New research on revitalizing lithium-ion cells
25 posts / 0 new
Correllux
Correllux's picture
Last seen: 55 min 8 sec ago
I thought this new research finding was quite interesting and worth sharing as general info although its possibility or relevance for us home users at the present time is unknown. I can’t access the research paper without paying $$ so I have no idea what methods or cells they used in this study…suspect it may have been geared toward the monumental shift in electric vehicles and the challenges there.
Basically zapping lithium-ion cells with high current to “heal” some of the wear, so to speak, or prevent it during normal use (charging). From the little I can see it looks like it could significantly improve both the reduction of capacity and overall cycle count/life. Perhaps one day we’ll have li-ion charges with a “refresh cycle” mode or a change to the typical charging method programmed into the chargers. They’re giving charge rates at density ratios…maybe someone can math that out to layman’s numbers.
Over the years I’ve started to glaze over and ignore a lot of the battery research – even though some of it is interesting or novel, most of it can’t or won’t come to fruition in the products we use, or perhaps not for many many years if it has merit. This seems more useful overall, though.
https://www6.slac.stanford.edu/news/2022-01-03-revitalizing-batteries-br...
Source article in Nature has some links to the figures/graphs from the research paper (scroll down a ways): https://www.nature.com/articles/s41586-021-04168-w
Edited by: Correllux on 01/09/2022 - 17:07
Bort
Bort's picture
Last seen: 8 min 58 sec ago
Even if it works the claim that it reduces fire risk is laughable.
That said i am not yet convinced it is even correct, high discharge rates are not good for lithium batteries which is general knowledge since their creation.
That said one must be open minded but this is not yet proven.
The Journal of Alternative Facts TM
"It is critical that there is a credible academic source for the growing and important discipline of alternative facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists"
supreme
Last seen: 20 hours 41 min ago
Here’s the research paper
Correllux
Correllux's picture
Dendrites…reversing or preventing…that’s our biggest risk with venting and fire…that’s the whole point of this research. Without seeing the details in the paper but looking at the figures, it appears to be all charge, not discharge, for the methodology they are presenting.
Supreme…extremely hesitant to dl that file…not familiar with the site. Did you upload it, and if so do you mind sharing how you got the materials? Shows it was just uploaded.
kennybobby
kennybobby's picture
Last seen: 48 min 52 sec ago
i’ve used that service before and it downloaded without incident. It asks if you want high speed (fee) or low speed (free); i have always used the free (budget minded) and it has always worked. i can email it to you if you are nervous about the dl.
it is a quite technical study to investigate manipulation of Li ions
Quote:
we hypothesized that a short, fast
Li-stripping step after Li deposition may promote the recovery of i-Li
and extend the longevity of the Li anode.
To test their theory, they doped some cells with excess Li:
“As a proof of concept, we evaluated the electrochemical performance of NMC–Li full cells with 150%-excessed Li with and without activation.”
Results:
“The dynamic polarization of i-Li results in its spatial progression toward the cathode (anode) during charge (discharge). By promoting its growth toward the anode through fast discharging, we further dem- onstrated the recovery of isolated Li in both Cu–Li and NMC–Li cells. We anticipate that the mechanistic insights into the behaviour of i-Li will inspire and guide the future development of robust lithium metal batteries and realize extreme fast-charging in lithium-ion batteries.”
Now i used to think that i was cool,
drivin' around on fossil fuel,
until i saw what i was doin',
was drivin' down the road to ruin. --JT
Correllux
Correllux's picture
All good. I hate anonymized files…and couldn’t cross check with file size or anything else. Used a different computer and gave it a scan. I’ll have to read it later tonight. Thanks for the offer! And thanks Supreme for the link!
Bort
Bort's picture
I guess i am skeptical becasue this upends a great deal of established knowledge.
That said more data and third party replication is in order.
I did not upload the file, supreme apparently did.
supreme
I have access through uni. Just googled a file upload service and picked the first one. I can upload to whichever file service you choose.
