Charger for MS08 21700 cells
Anyone know of a charger that will handle the 21700 batteries which are supplied
with the Imalent MS08? Neither my Nitecore D40 or my Gryfalcon will
go deep enough to accept them.
Thanks
The XTAR VC4SL can handle them easily.
OK RR thank you !!
I just bought this Vapecell —- works well — charging is great —- discharge is good on outer two slots ( 1 amp ) only .5 amp for the middle 2 slots — comes with a more than adequate power supply to provide 3 amps charging to all 4 slots — WOW Big Battery is crazy with their shipping — Illumination Supply backordered
The Nitecore UM4, UM2S, and UM2 can handle the longest cells (79mm).
https://lygte-info.dk/info/roundCellChargerIndex%20Universal%20UK.html
OK thanks again, the 21700’s in the MS08 are about 72mm so the XTAR, Nitecore or Vapcell should
all work great. The magnetic charger with the MS08 works fine but, I like seeing what’s going
on during the charging operation and also having a second option should the cable with the MS08
fail.
