I’m after something like the Meco XPE-Q5 but with USB C input for charging. I’ve spotted the Coast HX5 but it seems to only be Micro USB input.
Ideally the switch/button would be mounted on the end and tail standing should still be possible but 14500/AA and USB C are the important required features.
Then the charging port is "not" on the flashlight itself, but is instead "built-in to the 14500 battery" that is offered on the webpage for the "Coast HX5" as one of it's "ACCESSORIES" and described on this webpage:
Which would probably not be as exciting or dangerous when compared to the outcome for the unsuspecting "pipe bomb" victim who recharges "non-rechargeable lithium primary CR123A" cells inside of the "Coast HX5R" which has a USB-A charging connector built in to the tail cap of the flashlight (unless the "HX5R" or "CR123A primaries" contain safety features that I am unaware of):
The description for the "Coast HX5R" at https://coastportland.com/products/hx5r states:
"The Dual Power system allows the light to run on our custom rechargeable battery and a standard C123 alkaline battery."
I have never heard of a "C123 alkaline battery", but maybe the "custom rechargeable battery" listed at https://coastportland.com/collections/batteries/products/z550 is designed in a proprietary way so that it is the only battery that the HX5R will recharge due to its physical characteristics making the light safe.
EDIT #2:
Found a manual for the "Coast HX5R" at https://www.batteribyen.dk/media/blfa_files/HX5R_Manual.pdf which states the following:
So the "Coast HX5R" is designed safely and I apologize for questioning the safety of this light.
I could not find directions for the "Coast HX5R" on the web to determine if users are warned about the dangers of recharging CR123A primary batteries or if the engineering design of the HX5R when used with CR123A primaries prevents any adverse consequences from occurring if this accidentally happens.
Even if there was not an explosion and the battery only vented while being charged, it would be harmful to breath any of those fumes.
EDIT:
EDIT #2:
