Weltool New products 2022
35 posts / 0 new
Weltool
Weltool's picture
Last seen: 2 weeks 2 days ago
Weltool T2 EDC LED Flashlight
T2 is a compact portable LED flashlight, using 1 18650 Li-ion battery or 2 CR123A batteries, full power output mode 1,730 lumens, 42,450 candela, throwing 412 meters, there are three brightness modes, full power output mode is suitable for short-term emergency use, The medium mode is suitable for outdoor, and the low mode is suitable for indoor or close lighting. The T2 light head adopts Weltool's patented T-HC (Through-Hole Cooling) structure, which releases the heat generated by the LED and electronic components from the light head to the environment in time through air convection. The bezel is made of stainless steel with attack teeth, which are wear-resistant and drop-resistant, which can effectively protect the flashlight head. T2 has a mode memory function, and has reverse battery protection, low battery reminder function and battery over-discharge protection function. It comes standard with a stainless steel pocket clip, which is easy to carry. T2 has strong performance and simple structure, and can be used as emergency equipment carried every day.
Weltool official link: Click to view
Edited by: Weltool on 07/24/2022 - 22:43
Weltool
Weltool's picture
Weltool T2 uses aluminum alloy reflectors with high reflectivity, high temperature resistant LED gaskets, Luminus SFT40 high-intensity LEDs, stainless steel Abrasive blasting bezel, through-hole cooling structure, not only these, but also ultra-low internal resistance forward switch, can handle 10A current, low internal resistance phosphor bronze spring,high drain 18650 battery.
The flashlight has battery over-discharge protection (when using lithium-ion battery), battery reverse connection protection, low voltage reminder function, memory mode function.
No flicker and noise
Patented through hole cooling structure
Battery type: 1 high drain 18650 lithium-ion battery or 2 CR123A batteries
IP67 level, can be used in heavy rain
Passed the 1 meter height drop test
Each flashlight has its own serial number
Weight: 95±1g (without battery)
Dimensions (±0.5mm): (Head diameter) 26.5mm, (Body diameter) 24mm, (Length) 135mm
Included: Weltool 3000mAh high drain 18650 Li-ion battery, charger,O-ring, stainless steel pocket clip
Weltool
Weltool's picture
Weltool T8
Weltool
Weltool's picture
Weltool W1
Weltool
Weltool's picture
Weltool T2R
Weltool
Weltool's picture
weltool w35l
Weltool
Weltool's picture
weltool t14
Weltool
Weltool's picture
weltool t20
Weltool
Weltool's picture
weltool t18
Weltool
Weltool's picture
weltool t18
Weltool
Weltool's picture
weltool t18
Glenn7
Last seen: 9 hours 42 min ago
Think you are missing some pix?
Weltool
Weltool's picture
Hi ,Will update as new models become available
Bwana
Last seen: 14 hours 24 min ago
Let me know when you update new discount coupons
Ventsi
Last seen: 14 hours 15 min ago
Weltool T2 – very good looking light with absolutely no information about the UI, not to mention lack of simple battery level indication. Sorry if I’m picky but it’s 2022.
bobvoeh
bobvoeh's picture
Last seen: 2 hours 30 min ago
I think most of us would also like to know what specific emitters are installed in your lights.
id30209
id30209's picture
Last seen: 8 hours 15 min ago
Visible in many photos, SFT40 mostly
WTB Titanium 4sevens 2xAA tube
Weltool
Weltool's picture
Ventsi wrote:
Weltool T2 - very good looking light with absolutely no information about the UI, not to mention lack of simple battery level indication. Sorry if I'm picky but it's 2022.
Not everyone likes complex functions, and stability and reliability are often pursued by many people.
Weltool
Weltool's picture
Yes, this is a Luminus SFT40 LED
Mstevens113
Mstevens113's picture
Last seen: 28 min 11 sec ago
Looking at 21700 to replace my 18650’s now. Brightness is at the point of diminishing returns, I’m more interested in being able to maintain power for longer.
gravelmonkey
Last seen: 14 hours 3 min ago
What’s going on in pic 15 of the T2… Is that a paintbrush??
Knurling and body design looks good, I first saw the pattern around the head and hoped it would be a rotary ring Crying
Ventsi
Battery level indicator is a complex function? OK…
I have many lights with battery level indicators and they have been pretty stable and reliable, maybe look at your products before taking hits at the competition that is already in the 21st century, thanks.
timbo114
timbo114's picture
Last seen: 10 hours 46 min ago
Quite handsome torch – robust and tactile.
I’ll buy one when the price is reasonable.
LumenMax
LumenMax's picture
Last seen: 7 hours 52 min ago
It doesn't have to be a complex one. It could be an indirect battery indicator like the tail switch of the Lumintop Tool AA. It is lit when the voltage is still high. When voltage is low, the light in the tail switch turns off.
hIKARInoob
hIKARInoob's picture
Last seen: 11 hours 2 min ago
I really like the design, well done! I would like to know more about the Through Hole Cooling design. Perhaps there is like a cross section illustration?
flashflood
Last seen: 22 hours 6 min ago
Same here.
Double 18650s are long, triples are thick, and multi-cell in general can be a pain.
26650s somehow never lived up to their promise — a much bigger cell, but very little difference in actual capacity.
21700s are just the opposite: only slightly bigger, yet nearly double the capacity. Love them!
Single-cell 21700 lights have become a real sweet spot in EDCs.
Weltool
Weltool's picture
Mstevens113 wrote:
Looking at 21700 to replace my 18650's now. Brightness is at the point of diminishing returns, I'm more interested in being able to maintain power for longer.
You can follow our upcoming T8 and T8Plus
Weltool
Weltool's picture
gravelmonkey wrote:
What's going on in pic 15 of the T2... Is that a paintbrush?? Knurling and body design looks good, I first saw the pattern around the head and hoped it would be a rotary ring :((
The head doesn't have a rotating ring, that's the cooling trough
Weltool
Weltool's picture
In fact, it is difficult to accurately judge the battery voltage in this way
Weltool
Weltool's picture
Ventsi wrote:
Battery level indicator is a complex function? OK... I have many lights with battery level indicators and they have been pretty stable and reliable, maybe look at your products before taking hits at the competition that is already in the 21st century, thanks.
If we set an indicator light, then of course there is no problem, it is not very complicated. For example, our upcoming T2R has an indicator light.
If the voltage is prompted by pressing the switch and the light flashes a few times, we think it is completely unnecessary and inaccurate.
In addition, any product has a corresponding customer group, and no one product can meet the needs of all customers.
Weltool
Weltool's picture
timbo114 wrote:
Quite handsome torch - robust and tactile. I'll buy one when the price is reasonable.
Thank you,sir
