How about this: the more batteries/cells you own, the more the possibility will occur that one of those will fail. The more you will be inclined to monitor your batteries/cells.
And if you own more batteries/cells, you’ll probably also own a bigger charger.
Personally speaking this is my wishlist of an analyzing charger:
4 slot
4x 26800 compatibility
4x 2A or 3A charging
Internal resistance measuring
High quality rails and contacts
Temp sensors (Per slot cell temperature and device temperature)
Analyzing and capacity function with 1A discharge per slot if possible
Storage charge/discharge function
Nice LCD screen
Updatable firmware if needed
Included power supply (65w USB-C QC or PD input would be wonderful, but may be unrealistic)
I have the Miboxer C2-4000 which is a 2-slot analyzing charger. It is ok as a charger but the internal resistance reading is a joke. It always reads high internal resistance and consequently steps down the charging rate. That said, it’s still my every day charger and has never failed me.
I think it´s easier to make a 4-bay-charger with this functions because:
- more space for a big display
- more space for big discharge-resistors
- lower temps
ppl would spend generally more money than for a 2-bay-charger
The S4+ needs IMHO enough time for testing cells (especially the bays 2+3 which allow max. 0,5A discharge), less slots = more time for test
Would be nice for me if all bays are on “max Power”
If 6-8 bays means the charging or especially the discharge function is set on lower current it would be not interesting for me. Who needs a bigger charger if the test of 8 cells needs the same or more time than the 4-bay?
I really like this summary. I would add that each slot should be current controlled by the user with a reasonable default setting. I really do not like chargers that assume a big body battery, well then let’s charge it hard.
I am also not a fan of more than 4 slots due to weight and size. I value taking my best charger with me when I travel and 4 slots is enough for a travel charger.
I have the idea of making a 2-3a fast charging, 0.5-1A discharging 2-slot charger, or compatible with various chemical composition batteries, but it is expected that the market is not good, so the scheme may be eliminated
If you can make this for 50% or even 40% of the cost of the S4+, but keep most of the functionality of the 4 slot model (maybe add 26800 size slots to the 2 slot version…4A charge each?) Then I think you would he successful in sales. Currently only 26800 size chargers are very basic and only a single slot.
I think a 4-slot-model is the best solution, not sure how other ppl interested in a 2-slot-model with many functions because it´s maybe not much cheaper than a 4-slot. And I charge often many cells, so it would only cost time and nerves.
I´m fine with more slots if it can charge/discharge at speeds like the S4+ and which moderate heat (fanless). I have enough chargers to not move around with the big chargers
But dunno how big the market is for an huge 8-slot-charger. I think if many ppl needed it, more of these chargers would be available.
