cr123 vs energizer l91 as power source?
11 posts / 0 new
monkeyman77
Last seen: 5 min 2 sec ago
which would you choose if at same price? is it me but do the 123s have the abilrt to give more amps?
raccoon city
raccoon city's picture
Last seen: 5 hours 52 min ago
Location: Palm Desert CA ~ West Coast is the best coast
Hmm...
Good question!
I haven't researched this because I try to use rechargeable batteries whenever I can.  8^)
monkeyman77
me to im thinking back ups i have like 15 16340s they are more bright for sure
ChrisGarrett
ChrisGarrett's picture
Last seen: 7 hours 49 min ago
CR123As are specked at ~1.5 amps, so I would imagine the L91s to be a bit more.
For 5A, Eneloop Pros, or the Fujitsu equivalent, would be the answer.
Chris
monkeyman77
my 1 × 123 lights are brighter then my zebra aa light with l91s in it. the zebra should make 550 lumens but it dont with l91. hardly does it with my eneloops
ChrisGarrett
The Zebralight SC5 is specifically tailored for the Eneloop Pro, which can handle the load.
I really can’t speak to the L91, as I don’t own any high drain AA lights.
I do have a ZL SC52, but it’s not too hard hitting.
Chris
jon_slider
jon_slider's picture
Last seen: 7 hours 6 min ago
L91: 1.5 Volts, 3150 mAh
CR123: 3 Volts, 1550 mAh
I think it is more difficult to find CR123 in a grocery store, than L91, and AA, so for a shtf light, I would choose L91, not CR123.
also, since Im an Anduril fan, I would buy the L91, not CR123
there is No anduril light that runs on CR123
The SP10 Pro will work on L91, and also AA, so it is much more versatile than a CR123 light.
monkeyman77
i run my emisar d4v2 on 123s. but not as bright a course
jon_slider
That only works when the CR123 battery is full. It also works in the SC21 Pro.
BUT: Anduril will shut off the light at 2.5v, so it will not be able to take advantage of the remaining capacity in a CR123.
Desertcat
Last seen: 4 days 7 hours ago
https://data.energizer.com/pdfs/123.pdf
https://data.energizer.com/pdfs/l91.pdf
Keep in mind the voltage difference when thinking ‘power’.
Generally the specific light determines which I use. I only have one that can use either (SL Protac 1L-1AA, and I generally use LFP 16340 in it for routine use, as it’s rechargeable and provides higher output (@~3V vs ~1.5) than ‘AA’ in that light).
Although you didn’t mention NiMH, I’ve never been able to find similar level of ‘proper’ output current (discharge – continuous/pulse) specs for Eneloop – and I have looked around more than once. If anyone has a link to such, please post it.
wle
wle's picture
Last seen: 15 hours 29 min ago
i have used those l91 type ‘ultimate lithium’ and i find them to be horrible
they seem to hold full volts no matter what
then you try to use them and find they have no energy left – very high impedance at end of life
i would WAY more trust CR123A cells than those things
    Daniel Behrman, "The Man Who Loved Bicycles".
-Greg Lemond.
