Product Parameter: Material: Red copper The item size: Extennal Diameter:25.4mm Length:92.5mm The weight:173g (no battery) Surface color:Original red copper color(user can make to old bronze as they like) Copper base plate:Electrothermal separationcopper base plate can make the heat dissipation more fast. Lens:tempered bule-coated lenses(The transmittance reaches 98%) Lamp Bead model: 3*SS-T20/3*XPL hi Battery model:1*14500 Battery Reflector:3*Netherlands imported LED convex mirror. Low voltage prompt/Reverse polarity protection/Mode memory: Yes Auxiliary light: Half-Pressing the tail button can turn on auxiliary light,and the auxiliary light has red, green, blue three colors be selected Switch mode: Tail mechanical power-off reverse switch (Press: on/off flashlight. half-press: Switch gear and function) Dimming mode: 5 different brightness—stepless dimming mode-10 different gears with different combos (high playability, see the operation manual for details) Package contain:1*flashlight(no battery and charger),1*stainless steel Clip,2*M3.0 stainless steel screws,1*silver grinding rod
There is a battery charge head can match with this model
I don’t think it’s actually built in charging. It is listed as an alternate “charge head”.
Looks to me like you unscrew the main head of the light and then screw on the alternate special head containing just the charger. Not a bad idea actually, since the charge head is a lot smaller than a full-size charger.
You are definitely right.
It’s always fun sifting thru their info, this model at one point had an Amazon page that said 18650 and xp-l
It was actually 14500 and sst20 .
I’m not bashing they do much better with English than I do with any other language.
