Small(ish) Floody Flashlight With Good Throw and Long Runtime
50 posts / 0 new
meeshu
Last seen: 5 days 2 hours ago
Looking at getting a floody handheld flashlight that also has some reasonable throw as well. Also, the light should have a long runtime.
Prefer light that uses just ONE cell. Not sure what cell size, but probably 21700 as a minimum, and maybe up to 26650 size cell?
Prefer light that can use any appropriate sized cell (from above, ie 21700 or 26650 etc) and NOT be restricted to proprietary cells only.
Light MUST have mode memory.
Light MUST be relatively small and can fit in pants pocket.
Light beam angle should be at least about 50°.
Light throw should be at the very least 30 meters.
Runtime at the 30+ meter throw should be at least around 6 hours.
Flashlight price no more than around US $100.
One light I was looking at was the Imalent MS03. But there are a few things that I'm not happy with this light about.
1) Price. The Imalent is just a bit too expensive.
2) Proprietary cell only. This limits what cells can be used in this light. Especially not good in the event the proprietary cell fails and being unable to use more readily available similar sized cells.
3) The runtimes at various throws are a bit too low.
So, the light I'm after should be fairly similar in size and style as the Imalent MS03, but with better throws/runtimes.
EDIT: All lights for consideration MUST have detailed manufacturer specifications to verify data.
Minimum required manufacturer specifications should include - Lumens, Candelas, and runtime. Light throw would be peferable as well but not critical as this can be calculated from Lumens and Candelas.
Flashlights: Sofirn - SP10 V3, SP10 Pro, Lumintop - Frog, EDC AA, EDC AAA, JETBeam - JET-E01R, JET μ, JET I MK (sold), Klarus Mi1c, Mi10 (unused), 3 x Manker E11 (all faulty!), 2 x iTP SA1
Chargers: Zanflare C4, Vapcell S4+ V2, OPUS BT-C700, 2 x SkyRC NC2200, Liitokala Lii-600, 2 x iSDT C4 EVO, Miboxer C2-6000, 2 x Miboxer C4-12, iSDT C4 (sold), 2 x OPUS BT-C3100, OPUS BT-C2000, LaCrosse BC-900, Voltcraft IPC-1, Tenergy TN268, plus a few smaller chargers
Edited by: meeshu on 07/25/2022 - 11:03
Sk9
Last seen: 1 day 17 hours ago
Convoy m21f with xhp70 or gtfc40.
acobp
acobp's picture
Last seen: 2 days 3 hours ago
Convoy S2+ or S21 with sft40 or eventually sst40.
Solid throw with good sidelight.
Quadrupel
Quadrupel's picture
Last seen: 1 hour 46 min ago
Emisar D4V2 Boost driver + floody TIR
ch1ir
Last seen: 2 hours 38 min ago
Emisar D1v2 w/ GT-FC40 emitter
meeshu
Comments noted thank you!
Regrettably, Convoy lights are not suitable as there is no technical specification available (apparently) for these lights for me to verify light data.
Similarly, Emisar lights are also not suitable due to lack of technical specification. Some information is available but is very limited; not enough information is provided.
Lights for consideration MUST have manufacturer specifications to be available with at least the Lumens, Candelas and runtimes to be quoted. Light throws are also useful, but can be calculated if that information is not available.
I've edited my first post to clarify my requirements.
Thank you.
Rusty Joe
Rusty Joe's picture
Last seen: 12 hours 20 min ago
Fenix PD35 with sft40?
Quadrupel
Quadrupel's picture
Good luck buying specifications…
meeshu
Thanks for the suggestion, but this light has only a beam angle of 15°. This is a tight spot beam which is not suitable for my purposes. The light I'm after should have a beam angle of close to or greater than 50°.
Lixivium
Lixivium's picture
Last seen: 9 hours 41 min ago
Wild Trail WT3M is floody with some throw and fairly compact. I heard the driver got changed though so idk if it will still perform like the original.
meeshu
Quadrupel wrote:
Good luck buying specifications...
