[̲̅=LMX=] Banggood Deals: Astrolux® EC07 - 13K lms, 468m throw, HP50 LEDs + 650nm red laser, 32,700mAh battery, USB-C rechargeble
New to Banggood: Astrolux® EC07 13000LM 468M Powerful EDC Flashlight 6500K+3000K+650NM Red Shooting Light Color Adjustable Tactical LED Torch With Strong 32700 Rechargeable Battery Type-C Charge and power bank function for charging your devices.
Use code Coupon Code:BG517d75 to bring the flashlight down to around $71 before shipping/tax.
Description:
The EC07 is an outdoor multi-functional flashlight that combines six light bulbs(6*HP50) in a petal-shaped arrangement, with a red beam (650nm)in the center. It features a wide floodlight design. It is compatible with two color temperatures (6500K+3000K), and the two lighting modes can be used separately (switched with a triple press of the button), satisfying various scene requirements. The brightness can reach over 13,000 lumens.
Specifications:
Name Astrolux® EC07 Tiny Monster Flashlight
Brand Astrolux
Model EC07
LED HP50(6500K+3000K)+650NM red shooting light
Lumen 13,000LM
Intensity 54650CD
Distance 468M
Driver Linear Direct Drive + Constant Current
Battery 32700 Li-ion Battery (Included)
Two-way Charging Type-C,and power bank function
Tailcap Magnetic tailcap
Waterproof IP68
Weight 212g without cells
Size 117.1* 56* 40mm (Length x Head Diameter x Body Diameter)
Features:
  1. 13000LM Dual Color Light Source Design
-Equipped with 6*HP50 LED, offering a combination of 6500K cool white light and 3000K warm white light, with an impressive beam intensity of 54650cd. - Features a smooth dimming mode, and a lockout mode that can be activated with 5 clicks to prevent accidental activation. - Astonishing output of up to 13000 lumens. - Provides a maximum beam distance of 468 meters.
  1. 650nm Red Beam Design
  • One Button to Lock The Target
  • Four-click button to open, accurately locate distant targets
  • Ideal for camping, hiking, hunting and emergencies.
  1. Easy To Use & Lockout design
  2. Come with Powerful 32700 Li-ion Cell
  • Including one removeable 32700 7000mAh high-capacity power battery provides more continuous battery life
  1. USB Type-C Charge and Discharge
-Output support: PD3.0 PD2.0 QC3.0 QC2.0 AFC FCP SFCP PE2.0 PE1.1 -Input support: PD3.0 PD2.0 AFC FCP
  1. IP68 Waterproof
  2. Magnetic tailcap
  3. Window Breaker & self-protection
Operations:
Clicks Off On
1 click On(Cool White: CW LED on.
Warm White: WW LED on
Cool&Warm Mix:CW&WW on) Off
Press&Hold Turn on lowest brightness, then
Smooth ramping Smooth Ramping
(lt depends on mode. Cool white: CW LED only
Warm White: WW LED only.)
Red Laser On: tum it off
2 clicks Strobe Turbo(Enter CW&WW &Mix Mode)
3 clicks Mode Change (CW-WW-CW&WW) Mode Change (CW-WW-CW&WW)
4 clicks Red Beam Light On No Response
5 clicks Lockout: Unlock
Unlock: Lockout Lockout: Unlock
Unlock: Lockout
6 clicks Voltage Check Voltage Check
Package includes:
1 x EC07 Flashlight 1 x Lanyard 2 x O-ring 1 x 32700 Battery 1 x Manual
