/comment/1759725#comment-1759725
They're not the best VPN, but they're dirt cheap and good enough for me.  :BEER:
The Dude Abides
Last seen: 1 week 1 day ago
I think most paid VPNs are pretty much a scam at this point with all the Youtubers shilling for it. For securely accessing your home network, including accessing Synology from afar, I recommend Tailscale. I have been using it for many months and it is great and free. It runs based on Wireguard VPN.
https://tailscale.com/
raccoon city
In my research, everywhere that I have read, all free VPNs are worthless, privacy-wise.
(Many paid ones as well.)
azj
Well, at this point, it sounds like your Synology is not getting proper network settings. I’d try the following:
1) turn off the pc with ExpressVPN on it, just to be sure (this shouldn’t be necessary, but hey, just to be sure)
2) reboot the Synology. This can take 5 minutes or so. To do this you are probably going to have to tap the power button, wait a bit for all its lights to go out, then tap it again. If that doesnt work, hold down its power button until the lights go out (force it off, less desireable), then push it so it comes back on. A much worse/last ditch method is to pull its power.
3) try and ping the Synology after waiting the 5 minutes or so from a different computer. It appears from your screenshots that its name is “nasstorage”, so you’d open a command prompt by typing “cmd”, and either press enter or click the command prompt icon, then in the black command window type “ping nasstorage” (no quotes). You may have to do this a few times. Hopefully you get messages that say “Reply from…” after a bit and not “Request timed out” or something else bad.
You can click the “X” or type exit to get rid of the command window.
If that doesn’t work then I’m not sure what’s up with the Synology, but it really shouldn’t have anything to do with the VPN. Maybe unplug/replug/check its network cable.
If all that does work, then turn your VPN computer back on and go from there.
Good luck
As far as one vpn service over another, ExpressVPN is fine. I happen to have “Private Internet Access”, but only because I got a good deal many years ago and I knew how to connect to them using a router. I also connect to them using a PC when I’m at work with no issue.
pennzy
pennzy's picture
Proton vpn gets good reviews and is free.
raccoon city
They throttle the speed of the free accounts, and don't allow file sharing.
Also, with a free VPN, you are the product, which means they sell your data, which is the exact opposite of what you want with a VPN.
If you care about your privacy, do not get a free VPN.
"If you really want better protection online, avoid free VPNs. While you might save a few dollars each month, the risks to your privacy and data are not worth it. In fact, using a free VPN could cost you a lot more than the subscription to a premium provider."
https://www.vpnmentor.com/blog/free-vpns-are-not-safe-to-use/
pennzy
pennzy's picture
I don’t know about file sharing and the speed does slow from some free locations but Proton was one of the best for protecting your info. It is fast enough for me but I don’t use it for gaming or anything requiring a lot of speed. At least it was rated highly when I joined up over a year ago.
https://www.top10vpn.com/reviews/protonvpn-free/
raccoon city
Okay, according to that website, ProtonVPN is the only exception to the rule (of free VPNs that offer unlimited access selling your data.)
I did some additional research, and it looks like my comments about privacy and ProtonVPN were wrong (in previous posts.)
You'll get much better speeds with a reputable paid VPN, and I got a lifetime subscription to Ivacy VPN for only $40
vestureofblood
My Apologies!!! I found the problem with my network and as minithree and azj suggested it was not an issue cased by the VPN. At the same time I installed the VPN I also updated some old passwords including the one on the NAS. I didn’t realize that I needed to update them inside each of my computers as well (someone else setup this nework for me).
I left my original post but edited it to reflect this. That way all of the responses to that comment will still make sense. I also deleted the post I made that suggested a person should take into account the “damage” done by VPNs as part of the “Price”. Again I apologize for posting the incorrect information. Thanks to all who offered support.
I still plan to peruse the VPN. I am going to do a new set of backups before proceeding since mine are like 5 months old. Once that is done I will Test the VPN again.