Oli
Last seen: 1 hour 27 min ago
They’re talking about a quick hi-load discharge immediately after full? charging. It’s already well known that you should not leave a Lithium-Ion battery in a state of “full” charge. In flashlight terms, one minute on turbo immediately after charging probably isn’t going to hurt anything. It’s also already known that you can extend a battery’s life cycle by not fully charging or discharging. 80/20, 85/30, 4.0/3.5v pick your range. Does that have something to do with not losing this lithium on stranded islands? I don’t know. They also loaded their hand built test battery with extra lithium so it’s easier to create Bridges and not have isolated Islands.
You can't compare the big flashlight in the sky to the little flashlight in your hand.
flashburn
Last seen: 1 week 1 day ago
From experience I can say that discharging a LiPo cell at specified C-rate to about 3V under load from time to time does increase the lifetime of the cell.
An overdesigned cell (too many mAh, too much C, too little charge or discharge current) ages faster than a cell operated close to the specified parameters.
Never thought about the cause for these findings.
 Sofirn IF25A-4000K, IF25A-6500K, SC31 Pro 5000K
ljtyk
Last seen: 38 min 59 sec ago
Here is the paper’s conclusions:
Here we added a 2-min fast-discharging step (Li stripping) at a rate of
1C (1C = 2.67 mAh cm−2) after the charging process. During this 2-min
activation step, the cell delivers a specific capacity of 5.3 mAh g−1, which
accounts for 3.7% of its total capacity (143.1 mAh g−1) (Fig. 4d). The ben-
efit of this activation step becomes more pronounced after 30 cycles
when the cell without activation starts to exhibit fast degradations in
capacity (Fig. 4e) and CE (Extended Data Fig. 9a). Such degradation
behaviour indicates the exhaust of excessive Li and the continuous
accumulation of ‘dead Li’. By sharp contrast, the cell with activation
maintains stable cycling for more than 40 cycles (versus 30 cycles) and a
much slower degradation process afterward. On average, the cells with
activation exhibit a 29% longer cell lifetime (Extended Data Fig. 9b),
which can be attributed to the partial recovery of ‘dead Li’. A similar
increase in cycle lifetime has also been observed under a faster-charging
condition at 4 mA cm−2 (Extended Data Fig. 9c, d) and in the literature29.
So their method is to discharge at 1C for 2 minutes after charging process which boosted battery life after 40 cycles. And other literature reports discharging 1.5C is also beneficial. I think some fancy chargers like MC3000 could be programmed to do this, anyone wants to try this and report?
Bort
Bort's picture
Quote:
As a proof of concept, we evaluated the electrochemical performance of NMC–Li full cells with 150%-excessed Li with and without activation. Here we added a 2-min fast-discharging step (Li stripping) at a rate of 1C (1C = 2.67 mAh cm−2) after the charging process. During this 2-min activation step, the cell delivers a specific capacity of 5.3 mAh g−1, which accounts for 3.7% of its total capacity (143.1 mAh g−1) (Fig. 4d). The ben- efit of this activation step becomes more pronounced after 30 cycles when the cell without activation starts to exhibit fast degradations in capacity (Fig. 4e) and CE (Extended Data Fig. 9a). Such degradation behaviour indicates the exhaust of excessive Li and the continuous accumulation of ‘dead Li’. By sharp contrast, the cell with activation maintains stable cycling for more than 40 cycles (versus 30 cycles) and a much slower degradation process afterward. On average, the cells with activation exhibit a 29% longer cell lifetime (Extended Data Fig. 9b), which can be attributed to the partial recovery of ‘dead Li’. A similar increase in cycle lifetime has also been observed under a faster-charging condition at 4 mA cm−2 (Extended Data Fig. 9c, d) and in the literature29.
Lithium batteries lose a few percent in their first 2-5%-ish of service life, so they claim they can recover it.
Thats great (if universal) but the after this initial drop the cell stabilizes for most of its working life. So their proof of concept only covers the initial drop which most devices don’t even notice becasue its expected design behaviour.
