BUYER'S GUIDE FOR THE BEST CAMPING LANTERN & FLASHLIGHT
4 posts / 0 new
WubenLight
WubenLight's picture
Last seen: 3 days 14 hours ago
When it comes to your camping trip, have a quality lantern. First and foremost, a good lantern should be able to provide convenient and reliable illumination in or around your tent. Before getting a camping lantern, you need to first consider the intended purpose of the lighting. Are you going to use it to illuminate your tent? Or the other parts of your campsite? Create a relaxed atmosphere for campers?
There are many types of camping lighting on the market, what’s make a camping lantern different is that it's designed to illuminate a large area without the need to be held, it can be placed on a camping table.
Lantern Style  #Wuben F5 Power Bank Camping Light
⚡ With 3 Color Temperatures, 5700K-4500K-3000K
⚡ Built-in 5200mAh rechargeable battery
⚡ Runtime up to 190 hours
⚡ Only 203g
⚡ IP 64 waterproof level
Wuben F5 comes with a floodlighting design, it can illuminate your entire tent. The light features a magnetic O-ring, S-hook, and lanyard that allows you to hang it up wherever you want, and it can be balanced on a table or any flat surface, offering you a hands-free operation. One of the greatest features is that F5 can serve as a power bank to juice up your smart gadgets with a type C cable.
High Brightness  #Wuben A21 High Lumen Led Flashlight
⚡ Adopts 21700 rechargeable battery with 4800mAh
⚡ Constant current
⚡ Aircraft aluminum & stainless steel bezel
⚡ IP 68 waterproof level & anti-drop
A21 delivers a maximum of 4200 lumens cast a long throw of 222 meters, a perfect floodlight for everyone. The flashlight is powered by a 21700 high-drain li-ion battery with a 4800mAh capacity, it offers up to 110 hours of runtime; it features Turbo, High, Med, Low, Eco 5 brightness levels, also feature SOS & Strobe modes to cope with different needs. Made from aircraft-grade aluminum housing, A1 is tough and durable, you can easily use a lanyard to hang it up in your tent or on a tree.
Multifunction  #Wuben H1 Super Bright Led Rechargeable Headlamp
⚡ 18650 li-ion battery with 2600 mAh
⚡ 180 degrees rotation
⚡ Only 54g
⚡ 5 defaults output selections
Wuben H1 is a headlamp with multiple functions, it can be placed on a table and serve as a camping lantern. H1 delivers a maximum of 1200 lumens cast a wide beam that effortlessly illuminates your surroundings; it is powered by a 1 pc 18650 li-ion battery of 2600mAh, H1 can be charged with a micro-USB cable and features a built-in intelligent charging IC chip to prevent overheating. One appealing feature is that H1 allows you to adjust the beam throw from 100°C to 180 °C, rotating it according to your needs.
Easy Carry  #Wuben C2 2000 Lumen Power Bank Flashlight
⚡ Up to 2000 lumens with the longest throw of 358 meters
⚡ Serve as a power bank
⚡ IP 68 waterproof
⚡ 109g only
Wuben C2 is a small pocket-sized LED flashlight but it can be used as a camping light as well. It features the signature ‘W’ switch, it’s quite powerful regardless of its size, it delivers up to 2000 lumens and its longest beam throw is up to 358 meters.
With a 4800 mAh battery, C2 can be used as a power bank to charge your electronic devices such as smartphones, cameras, etc. I love to go for a long walk with my dogs in the evening, my old flashlight overheated after 20 minutes of continuous use, it stopped me from walking too far. But Wuben C2 has a built-in intelligent circuit, it not only monitors the temperature of the flashlight but also allows C2 to emit a constant current.
Wuben C2 is slightly longer than 5 inches, with an anodized black housing, and weighs 6.7 oz, it features a clip so you can easily hang it on a tree by using a lanyard. C2 is also waterproof, this means it can be used to light up your campsite in the pouring rain without any issues.
Dreaming_
Dreaming_'s picture
Last seen: 37 min 35 sec ago
Nice post, I’ll check that lantern out. I like that you take feedback from the community.
andycc12 wrote:
Favorite Quotes: Women hold up half the sky
By that standard, penguins only hold down like 1 / 10635853th of the Earth, mostly ice.
I feel like penguins aren’t pulling their fair share.
                                 I just ordered some Dc-fix from Boaz!
                                                --> DC-Fix Diffusion Film Sale <--
                                 --> https://budgetlightforum.com/node/42208 <--
Bort
Bort's picture
Last seen: 5 hours 27 min ago
Penguins you say?
The Journal of Alternative Facts TM
"It is critical that there is a credible academic source for the growing and important discipline of alternative facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists"
Dreaming_
Dreaming_'s picture
Bort wrote:
Penguins you say?
