My beloved Thrunite TH10 v2 has hit the dust. Looking for a replacement.
I use mine to spot wildlife - both large and small. These days I use it more so on my night walks to spot and photograph wildlife.
Have also started using it to help me nail focus for macro photography for much smaller critters.
I’ve looked at (on paper):
Armytek Wizard C2 Pro
Thrunite TH30
Olight Perun 2 (I think these run a propriety battery - not a fan as I run other lights and like packing spare 18650s)
Skilhint H04 and H300
Happy to spend up to $140ish AUD. Of course less the better. I guess I’m after throw not flood - happy to take advice on light temperature.
The wizard C2 pro as well as all other armytek headlights uses a beaded lens that produces a very wide smooth beam pattern with no discernible hotspot. It will sustain over 600 lumens. If you want a discernible hotspot and more throw then you do not want a beaded lens.
I’d say TH30 over H300. TH30 has more throw and better run times. I own one and it’s my go-to light. It is heavy, and has a very awkward UI, but I’ve yet to find anything else with its combo of throw, neutral (or warmer) tint, form factor (ie 1x18650 headlamp) and run time. If you can live with less throw than the TH30 I’d go for Zebralight H600C Mk IV over skilhunt. I’ve owned several iterations of skilhunt headlamps and always thought they were way over-praised.