What they really need to do is get some old worn out batteries that are below 80% initial capacity (and high IR) and see if they can revive them.
kennybobby
Bort wrote:
… What they really need to do is get some old worn out batteries that are below 80% initial capacity (and high IR) and see if they can revive them.
LOL Don’t hold your breath waiting on that to ever happen.
Bort
Bort's picture
Why not?
ljtyk
Bort wrote:
Why not?
They actually did somewhat accounted for this effect. Their highly artificial battery only has life span of about 100 cycles, and they claim their discharge method increased battery capacity beyond 100 cycles, i.e. even good for even near end of life batteries. I’m somewhat skeptical but I did order a MC3000 recently and may do some real world testing if I got some time.
Bort
Bort's picture
ljtyk wrote:
Bort wrote:
Why not?
Artificial aging is not always analogous to actual aging.
And i guarantee they can find naturally aged cells, just go to the battery recycling bin of any big box store.
You can pulse charge lead acid and get some extra life out of them. Its a proven effect and you can buy chargers that do it.
So i would love to see actual aged lithium cells brought back to life and see how much more life you can get out of them.
This is not expensive for a research lab and some PhD students.
ljtyk
I agree 100%. There are other red flags in the paper. Their sample size of 6 I believe and their own battery chemistry is chosen to allow for premature artificial aging. With that said, I would love to do a real world test of this. You think I could go to a box store and ask for some of those aged cells? All my batteries are <3 months ago since I only got into this hobby very recently.
Bort
Bort's picture
Many BLFers have been succesful in getting used cells by asking nicely.
Sometimes you end up with new cells from displays or people who didn’t know how to charge them or changed eco systems or threw away batteries when cleaning out parent’s basements who have passed away and so forth.
Bort
Bort's picture
Correllux
Correllux's picture
After reading through the paper and going down a couple rabbit holes, I’m not sure what to think. It certainly holds promise. Their test cells weren’t at all like our manufactured cells but that’s not important. I’m curious about their choice of Li-Cu (could be a good chemistry reason for that, for this experimentation) but they also used a LiMnCo in the tests. Their treatment of the formation charge is critical here, it seems, and that may be where a lot of the benefit is but it’s clear that there could be benefits down the road as well. Somewhere in there I saw more digestible numbers of charging at 0.3C and discharging at 0.1C as they were trying to massage the iLi toward the anode, which in turn reduces the size and growth of dendrites (good gosh those things are tiny…I had no idea the scale we were talking about when mentioning those). Interesting that the dendrites were able to pierce one liner but not the other (I’m sure that’s not news to the bigwigs).
I think maybe “revitalizing” is the wrong word to use here…that was synonymed from the article I first read about this. It’ll be interesting to see if this can actually apply to packaged cells we use in products and if chargers will follow suit in the consumer market. I really suspect it’ll be the automotive arena that will give it the attention if it deserves it. I think it was Figure 9 (second to last page) that was the most telling, for potential.
Correllux
Correllux's picture
All good…really, thank you for sharing that! I tried my old uni login but it’s clearly expired. Smile Tried another and it was still going to make me pay. I know these folks have to earn some money that doesn’t come from a grant but paywalls are so frustrating.
kennybobby
Bort wrote:
… Why not?
The solid-electrolyte interface (SEI) layer that forms on the anode.
Growth of the SEI layer causes capacity fade by removing active lithium from the system irreversibly.
Bort
Bort's picture
kennybobby wrote:
Bort wrote:
… Why not?
This does not stop them from testing their proposed solution on worn out batteries.
As i said i don’t expect success but the testing is very achievable.
JaredM
JaredM's picture
Last seen: 12 min 51 sec ago
There are a bunch of 35Es and MJ1s in my test lab that a previous student abandoned. I can fire them up and try a few of these techniques (I haven’t yet read this paper, but happen to be working on some similar projects). Not sure how many cycles they have, but maybe I can dig through her file folders and find out. If I get around to it I’ll share the results
https://fundrazr.com/osturaband
No affiliation, just a fan.
Bort
Bort's picture
I look forward to your results if you do this!