Manufacturer specifications are important to get an idea of how the light performs. The quoted specifications may not be always correct, but it gives a fairly good idea of what lights are capable of.
Lights that do not have specifications available are a lottery. There is really very little or no idea of how they perform, and I'm not buying lights that I do not have at least some idea of expected performance. Otherwise it would most likely be a waste of money and time buying and trying different lights based on little or no specifications.
I have particular requirements for the light I'm after for use in certain circumstances. I have very limited income and time available to waste. So I have to be careful about which light I choose.
Mandrake50
Last seen: 12 hours 31 min ago
I’ve edited my first post to clarify my requirements.
Thank you.
Manufacturers specifications are notoriously inflated in almost all cases. I think you would be far better off by finding a few reviews on any light that you are considering. If you read three or four (or more) of them, you will have a much better understanding of real world performance (including beam shots and comparisons) versus just looking at the spec sheet from the maker.
nicodimus22
Last seen: 2 days 12 hours ago
Manufacturer specifications are usually just another form of advertising. There is zero transparency or testing methodology shared with the consumer. They aren’t good information to base a purchasing decision on, because you have no idea how they got that number (if they did any testing at all.)
You know what gives a fairly good idea what lights are actually capable of? Real-world testing and reviews, and the more the better for consistency.
I hope you find what you’re looking for.
Mark M
Mark M's picture
Last seen: 9 hours 17 min ago
Emisar is definitely the way to go, a real shame if you think specifications are the issue.
Mandrake50
Yeah, and because of this, comparing spec sheets (marketing BS to some extent) from various manufacturers is pretty pointless.
Oli
Last seen: 9 hours 32 min ago
There are no specs that are going to show you how much of the light is in the spot versus in the spill. So your criteria is flawed from the very start. Do you want to actually be able to see clearly out to 30m or do you want the specs to show 30m? Again same question, in the spot or in the spill? Again specs are not going to specify spill throw distance so again your criteria is flawed from the beginning. There are so many good lights that you are not even going to consider because of your flawed criteria. Spell out exactly what you want here and people will respond. Do you not want a hotspot at all?
You can't compare the big flashlight in the sky to the little flashlight in your hand.
quahog
Last seen: 15 hours 29 min ago
Sofirn SP35
Efficient buck driver. 21700 battery. Tube-shaped so should fit well in a pocket. On-board charging. Has last mode memory. Easy user interface.
If it’s not floody enough you can apply some diffusion film (or frosted scotch tape) to the lens.
Medium at 400 lumens lasts 5.5 hours. That should reach 30 meters.
$30 USD with $2 coupon and 5000mAh battery
https://www.aliexpress.com/item/1005002848601801.html
I’d choose the 5000k option.
I’ve gifted this exact light to my father.
meeshu
Manufacturer specifications are a starting point. As already mentioned, their specifications are not entirely accurate, but usually fairly close to actual operating conditions, at least for the main or reputable manufacturers.
Of course I look at reviews where and when available for lights of interest. The problem is that sometimes reviewers do not include outputs (Lumens) and associated runtimes for lower levels of brightness settings. They tend to test only for turbo, high and medium modes and leave out tests for the lower outputs.
The light I'm interested in must be principally a flood type but with a bit of throw as well. So I don't really want a light with a (noticeable) hotspot.
Actually it is possible to get an idea of beam and spill by calculating the beam angle and field angle respectively, provided all the data is available without testing. Beam angle is (relatively) easily calculated, but field angle is not so easy to calculate (for me) at the moment to determine the amount of spill (field) light.
Looking at Wild Trail WT3M light for the moment, thanks.
The Sofirn SP35 has a fairly narrow beam (hotspot) at around 17°. So this is not really suitable as it stands. I avoid having to add extra diffusion whether home made or a manufacturer optional accessory. It is something that could be lost at any time, plus there is usually a (slight) loss of light output. So I prefer a light that has a "natural" floody beam without the use of extra diffusion.
Mandrake50
Maybe take a look at the Convoy S21D with 4 519A LEDs . High CRI. Several choices for optics from 60 degree flood to 10 degree. Several color temps. I think it ticks most of your boxes.
