LED light bulb discussion
6 posts / 0 new
Blinders
Blinders's picture
Last seen: 1 week 2 days ago
/edit, I just saw there is an entire forum catagary for LED light bulbs, my Apologies! /end edit
Happy new year, all!
What have you found is the best Standard A19 LED light bulbs?
I switched to LED around 8 years ago for all my home LEDs. My experience has been terrible. I’ve tried GE brands, they all die within 1 to 2 years with normal Usage.. About 4 years ago I switched to the Walmart Great Value brand. They are great as far as light output and color goes, but they die within 1 to 2 years. Tomorrow I’m taking back 9 bulbs (eight 75w equiv and one 100w equiv) to exchange. They take them back without receipt for exchange.. So far this is my most cost effective solution. They have 3 year warranties so, but they don’t give you hassle since they are in house brand.
Anyone have good luck with a better built brand lasting more than 2 years?
Edited by: Blinders on 01/09/2022 - 23:27
Lightbringer
Lightbringer's picture
Last seen: 8 min 11 sec ago
Feel like going to Dubai and picking up some?
The Big Clive went into this…
kennybobby
kennybobby's picture
Last seen: 6 hours 30 min ago
How is the quality of the power grid in your area—do you have frequent outages or brown-outs, get many lightning storms, underground or overhead main lines, etc?
i’ve had a few failures that seem to be from overheating, which can cause an annoying flicker or just burn out an emitter. Most of the time only 1 emitter has failed, but recently i had all 8 on the board to go.
There is little to no EMI filtering or surge suppression on the circuit board, and no good path to get the heat out.
Now i used to think that i was cool,
drivin' around on fossil fuel,
until i saw what i was doin',
was drivin' down the road to ruin. --JT
jon_slider
jon_slider's picture
Last seen: 1 hour 2 min ago
There are at least 4 different LED bulb threads atm..
https://budgetlightforum.com/node/69805?page=17
https://budgetlightforum.com/node/80491
https://budgetlightforum.com/node/80497
https://budgetlightforum.com/node/80112
but few of the posters actually measures anything and lots of the posters dont care about CRI, nor do they care about flicker.
for those that care about CRI and Flicker, I suggest buying an Opple Light Master, they are on sale atm. https://www.aliexpress.com/item/1005003302809897.html
Blinders
Blinders's picture
I live in an area with a healthy power grid, no outages or brown outs really. Incandescent lasted around the same Length of time,the I switched to “rough use” that had thicker filaments and could withstand higher voltage (rated for 130v I stead of 120)and they lasted a bit longer. Thinking of getting a whole home surge protector/arrestor. You think that would help?
kennybobby
It could help. You might do some monitoring to see if the lines are noisy and spiky, running high, etc to know whether or not surge suppress or filtering might be needed.
The main problem is just cheap manufacturing, weak design and inadequate heat sinking. But if they were better design then maybe less power would be wasted and less need for heat sink. They just run so hot that they shorten the life.
