YAKORSER GD12 is made from Sofirn Factory, good build and performance ,For some reasons, the brand has suspended the project this year, and now it is clearing the stock GD12, the set is good value and package ,worth it.
GD12 built with tactical mode and outdoor mode, allows you to switch between them conveniently.
On tactical mode, Instant Turbo and instant Strobe can be activated from OFF, and you can swiftly switch between Low and Turbo, Turbo and Strobe.
While on outdoor mode, Moonlight, memorized output level can be activated from OFF, allows you to turn on the flashlight according to your circumstance, and hidden SOS get you prepared for the possible emergency.
Utilized 1 piece of Luminus SST40 LED, powered by 1 piece of 18650 Li-ion battery, GD12 emits 1600 lumens max output, and cast 200 meters beam distance.
I have some beamshots from my camera and drone I can share tomorrow.
Excellent model and was my first ever review. Superb build quality and an excellent beam profile. The only downside was the 6500k tint, but that’s personal preference.
Tested lumens using the included protected 18650 was spot on 1,600,and using a 30Q it achieved over 1,800
I attached my GD12 to a pressure washer wand for a few nights so I could finish a deck job after dark. Late in the evening was the only time I was able to work it so I needed a light. This GD12 is still alive and well to this day.
Haters are going to hate… But I contribute most of its durability to not having an outside charging port. Love that. I have battery chargers for charging a battery… Just my opinion!
Kinda sad to see this GD12 go. What is comparable to this build and UI? Sofirn SP31 is all that comes to mind.
