Thank you for your active participation. The list of winners we got through the random.org website is as follows:
1,#34 datiLED
2,#24 joebob4501
3,#47 Paul321
Congratulations! Please private message us to send your recipient information including name, address, phone number, etc. We will send the prize as soon as possible.
Thank you everyone. Have a great day.
Hi, Guys.
We plan to make a new all-metal headlamp. It is multipurpose but is different from the HS6R.
Questions:
When would you need to use headlamps?
What kind of headlamp do you want?
【Giveaways】Share your thoughts & Win an HS6R Headlamp (Value $74.95 )
Rules:
1, Leave a comment on ‘Cyansky 2022’ and your thoughts about the headlamp you like.
2, The Winners need to post a review of the HS6R on BLF after receiving the product.
3, Giveaway Period: 25th Feb – 15th Mar 2022
4, 3 Winners picked by random.org on 15th March (UTC+8)
Main use for a headlamp would be for working in confined (crawl) spaces. It would be nice if the flooder mode had a wide enough angle that I can see with peripheral vision if I’m about to bump my head.
Thanks for the GAW. I’ve seen the review of the prize-light on 1Lumen.com. If I win, it will be an honour to review it too, al be it a bit les outstanding (eh, the quality of my review).
Cyansky 2022
I want my headlamp to be an all purpose light, easily detachable from head strap for handheld using.
Other thing I want is it’s weight light enought to use single strap. I have some of 18650 headlamp that use single herizontal strap, they’re more comfortable and easier to use.
Multi-purpose? Then deep carry clip, headlamp mount works with clip attached, real moonlight mode, magnetic tail, high CRI, neutral tint, TIR, good IPX ratings for drop and water resistance.
Cyansky 2022
I like a magnet on a headlight / 90* so adjust where light is focused with a regular axel light it focuses one place only.
I like different battery tubes so I can get it as short as possible.
I like body colors, it can be hard to flashlight in dark.
High CR when I am doing something with my hands I like accurate color
I look forward to see what you make.
Cheers,
OS
I currently use an O-Light H2R and it works pretty well for me… Why? It has long runtime, a good floody beam and with the NW unit a decent tint. I have finally sold of all but one of my 16340 and 18350 lights that are used for more than show because runtime is something I heavily value.
I would like to see something in a right angle configuration running the latest XHP-50 emitter with a decent ramping interface that could provide low levels for battery duration and high levels for the crap hits the fan moments. When I need a head lamp, I need one for more than a few moments thus the importance of good level controls. I personally do not see a need for a red emitter, most of us are not soldiers trying to read maps, most of us are not pilots reading maps and I think for most of us range of output would be very valuable. I think that any offering should come with options for 4000k to 6500k emitters as folks like different things and in this day and age high cri should be a given. For me a very solid over the head strap is required to minimize having to adjust the band and location while working. A tailcap magnet would be a must for me as well and it would be great if the light clipped in or magnetically attached to the strap.
I use my headlamps for handwork and to walk around on the dark. For handwork I like a pure flood light with high cri at around 3500-4500 K, maybe Nichia 219b or 519A. For walking around, I like a throwier emitter, like SST20 in 4000K and also with high cri. Wood and leafs look better with good brown tones (high R9 for high red rendering).
I like clip mounts for the headband so you can take it off quickly. A magnet on one end is really useful, but maybe make it removable. Please place the switch so, that it will be on top of the light if it used with the headband, so you don’t push the light to one side, if you push the switch. I like lights with integrated charging. But make it water resistant (maybe hide it under a threaded piece), and use USB C.
Moonlight/Firefly modes (sub 1 lumen) would be great.
Thanks for the giveaway and for listening to the community.
I have the HS6R and it’s about perfect! However, if I could improve on it:
Easier to remove from headband/different retention method
Higher capacity 3100 or 3500 mAh 18650 battery
Higher output (1200 Lumen for spot, 1000 Lumen for flood LH351D high cri
2 amp charging
Power bank capability
Switch to SFT40 vs sst40 for spot LED
Use Samsung LH351D 4000-4500Kfor high cri
Switch dual SMD LED to red sst20
