Convoy Red driver with 12 groups UI (Now Available!)
34 posts / 0 new
Funtastic
Funtastic's picture
Last seen: 2 days 18 hours ago
Update 23/06/22: 12 Groups Driver is now available
Update 1/06/22: 12 Groups Driver is currently in production and should be available within 2 weeks!
Simon is looking into getting the 12 groups firmware onto the Red LED driver for my store, would anyone else have an interest instead of the 20% & 100% modes currently on it?. I sell to hunters for mounting on their rifles and the 20% level is far too dim and the 100% level can be way too intense for under 100m with the C8+, even worse for the longer range L21B. Currently the L21B with red osram can’t be used on anything less than 250-300m otherwise the deer take off.
I had previously asked for the Ramping UI, but I think the 12 groups would be more popular with others. The pro with the Ramping UI is hunters being able to set a custom level and then it’s basically on/off at your set level.
Piercing The Darkness YouTube channel – https://www.youtube.com/c/PiercingTheDarkness
Edited by: Funtastic on 06/22/2022 - 21:48
flightless22
flightless22's picture
Last seen: 4 hours 16 min ago
Of course. 12 group would be preferred.
Verodin
Last seen: 14 hours 54 min ago
Yes, would love to have the UI matching the other coloured Osram emitters.
Kakapo
Last seen: 30 min 3 sec ago
It would definitely be a better option. All lights should have the full set.
Lixivium
Lixivium's picture
Last seen: 1 day 14 hours ago
Yes, 20% or 100% isn’t ideal. I assumed there was some reason for these limitations. Is there not?
Auxilshunter
Last seen: 2 days 9 hours ago
I just used the red osram for coyote hunting. My friends liked it so much that we have ordered 3 more. Great light but more mode options would be great.
Thanks!
id30209
id30209's picture
Last seen: 11 hours 20 min ago
Yes! I’m in.
WTB Titanium 4sevens 2xAA tube
captainkirk
Last seen: 4 hours 24 min ago
Yes, the 12 mode would be great for a red light.
This space for let.
LunaLoves
Last seen: 7 hours 43 min ago
Or you get a 12 group 8×7135 driver and remove a couple of chips.
Works in more than one of my torches
Nooner
Last seen: 4 hours 43 min ago
I’d definitely buy a few if they were offered for sale.
bobvoeh
bobvoeh's picture
Last seen: 2 hours 54 min ago
Definitely interested. I’d like to build a deep red light with more options than just high and low.
mcflies
mcflies's picture
Last seen: 2 days 5 hours ago
Yes. It's the reason I haven't bought one.
stephenk
stephenk's picture
Last seen: 4 hours 59 min ago
It would good for the CSLNM1 red driver to be consistent in UI with other S2+ 12 group/Biscotti.
Not sure if I would personally justify replacing my existing S2+ with CSLNM1 red though, as I tend to allow the thermal regulation to do its thing anyway.
tactical_grizzly
tactical_grizzly's picture
Last seen: 5 hours 19 min ago
YES. Please put the 12 group firmware on the driver for red LED’s! Currently I’m using an 8×7135 driver instead of the dedicated red driver just so that I can have the 12 group firmware.
LunaLoves
Dumb question, what do you dislike about using the 7135 driver?
The only downside should be slightly less battery runtime due to a lower efficiency and maybe a slightly warmer torch
CRC2
CRC2's picture
Last seen: 5 hours 58 min ago
I was all set to grab a C8+ and S2+ with red emitters, but changed my mind when I saw they only had 20% and 100% output modes.
I would definitely be interested again if they were to come with a 12 group driver.
Not the brightest flashlight in the collection.
tactical_grizzly
I’m not sure. I assume that Simon would not make a dedicated red driver unless there was a good reason for it.
id30209
id30209's picture
Everyone using other than 2.5V driver, your emitter won’t run long.
This post is entirely about 2.5V driver but 12group.
Running normal 3V driver is not recommended.
LunaLoves
The 7135 driver limits the current though, you could use a 1V LED with it and it’d be fine.
The voltage (curve) of the LED is current dependant, not vice versa.
id30209
id30209's picture
The 7135 driver limits the current though, you could use a 1V LED with it and it'd be fine. The voltage (curve) of the LED is current dependant, not vice versa.
Oh ok. You might be right (probably you are). I’m not much into electronics nor i like understand them. Can solder some but that’s it. Why i was so specific about V and A is the fact red emitter needs lower Volts to work correctly. No idea how Nanjg works…
Funtastic
Funtastic's picture
You are partially correct, it’ll give okay runtime, just not long at a higher output, the 2.5v red emitter is not ideal on a 7135 driver since it’s designed for a higher Vf. I was also told it’s quite hard on the chips
For others who say it’s a non issue, why would Simon design a dedicated 2.5v driver for the Osram red if the 7135 driver worked perfectly fine?
C8+ osram red using 8*7135
L21B osram red using the 2.5v driver
Funtastic
Funtastic's picture
Fairly certain it was used because most other red lights only use a low, high, and beacon
stephenk
stephenk's picture
It is actually quite difficult to visually tell the difference between 20% and 100% modes.
LunaLoves
We’re running parts way out of their specs in torches daily, Eg overdriving LED’s etc
Will it break after 2000hrs of use?
Yeah, probably, because they’re running very out “burning” that much excess voltage.
Will it be less efficient?
Yeah
Those factors matter when you use torches for more than playing around like hunting, which is why Simon probably designed a dedicated step down driver with the most common modes used by hunters or similar
Funtastic
Funtastic's picture
Yes, there’s no visual difference at all, you’re completely right…just kidding, you’re saying you can’t tell in the video?
tactical_grizzly
I find them easy to distinguish. Having a lower mode than 20% would be very nice though, and significantly easier to distinguish. The 0.1% mode on my 8×7135 driver is delightfully low.
bobvoeh
bobvoeh's picture
A “Moonlight” mode for the red leds would be great.
CRC2
CRC2's picture
Im a bit confused about flashlights using red LED’s.
Ive been looking at a bunch recently, and it seems like most are very mode limited. Especially Convoy.
Yet Emisar/Noctigon flashlights can use red LED’s with Anduril/full range stepless ramping?
Funtastic
Funtastic's picture
bobvoeh
bobvoeh's picture
Thumbs Up
tactical_grizzly
Woohoo! Awesome!
