This is a fantastic budget friendly headlamp with a robust feature-set. Compact and lightweight H50 2.0 headlamp equipped with floodlight,spotlight, or dual beam with a max output of 2,000lumens.141 meters long range coverage and 170° wide range flood light specially designed for industrial maintenance,caving rescuing,climbing and mountaineering.
✅ Utilizes 3 x Luminus SST-20 LED(Neutral White 5000K)
✅ Equipped with the customized TIR optic lens, can reflect uniform and soft light
✅ 180° tilt angle for different illumination needs
✅ Including one 18650 high capacity Li-ion battery and compatible with 2 x CR123/16340 batteries
✅ Built-in the concealed USB-C charging port is effectively protected against the complex outdoor environment
✅ USB-C Rechargeable Approx. 2hours 30 min to fully charge
✅ One button interface controls 5 brightness levels, 3 light sources and 1 SOS special mode
✅ Highly efficient constant current circuit provides a stable output of up to 30 days
✅ The power indicator beneath the switch can indicate the remaining battery power
✅ Rating in accordance with IP68 (2 meters submersible),All-weather applicable
ACEBEAM headlamp is the first choice by China Expedition.
Learn more: https://www.acebeam.com/wide-beam-led-headlamp-h50
Exclusive Coupon to BLF members: BLF10
sales@acebeam.com
ACEBEAM ► https://www.acebeam.com
FB ► https://www.facebook.com/AcebeamWorld
FB Group ► https://www.facebook.com/groups/acebeam
Ins ► https://www.instagram.com/acebeamofficial
YTB ► https://www.youtube.com/c/ACEBEAM/featured
Tiktok ► AcebeamFlashlights
Official Amazon.US ► https://www.amazon.com/acebeam
Official Amazon.UK ► https://www.amazon.co.uk/acebeam
Official Amazon.JP ► https://www.amazon.co.jp/stores/page/EE561FA1-BA6E-4805-A1A7-EE51EB77531C
Official Amazon.DE ► https://www.amazon.de/stores/page/8BBF5CD3-D851-4CDF-BDA8-5FD46B35044A
Official Aliexpress ► https://www.aliexpress.com/store/5879734
What bin or part number are those SST20 5000k high cri >90?
I’ve never seen a high CRI SST-20 in 5000k. Luminus doesn’t have any listed in their product data sheets.
The Luminus high CRI (95) SST-20 product family (SST-20-WxH) only goes up to 4000k.
The Luminus low CRI (65) SST-20 product family (SST-20-WxS) are the only 5000k models Luminus offers.
Source: https://www.luminus.com/products/white
Could this simply be a typo in your product description ACEBEAM? If so, is the typo “5000k” or “High CRI>90”?
Yeah, I said it in another thread in a similar way.
Unless Acebeam made a very large semi-custom order(totally possible for a company their size), then it has to be a typo.
Hopefully the typo is “5000k” and they just meant to say “4000k”.
If it turns out that they just released a light with the god awful low CRI green tinted SST-20 5000k that’s an unforced error.
H50 2.0 utilizes 3 x Luminus SST-20 LED(Neutral White 5000K)
sales@acebeam.com
Green, low CRI.
Better to be used LH351D with new 519A in that headlight.
You can't compare the big flashlight in the sky to the little flashlight in your hand.
