Anyone familiar with switches? Trying to replace this one
4 posts / 0 new
trailhunter
Last seen: 3 days 8 hours ago
I’m not sure on the type of switch this is. Can anyhelp help identify? It’s from ITW and it’s 12mm diameter. When it worked, you would push the button and it toggles the light on. Is that a momentary switch?
Edited by: trailhunter on 07/27/2022 - 13:31
Quadrupel
Quadrupel's picture
Last seen: 6 hours 59 min ago
Check it with multimeter for continuity. Momentary have continuity only pressed.
kennybobby
kennybobby's picture
Last seen: 19 min 45 sec ago
You might need to unsolder the wires and back the holding nut off to remove the switch (will need to do this anyway when you put a new one in).
then read the model number from the switch.
With that info you can find the datasheet for the switch to know its type, current and voltage rating, etc.
Now i used to think that i was cool,
drivin' around on fossil fuel,
until i saw what i was doin',
was drivin' down the road to ruin. --JT
Niko
Last seen: 1 week 3 days ago
Apem ip67 pushbutton switch, m12 thread.
