Liquid Electrical tape
10 posts / 0 new
Bwana
Last seen: 17 min 32 sec ago
Is Liquid Electrical Tape a good idea for repairing a small tear in a battery wrap?
I have a very small opening near the top rim of a 21700.
I read where nail polish is one solution, but I would think the liquid tape would be more flexible and better for heat.
pennzy
pennzy's picture
Last seen: 29 min 1 sec ago
That could possibly work but it might peel off easily. This is my go to for things like this
https://www.walmart.com/c/kp/e6000-glue
Bwana
pennzy wrote:
That could possibly work but it might peel off easily. This is my go to for things like this https://www.walmart.com/c/kp/e6000-glue
I think I have some of that stuff . I’ll give it a try
Thanks
iamlucky13
Last seen: 13 hours 50 min ago
I would prefer to consider such a fix temporarily, lest that spot be more susceptible to future handling damage, especially since it is near the top, where there is less distance to span to create a short between the case (negative) and the positive terminal.
In fact, personally I would just use electrical tape unless there are clearance issues, and plan to get some new battery wraps the next time I place an order from a store that sells them.
Tatteredmidnight
Last seen: 2 hours 44 min ago
Why not just rewrap the battery? Seems like the safest and most permanent solution to me.
slmjim
slmjim's picture
Last seen: 1 hour 7 min ago
My first thought was corona dope, or some variation thereof, such as this:
https://www.amazon.com/MG-Chemicals-Silicone-Conformal-Coating/dp/B085G42TGS/ref=pd_sbs_5/140-6336066-8867610
slmjim
Smile! It makes others wonder what you've been up to.
Time is more valuable than money.
You can get more money, but you cannot get more time.
Bwana
I just ordered some wraps from AliExpress for a permanent fix.
Ordering from AliExpress is akin to a pregnancy, it is measured in trimesters.
James C
Last seen: 9 hours 42 min ago
Looks like some good answers to the original question.
I was just thinking of liquid electrical tape the other day. I think I fried another driver by shorting it on a reflector. I had taped the underside but evidently not well enough. Has anyone tried coating their reflector in LET to prevent shorts?
kennybobby
kennybobby's picture
Last seen: 47 min 28 sec ago
i’ve used it on the blade of my hockey stick and it works great. Just let it have time to dry and it makes a good insulation for electrical work.
Now i used to think that i was cool,
drivin' around on fossil fuel,
until i saw what i was doin',
was drivin' down the road to ruin. --JT
id30209
id30209's picture
Last seen: 15 hours 46 min ago
I am using liquid tape for years now. Not only for flashlights stuff but it's used in the aviation industry as well, at work.
So yes, go ahead. That stuff becomes like rubber once cured and isolates whatever you want.
WTB Titanium 4sevens 2xAA tube
