FW21 Pro / Anduril clarification please
Hi,
I have been having trouble finding a definite answer to this question, the FW21 Pro according to some, ramps to max then jumps to turbo with 2 clicks - all well and good.
However an owner of one on YT I was just talking to said as far as he knows there is no way to access any light levels between max and turbo. Please tell me that is incorrect? I am looking to buy one but certainly won’t if I can’t set max ramp anywhere I want, between moonlight and near turbo (or at least be able to use the levels between them).
I thought and expected to be able to set max ramp to say 3000lm (or anywhere I want) then double click to turbo….
Alternatively, can it be programmed to ramp the same as a Q8? I.E. hold from off ramp all the way from moonlight to turbo stopping at any level.
Disclaimer, if the dude on YT is a member here, this definitely isn’t a knock at you, I’m just after definite clarification :+1:
Ramp ceiling is factory set to max regulated level. But you can change it to what you want. Set ceiling to 150 and you can ramp to turbo.
Perfect, exactly the answer I was look for, appreciated.
you can change the ‘ceiling’ level
also when using the light normally, while it is ON, you can jump to max possible level - which is usually above the ‘ceiling’ which you set - with 2 fast clicks
if it is OFF, 2 fast clicks go to ceiling, instead of max
