Can I Use These 18650's In My Flashlights? (First Time Makita Batterypack Pull)
Edited
So first, Ive never pulled cells out of anything before.
If I were to clean the ends of these up, and re-wrap them, (all but two have damaged or no wrap) could I charge these up and use them in my flashlights? (All at 3.43v)
A Makita Batterypack was left at my house by contractors over a year ago and I finally decided to pull it open, to find five 18650s bearing the code SE US18650VT.
With a quick google search, It looks like its made by Sony.
So far, having only really looked at the link above. It seems like a decent cell?
Pretty low capacity, but may be relatively high drain?
I mean, it was in a battery pack for a drill, so I would think it should be pretty capeable?
Should be good?
Be extremely careful with any unwrapped li-ion cells. The ones with complete wrapping should be good to go for charging and use in an 18650 format flashlight. Clean up spot welds carefully, maybe with a dremel type rotary tool if you'd like.
Thanks.
I do understand the dangers of unwrapped cells. But thats about all I understand here.
Some further reading here about this cell shows its pretty dated.
This Quote is from 2015
I cant do any kind of testing other than checking their voltage.
Is there anything that may make these dangerous to use?
I dont know much about Internal Resistance, but have a vague idea it might be something relevant here?
Yeah, you can use these just fine.
Be wary they’re old low energy cells :stuck_out_tongue:
Would be interesting to capacity test them but yeah they will work fine.
I have the same multimeter
Yes:
If they were mine I’d use them since you have them and the price is right. Just know they are low capacity cells so carry a spare with ya if you plan on using the light long term.
Im gonna assume youre in Canada then. Since its from Canadian Tire lol
I'd charge them and do what we used to do without testing equipment .
Note voltage when fully charged .. let them sit and check voltage at
one hour ...one day ... 3 days ..one week ... 2 weeks
maybe do the same with a known good battery to have a baseline .
I'd toss any cell that got hot while charging or didn't fully charge up .
i would be interested to see pictures of both sides of the circuit board in that battery pack, if you cared to investigate further.
Thanks everyone.
I’ll test them as Boaz has described.
Ha, since I forgot to take the trash out this morning… I can take those photos for you.
they are low energy
i also would not expect them to be high-drain either
and they may be well into their max cycle life span
@CRC2, thanks for the pictures.
Yes and yes.
So I cleaned the ends up, and charged the four that still have their wrap intact.
Put them on the charger at 1:55pm (3.43v) at .5A.
They all finished at roughly 4:25pm at 4.19v/4.19v/4.18v/4.17v with about 1100mah added to each.
All good so far.
Will test voltage again in an hour.
Unnecessary photo.
I wish I could reach into the photo and pull the green tab and remove the protective film off the screen. :slight_smile: Just me?
Just checked their voltage again after an hour.
Cell #1 Went from 4.19v to 4.16v
Cell #2 Went from 4.19v to 4.16v
Cell #3 Went from 4.18v to 4.15v
Cell #4 Went from 4.17v to 4.15v
Still good so far.
Will check again in 24 hours.
They appear to be fine as far a usability — but even new these cells are much to talk about — I had those same cells in a 12v Ryobi drill pack — replaced with VTC6 cells — drill now has 3 times the torque and capacity
Your Makita Sony cells are 9 years old.