If you ask, Simon would probably send you a selection of the optics for relatively cheap.
He doesn’t publish much as far a specs, but there are a few good reviews out there.
nicodimus22
Mandrake50 wrote:
Maybe take a look at the Convoy S21D with 4 519A LEDs.
Phenomenal floodlight, the best 21700 light I’ve ever used, but it doesn’t throw as OP requested. The beam is very wide and even.
And no manufacturer specs, the importance of which I will have to agree to disagree with the OP about.
CRC2
CRC2's picture
Last seen: 1 week 2 days ago
(Edited a bit.)
I have no idea what the lumen levels are on my Convoy M21B with GTFC40, but comparing it to all my other lights, it is WAY brighter than any of them, is pretty floody and even with a not too defined hot spot, yet reaches impressively far.
Typically I will carry two lights. A flooder and a thrower. But when I only want to carry one light, the M21B/GTFC40 is my go to single light that can do everything I need. (Except reach dedicated thrower distances.)
I think I even prefer it to my dual channel Emisar D4SV2 with LH351D/W1. Which was my original solution to carrying one light but still having two beam styles. The UI is just so much faster and inuitive for me to have exactly the light I want on my target with no fuss.
Not the brightest flashlight in the collection.
John-Atwork
Last seen: 2 hours 33 min ago
Many of the published specs from the manufactures are false or at least a bit exaggerated.  There are a lot of reviews of Convoy lights out on the web and youtube where you could get specifications.
Mandrake50
Yeah… I forgot he said that. Even though real world testing by trusted reviewers is much more likely to reflect the true capabilities of the light.
But, OK, I give up. the OP is imposing limitations that will result in him missing some really great lights. But, Hey. It is what it is. His money….
Lightbringer
Lightbringer's picture
Last seen: 2 hours 10 min ago
There are some nice 999999900lm lights out there if you look. 🤡🤡🤡
meeshu
Thanks to those few with constructive comments.
Seems like I'll have to spend more time finding suitable lights myself rather than relying on folks here. It means more time searching light manufacturers light offerings and then finding (where available) reviews of interesting lights.
Anyway, I've found three lights so far which appear to meet my requirements. Neither are Convoy nor Emisar.
Quadrupel
Quadrupel's picture
We are happy for you.
raccoon city
raccoon city's picture
Last seen: 4 hours 40 min ago
Location: Palm Desert CA ~ West Coast is the best coast
I have a great recommendation, but it's a Convoy, so that's out.  :FACEPALM:
raccoon city
Exactly!
MoreHiCRILumens
MoreHiCRILumens's picture
Last seen: 1 day 16 hours ago
I usually start with UI if I look for that certain light and go from there. Ramping UI is way to go because it just offers more versatility in different situations. Measuring runtimes on those are another thing.
Sustainable lumens are thing that I don’t think any manufacturer measures unless stepdown is timed. So every number that manufacturer claims needs to be checked from review and at the same time you could look other lights that manufacturer doesn’t give any specs. Yes, I agree that those numbers are good starting point.
It’s really hard to find the “best” light if you just look numbers. Sure they help, but only real world beamshots tells the most. Sometimes less lumens are better lumens if we talk about high cri vs. obsolete led technology. Silly
quahog
OK, here’s my last suggestion: ZebraLight SC700Fd (21700 battery)
https://ru.nkon.nl/zaklampen/brands/zebralight-flashlights/zebralight-sc...
gravelmonkey
Last seen: 32 min 29 sec ago
I googled the MS03 to get an idea of what you’re looking for so I could suggest some lights which might compete.
I can’t find the specifications you want (beam angle or lux at lower modes) on the Imalent website… where did you find these?
Some questions which might help narrow the field:
1) What do you mean by 50 degree beam angle? is this Full Width at Half Maximum angle or does it include the ‘spill’ of the beam?
2) What do you mean by 30m of throw? ANSI standard uses 0.25lux on target which is generally considered to be quite low. Is this distance just for the center of the beam or do you want the full ’50 degree beam angle’ to illuminate to 0.25 lux at 30m?
