Hello, guys, this is John from ledbe.com, now we added more new LED Drywall Channels for your interior design.
For more information, please check here: LED Drywall Channels For Plasterboards, Sheetrocks
Black recessed Channels with anti-glare design, 1M and 2M length available, the max length can do 6M and cuttable, there are 3 types of diffusers available, PC diffused cover, PC Semi-clear cover and prismatic cover, the inner width is 13.4mm, easy to install SMD LED Tapes and COB LED Strips inside.
Check the Recessed Light Fixture Housing for drywall, which are made of 6063-t5 extruded aluminum material and with anodized surface treatment, there are 3 colors available, the default color is silver, you also can take white and black colors. the standard length is 1M, other lengths are available: 1.5M, 2M, 2.5M, 3M and max length 6M. there is only one type of diffuser is available, the PC diffused cover, which is made of imported brand material, anti-yellowing, perfect light distribution and smooth light output. the inner width is 10.5mm and allows the max width of LED Strips is 10mm. recommend installing the COB LED Strips to create a seamless line of lighting for indoor projects.
Features:
Model: ALP068-SR1
Material: 6063-T5 Extruded Aluminum
Surface Treatment: Anodized
Colors: White(Default), Silver, Black
Standard Length: 1M
Other Lengths Available: 1.5M, 2M, 2.5M, 3M And Max 6M
Custom Lengths Available: YES
Diffusers: PC Diffused Cover
Inner Width: 10.5mm
Max Width Of LED Strip Lights: 10mm
Max Power: 12W/M
Beam Angle: 100°
Tolerance: ±1%
IP Rate: IP20 Non-waterproof
End Caps With Wire Holes Included
90°, 90° Vertical And 180° Connectors Sold Separately
LED Strip Lights Not Included
Installation: Recessed Into 12.5mm Drywall Or Plasterboard
5 Years Warranty
The ALP129-O is the recessed LED Housing for 12.5mm outside corner installation, the standard length is 1M and max length can do 6M, you can cut to any length for your project, the inner width is 5.5mm and allows the max width of LED Strips is 5mm, recommend installing the COB LED Strip Lights inside, no visible light dots and dark areas. the compact design allows for a seamless plaster-in installation inside the 1/2” drywall without having to modify framing, easily recess in walls, ceilings and tight spaces or corners to cast beautiful, diffused and even lighting throughout your space. the LED Light House with flanges and the flanges with honeycomb holes, easy to mount on the wall with screws, plaster and painting on the drywall.
the Drywall LED Channel for inside corner of 12.5mm drywall plasterboard, the standard length is 1M and max length can do 6M, you can cut to any length for your project. the inner width is 5.5mm and allow the max width of Flexible LED Strips is 5mm, recommend installing the 3mm, 4mm or 5mm COB LED Strips as the light source.
ALP071-S Trimless Recessed Lighting Channels, the standard length is 1M and max length can do 6M per piece, cuttable and you can cut to any length for your project. the inner width is 20.7mm and allows the max width of LED Strips is 20mm, easy to install a single row or multiple rows COB LED Strips as the light source. only PC diffused cover available for the smooth light output, no visible light dots.3 types of connectors sold separately, you can use them to reconnect the LED Light Channels together and use for the lighting project from ceiling to wall.
Link: Plasterboard Trimless Recessed Lighting Channel With Diffuser
The ALP084-S Recessed LED Strip Light Fixtures, which with a single flange, the flange with small round holes, which easily can be recessed into the wall or ceiling for indoor linear lighting, plaster and paint on. the standard length is 1M and max length can do 6M, can be cut to any length for your project. the inner width is 13.9mm and allows the max width of LED Strips is 13mm, recommend installing high-density COB LED Strip as the light source, no visible light dots and dark areas, brighter and uniform light emission.
Link: Recessed LED Strip Light Fixtures With Single Flange For 5/8 Inch Drywall
The Low Profile LED Strip Light Channel has a height of only 7mm, and the spring clips are included, easy to mount on the wall or ceiling, and adjust the lighting direction. The Low Profile Channels are made of 6063-T5 extruded aluminum material and have anodized surface treatment, anti-oxidation resistance, and a longer lifespan than similar products.
The Super Narrow Flexible COB LED Stripe is an excellent choice for indoor applications where space is limited, especially in tight corners and spaces. The width of the LED Stripe Light is only 2.7mm, thin and flexible, with a high-density LED design, making it easy to install in difficult-to-reach places.
Link: https://bit.ly/3EvcMzF
