I hope you will offer several of the auxiliary colors for us to choose from. Maybe associate a different color auxil for each primary emitter choice: red with warm white, blue with cool white, purple for neutral whites.
You could also do limited editions with color anodized hosts to match the auxiliary color; green body with green auxiliary. many fun options lay ahead!
All look fantastic, ice blue and or orange and yellow are my favorites from these photos anyway. Very awesome project so far, great work!
Sure hope this has USB charging also, if not then let’s get a quick follow up for second light with a larger battery option with that onboard charging built in please.
Yes, Hank uses rgb’s but Wurkkos is, so far at least, planning to use single color leds like Fireflies does. I would love to see rgb’s used in this case!
Main thing the Aux should have is the ability to set them to high, low or off inside Anduril2.
My Emisar D4V2 lights look beautiful with full brightness on Aux, but I find that to be impractical. They are bright enough to light up my room at night and have significant parastic drain. On the other hand, the low brightness aux LED setting is perfect. Just bright enough to easily find the light when used as a bedside light.
Main thing the Aux should have is the ability to set them to high, low or off inside Anduril2. My Emisar D4V2 lights look beautiful with full brightness on Aux, but I find that to be impractical. They are bright enough to light up my room at night and have significant parastic drain. On the other hand, the low brightness aux LED setting is perfect. Just bright enough to easily find the light when used as a bedside light.
This is a standard feature on anduril 2 I believe...
You guys have to remember that this light is aimed at around 20USD.
RGB aux cost more and need more space. RGB literally means 3x LED and resistors and what not on the board to make them work.
You have to frankly come to terms with the fact that because of cost and space issues Wurkkos will most likely just produce one AUX colour for the whole batch. So choose wisely
good ideal for different aux colors with different tint choice, collect
Yes, our budget is $20, and single aux led seems the only option now, we will not only do one color, maybe 3-4 different
I doubt it would make much difference in cost really.
And I would guess that managing several SKUs would actually cost more.
Is the reason because you’re using a SOIC-8 Attiny85 ? (not enough pins for FET+7135 and RGB), if that’s the case then use a QFN-20 package, or you could even go Attiny1616 which has several advantages : it’s cheaper, has a factory calibrated temperature sensor, UDPI (only 3 pads needed for flashing, especially practical in the case of a small diameter driver here) and plenty enough pins for RGB. Sofirn sourced them for the SP10S Pro so I assume that wurkkos can too.
I think they are implemented as functions on andruil?
Is the reason because you’re using a SOIC-8 Atinny85 ? (not enough pins for FET+7135 and RGB), if that’s the case then use a QFN-20 package, or you could even go Attiny1616 which has several advantages : it’s cheaper, has a factory calibrated temperature sensor, UDPI (only 3 pads needed for flashing, especially practical in the case of a small diameter driver here) and plenty enough pins for RGB. Sofirn sourced them for the SP10S Pro so I assume that wurkkos can too.[/quote]
I’d love to see multiple colours available like in the original run of the E07. I think they had red, ice blue, purple and yellow? Something like that would be excellent. More often than not I’d prefer one colour rather than loads to choose from. I only mess around with my D4V2’s aux lights (and previously D4SV2’s) because they’re there. If they weren’t it wouldn’t be a big deal, ya know?
I chose YELLOW, though all of them look great. except Ice Blue, i am just not a fan. too bright not saturated enough.
I would be happy with Yellow, Orange, Red, or Blue / Purple.
through a couple of new FireFlies i have received, i honestly would rather have a nicely colored single aux more than RGB. I have gotten orange and yellow recently and they look MUCH better than the "orange" of any of my RGB setups, giving the light a more customized feel and look!
The WK10 will rename to TS10 seems it use anduril UI it will renamed in the TS series
www.wurkkos.com
Wurkkos Facebook giveaway/review Group
Wurkkos Deals Group
Wurkkos Facebook page
Wurkkos Amazon US store
Wurkkos Amazon DE store
Wurkkos Amazon UK store
Wurkkos Amazon FR store
Wurkkos Amazon IT store
Wurkkos Amazon ES store
Wurkkos Amazon JP store
Wurkkos Amazon CA store
Wurkkos Aliexpress Store
Wurkkos walmart Store
Blue for me
I was under impression that aux lights have rgb led in it and color can be cycled at runtime. Don’t Hanklights behave like that?
I voted orange.
I do like the orange, red, yellow and purple, more than green or cyan.
MY REVIEWS THREAD /// My Flashlight Collection /// YouTube Channel
Mods: 1 / 2 // TIR: 1 / 2 // Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 /// My Review's Blog (PT) /// OL Contest 2019 /// OL Contest 2020 /// GIVEAWAYs: 1 / 2 / 3
High CRI lights for sale
Oh they look great so far. Very excited about these!
That purp tho!
is there any significant change in parasitic drain (there should be)
I voted green, though I won't be buying the flashlight.
Looks like I'm in the minority with my color choice...
It's not easy being green.
How to Post Images on BLF // Many knives for sale (USA only)
How to move a thread
Voted ice blue to prevent red (best chance). All colors except primary colors R, G, and B are good.
Smile, you cannot kill them all.
www.wurkkos.com
Wurkkos Deals Group
www.wurkkos.com
Wurkkos Deals Group
www.wurkkos.com
Wurkkos Deals Group
yes, attiny1616 will be our choice
www.wurkkos.com
Wurkkos Deals Group
Ahaha, I’m a bit suspect, you know?
That’s good to hear, but what is the limitation for RGB then ?
I imagine soldering the wires costs money. Three times the chance to mess it up.
The $20 budget seems tight.
thats just my opinion!
Orange
purple and Orange
orange and yellow
[FLF] Five Light Friday https://budgetlightforum.com/node/78749
Check out some of my new lights (picture heavy) and quick first impressions of them here: https://budgetlightforum.com/node/77180
My Sft40 beamshots / comparison thread: https://budgetlightforum.com/node/78100
The BLF GT with SFT40 (2300lm, 2700m+ @ 30 seconds!)
https://budgetlightforum.com/node/79561
Purple, pirple, perple
Impossible to choose. Red, orange and yellow sure are nice, but depends on the body color which one of those will be my favorite.
I reeeally dig purple!
But I think I read something somewhere recently that purple aux lights have the worse parasitic drain?
It's the worst on your eyes and the least efficient...but certainly the most beautiful.
