With mine, it is impossible to use both emitters on max…When flood is set to high and I turn on spotlight on turbo, the flood emitter gets dimmer(to medium setting?).I’ve tested it with different batteries, but everytime the same…Does anyone else have that?
It’s normal for this headlamp. I’m a dealer for Cyansky and it’s on all of them due to a driver limitation
Updated version releasing later in the year
Thanx for the info!
What a shame for such an expensive light
It would have been nice to get the higher output, but it matches the new Nitecore HC65 V2 on range. The HC65 only has a dim white aux level, so imo it’s not really an issue.
You can see my review of the HC65 V2 in my signature and I compared it to the HS6R
I’ve seen it already, nicely done with those drone shots.Every review should be done this way
I also have the hc65 and hc65v2
