Convoy H2 LH351D 5700k - New only tested to see if it worked No battery £20 including P&P via Royal Mail 1st class recorded
Any questions please ask
Thanks
Thanks
What are the modes like on the Convoy H2? How low does the lowest go?
Hi
Its on ramping mode at the moment. It does go quite low so moonlight or you can set it to 4 mode operation.
These are the details
Mode operation instructions:
1.click the button ——> flashlight is turned on with last brightness ——> press the button,brightness ramping up ——> release and press the button again,brightness ramping down
2.flashlight off, press the button ——> moonlight mode 0.01A (0.2%) [This brightness will not be remembered]
3.flashlight on or off, 2-click the button ——> turbo 100%
4.flashlight off,3-click the button ——> strobe
5.flashlight off,4-click the button ——> tactical mode, only 100% ,4-click the button again to quit tactical mode.
6.flashlight off,5-click the button ——> voltage detection (* means “flash” , * pause* means 3.7V, )
7.flashlight off,6-click the button ——> normal ramping mode switch to 4modes 1–10–40–100
8.flashlight off,10-click the button ——> Lock mode,The flashlight will flash once under any operation, which means the flashlight is locked.10-click the button again to quit lock mode,Please note that this is the only way to unlock.
The flashlight has low voltage protection and temperature control protection.
Anyone?
Price reduced to £18 including p£p
I’ll take it can you dm me your PayPal.
sent thanks
