This just arrived from Manafont an hour or so ago. It's an R5, makes a good candle and came in a box! You can get it for a bit less if you pass on the box.
It's bright - brightest AA light I have on a 14500, the Trustfire R5-A3 is brighter on an NiMH.
Lightbox | Lightbox | Lightbox | Est. lumens | Est. lumens | Est. lumens | Throw | ||
Light | Battery | Immediate | 30 seconds | 2 Minutes | switch-on | 30 secs | 2 Minutes | Lux at 1m |
Ultrafire U20 | 14500 | 1647 | 1575 | 1534 | 295 | 283 | 275 | 7000 |
Ultrafire U20 | AA NiMH | 575 | 618 | 608 | 103 | 111 | 109 | 2540 |
It even came with a manual - in Chinese.
The box
Never heard of "aluminium allay" before.
The light even came with a Duracell in it. That was a pleasant surprise.
The light. There is light crenellation on the bezel but it isn't sharp. I like this so you can see when you have left the light turned on. It won't rip clothing unlike some bezels.
The engraving on the back isn't very nice. It just doesn't look right somehow.
It definitely has an XP-G in it and the reflector seems to be well centred.
It actually makes a pretty decent candle. It tailstands nicely and with the reflector removed in a headband it'd make a truly wonderful headlamp. Downside of the design is the pill is hard to get to. The black ring round the LED doesn't seem to want to come out by fingernails ad it is a new light so I've not tried seriously to pull it out. The hollow in it also centres the reflector.
Candle mode
Tailcap and reflector back. The switch mechanism seems to be held in by some sort of plastic goop.
It has O rings in the right places and they seem to be doing their job.
And finally, here's a ceiling beamshot.
The beam is a bit odd - I can distinguish seven separate rings. I very much doubt it'll make any difference in the real world.
